    MMM-CalendarExt3
    689 Posts 82 Posters 2.8m Views 86 Watching
    • 1 Offline
      1a2a3a @sdetweil
      @sdetweil yes i deleted it and reinstall. seems to be working fine now
        sdetweil @1a2a3a
        @1a2a3a he has a part called a submodule, that needs npm install to connect it
        so you didn’t need to clone again, just run npm install
          crisvdn
          Hi there,
          Installed your module which is really nice.
          I have one question though.
          At start up, it fetches all calendar’s I am using. However, it rendered and showed the calendars on the mirror before fetching. So its missing.
          Obviously you can fix that by having a faster fetchInterval. But I feel that is kind of unnecessary, since you dont make changes in your agenda by the minute.
          Is there a way to Fetch, and only populate the calendar on the mirror after all fetching is done?
          Regards, Cris
            MMRIZE @crisvdn
            @crisvdn
            There is ‘waifFetch’ config value to wait enough time.
            S C 2 Replies Last reply Reply Quote 0
              Splashed @MMRIZE
              @MMRIZE
              I am having some issues where events show up in my Calendar Module, but don’t always show up in my CalendarExt3 module. For instance, I currently have 5 working calendars displaying the upcoming events via the calendar module. All five calendars are displaying their information.
              Currently though, only three of those calendars are showing in my monthly view of CalendarExt3. Sometimes, if I remove one or two of the calendars that do display, then I can get the ones that didnt work to show up on CalendarExt3. Currently however, I have removed all but two calendars, and still only one of them is displaying.
              Overall, I have about 8 calendars Id like to link, and Ive never gotten more than about 4-5 to work at once, despite the fact that I can get them all to show in the Calendar module at the same time.
              Any suggestions? I can post more details if desired.
                sdetweil @Splashed
                @Splashed the default calendar clips off the broadcast events using the
                maximumEntries
                property. the doc says the max is 100, but that is never checked
                it can be set above the calendars list
                and this value is used for the TOTAL number of events sent
                the code
                return events.slice(0, this.config.maximumEntries);
                or can also be set in a particular calendar
                note that this size INCLUDES the PAST events if broadcastPastEvents:true
                is set
                  MMRIZE @Splashed
                  @Splashed
                  Maybe one of reason was mentioned by @sdetweil,
                  The other reason might be fetching finish synchronization issue. When you operate many calendars to fetch, some calendars might not end fetching before drawing CX3 due to hw performance, internet speed, server’s issue, etc.
                  There would be 2 general solution.
                  • wait for next refreshing cycle. The fetching of calendars may be completed until then.
                  • Or you can use ‘waitFetch’ config value to delay the rendering view.
                    crisvdn @MMRIZE
                    @MMRIZE Thanks for your response. That actually did this.
                    The config name is a bit confusing though. It implies waiting to fetch the calendars?
                    Anyways, thank you for this awesome module :D
                    • G Offline
                      gonzonia
                      I’ve been using MMM-CalendarExt3 for a while now and all is good. Suddenly I’ve got a single event that’s an hour off. The events for the rest of the day are fine, and the time is correct on all other methods (Google Calendar, BusyCal, iOS Calendar).
                        MMRIZE @gonzonia
                        @gonzonia Could you send me the ice file(or downloadable url) and your config? (eouia0819@gmail.com)
                        • 41
                        • 42
                        • 43
                        • 44
                        • 45
                        • 68
                        • 69
                        • 43 / 69
