    MESA issues - mm actually displays
    3 Posts 3 Posters 583 Views 3 Watching
    • N Offline
      nakulbende
      Saw this error in npm start. Quick search says that these typically rnder a black screen - I am actually seeing MM, so what does this error mean?
      MESA-LOADER: failed to retrieve device information
      ../../buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[27159:1223/223830.134308:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
      ../../buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[27202:1223/223831.357228:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      [27159:1223/223831.363276:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
      [27202:1223/223832.163432:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      BKeyportB S 2 Replies Last reply Reply Quote 0
      • BKeyportB Offline
        BKeyport Module Developer @nakulbende
        @nakulbende 90% of the time this can be ignored. If you’re getting your mirror up on screen, there’s no issue.
          sdetweil @nakulbende
          @nakulbende turn off use of the GPU.
          add
          export ELECTRON_DISABLE_GPU=1
          to the place where you do
          npm start
          add that line before the npm start
          in next release Jan 1,
          we are doing this by default a d adding a new
          ELECTRON_ENABLE_GPU=1
          as no one is really using the GPU
