    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      MMRIZE @1a2a3a
      @1a2a3a
      Don’t do edit module’s CSS ever at all. It will be problem on module update.
      Instead, override them in your css/custom.css
        sdetweil @1a2a3a
        @1a2a3a refresh
        if the cursor is over the mm part of the page, ctrl-r
        if the cursor is over the developers window part, f5
        never edit any module provided file, or any mm provided file
        custom.css is designed to enable override of any css.
        1 1 Reply Last reply Reply Quote 0
          1a2a3a @sdetweil
          @sdetweil lol so dead. no idea what i changed in main.css and module css :(
            sdetweil @1a2a3a
            @1a2a3a in each place (mm folder/ module folder) do
            git diff
            it will show you the changed content
            then copy that to custom.css
            when complete, in each place do
            git checkout xxx
            xxx is the filename to restore
            main.css or module_name.css
              1a2a3a @sdetweil
              @sdetweil thank you! that fix it. i needed quite a long time to remediate them haha
                1a2a3a @sdetweil
                @sdetweil hey Sam can I know your vnc tool? Or rather the problem I’m facing now is that I’m using tiger vnc. My pi monitor is vertical. Pc Monitor is horizontal. When I vnc from the pc it shows vertical but my mouse is in horizontal mode so I can’t control it properly to do my css.
                  sdetweil @1a2a3a
                  @1a2a3a I don’t use VNC. I use my PC browser.
                  on windows I use the bitvise ssh client that gives me ssh window for commands and a file system browser for editing files.
                  mixing vertical and horizontal is hard
                    1a2a3a @sdetweil
                    @sdetweil I’m also using bitvise as per your suggestion. Editing config file and the drag and drop is brill.
                    I install MM on pc and do the css on the pc and edit the css before transferring the css over to pi. Only problem is pc MM is horizontal and more often than not I have to guess and trial and error to get my position right.
                    My pc MM is started via npm start dev hence I can adjust the horizontal scale. So the horizontal position is always like for like. It’s the vertical part that I couldn’t do it because well, the horizontal monitor is not long enough….
                      sdetweil @1a2a3a
                      @1a2a3a you don’t have to transfer the css file, just double click to edit and save.
                      I use notepad++ or visual studio code as the config editor
                      yeh, doing the math on the dimension changes is a pain in the rear.
                      get it like you like it horizontal and adjust
                      x times narrow_size/wide_size ( like width of 300px * 1080/1920)
                        1a2a3a
                        @MMRIZE hi, can i know how to change eventheight in cx3? whenever i try to custom change the value, it is overwritten by the default element style which i have no access to it…
                          MMRIZE @1a2a3a
                          @1a2a3a
                          https://github.com/MMRIZE/MMM-CalendarExt3/blob/main/README.md
                            1a2a3a @MMRIZE
                            @MMRIZE read and don’t understand which was what I did.
                            I input —eventheight into my custom css but nothing seems to change
                            Edit:
                            Oh set in config. Let me try
                              1a2a3a
                              @MMRIZE did something change? i did a git pull update and now my calendar ext 3 is missing.
                                sdetweil @1a2a3a
                                @1a2a3a did you npm install in the module folder again?
                                  1a2a3a @sdetweil
                                  @sdetweil yes i deleted it and reinstall. seems to be working fine now
                                    sdetweil @1a2a3a
                                    @1a2a3a he has a part called a submodule, that needs npm install to connect it
                                    so you didn’t need to clone again, just run npm install
                                      crisvdn
                                      Hi there,
                                      Installed your module which is really nice.
                                      I have one question though.
                                      At start up, it fetches all calendar’s I am using. However, it rendered and showed the calendars on the mirror before fetching. So its missing.
                                      Obviously you can fix that by having a faster fetchInterval. But I feel that is kind of unnecessary, since you dont make changes in your agenda by the minute.
                                      Is there a way to Fetch, and only populate the calendar on the mirror after all fetching is done?
                                      Regards, Cris
                                        MMRIZE @crisvdn
                                        @crisvdn
                                        There is ‘waifFetch’ config value to wait enough time.
                                        S C 2 Replies Last reply Reply Quote 0
                                          Splashed @MMRIZE
                                          @MMRIZE
                                          I am having some issues where events show up in my Calendar Module, but don’t always show up in my CalendarExt3 module. For instance, I currently have 5 working calendars displaying the upcoming events via the calendar module. All five calendars are displaying their information.
                                          Currently though, only three of those calendars are showing in my monthly view of CalendarExt3. Sometimes, if I remove one or two of the calendars that do display, then I can get the ones that didnt work to show up on CalendarExt3. Currently however, I have removed all but two calendars, and still only one of them is displaying.
                                          Overall, I have about 8 calendars Id like to link, and Ive never gotten more than about 4-5 to work at once, despite the fact that I can get them all to show in the Calendar module at the same time.
                                          Any suggestions? I can post more details if desired.
                                            sdetweil @Splashed
                                            @Splashed the default calendar clips off the broadcast events using the
                                            maximumEntries
                                            property. the doc says the max is 100, but that is never checked
                                            it can be set above the calendars list
                                            and this value is used for the TOTAL number of events sent
                                            the code
                                            return events.slice(0, this.config.maximumEntries);
                                            or can also be set in a particular calendar
                                            note that this size INCLUDES the PAST events if broadcastPastEvents:true
                                            is set
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 34
                                            • 35
                                            • 22 / 35
