    MMM-Netatmo does not load
    33 Posts 13 Posters 14.6k Views 14 Watching
    • T Offline
      tommys
      I’m running nodejs v20.8.1 on Ubuntu 22.04 and most MagicMirror modules run fine, except for MMM-Netatmo. It seems to get stuck when fetch-ing the oauth2/token-request, though it receives a response with status 200, but then nothing seems to happen!?
      When I manually post the same request using curl from the command line, it works great and I get my access token, which I successfully can use using curl to get my api/getstationdata.
      The last thing I’m able to debug into is in the node-fetch’s worker.js file:
      process.stdin.on('end', function () {
        const input = JSON.parse(chunks.join(''))
        const request = shared.deserializeRequest(fetch, ...input)
        fetch(request)
          .then(response => response.buffer()
            .then(buffer => respond([
              buffer.toString('base64'),
              shared.serializeResponse(response)
      I can see that shared is updated with at response-header, however, I cannot see the response-body data that is supposed to contain the access-token among other things. And, for me, not being a nodejs/javascript programmer, the app seems to hang with the only thing being shown in the MMM-Netatmo widget is “Loading” forever.
      What could be causing my problems?
      Of course, I have triple checked that my config settings are correct:
          module: 'netatmo',
          position: 'top_center',
          header: 'Netatmo',
              clientId: 'xxx',
              clientSecret: 'yyy',
              refresh_token: 'zzz',
              moduleOrder: ["Inomhus","Utomhus"]
      Regards,
      /Tommy
      • T Offline
        tommys @tommys
        @tommys
        Replying to myself since I finally have solved the problem! Netatmo is now loading fine on the latest versions of MM and MMM-Netatmo.
        The problem was actually caused by two independent problems: the module reordering algorithm and the sync-fetch library.
        The workaround I did to solve the first problem was simply to not set the moduleOrder config property, easy as that.
        The second workaround was a bit more involved, I completely removed the usage of the sync-fetch library in netatmo.js in favor of the default async version . That is, simply remove the line: const fetch = require(‘sync-fetch’), make the authenticate, loadData and socketNotificationReceived functions async, handle the promise object returned by fetch appropriately as well as the call to json().
        S CFennerC C LusbuebL 4 Replies Last reply Reply Quote 2
          sdetweil @tommys
          @tommys the reason for this is fetch is built in in the node 20.8 version used by the node helper.
          • CFennerC Offline
            CFenner @tommys
            @tommys great that you solved the issue! Would you mind contributing that back into the repository?
            • T Offline
              tommys @CFenner
              @CFenner normally I would say: Yes, absolutely! But… I’m not a javascript-developer and know very little about it and node.js.
              This is the first time I dipped my toe in this world (I’ve been working for 30 years as a C++ developer :grinning_face_with_sweat: ) so I just tried things until I got it working. I have probably done something non-idiomatic or worse, so I think it is better that someone more knowledgable do a proper fix. But I’m happy to answer questions if more info than I already provided is needed.
              Btw, a big thank you for your great Netatmo-module @CFenner! :folded_hands:
              • W Offline
                wwats
                Hello everybody, I have the same problem. Because I’m not an IT professional, I’m having trouble solving the problem with your instructions.
                The second workaround in particular is difficult:
                …I completely removed the usage of the sync-fetch library in netatmo.js in favor of the default async version . That is, simply remove the line: const fetch = require(‘sync-fetch’), make the authenticate, loadData and socketNotificationReceived functions async, handle the promise object returned by fetch appropriately as well as the call to json().
                • I can’t find the “const fetch” line in the netatmo.js file
                • how can I make functions asynchronous
                • the sentence “handle the promise object returned by fetch appropriately as well as the call to json().” I don’t really understand either
                Is it possible to make the instructions a bit more detailed? Or what is the best way to ensure that the great module works for me again?
                Thank you very much for your effort!
                  cgillinger @tommys
                  @tommys I have the same problem, but while I can follow instructions and edit files, your description is a bit to advanced for me.
                  Could you break it down, I would really like to get the module working again!
                  CFennerC 1 Reply Last reply Reply Quote 0
                  • CFennerC Offline
                    CFenner @cgillinger
                    @cgillinger I merged a PR from @ottolote to replace the sync-fetch. Please try if that fixes the issue for you. It work for me now, but also did before that change using mm v2.26.
                    C L 2 Replies Last reply Reply Quote 2
                      cgillinger @CFenner
                      @CFenner And just to report back here as well: Now the module works for me again! Thnx!
                      • L Offline
                        Laz @CFenner
                        @CFenner
                        Have you updated your module? Does it need to be reinstated or how to update it?
                        • 1 / 4
