    MM doesnt work after update to version 2.26
    30 Posts 2 Posters 13.1k Views 2 Watching
      davismorehead
      how do I do that?
      also if I run the command
      pi@raspberrypi:~ $ systemctl get-default
      graphical.target
      I get graphical even though I don’t have the file
        davismorehead
        I did
        npm update.
        i did pm2 start mm
        and it works. Thank you very much
          sdetweil @davismorehead
          @davismorehead what npm update?
            davismorehead
            I will look at your script later.
            So in the future I should run npm update not npm install?
              davismorehead
              cd MagicMirror/
              pi@raspberrypi:~/MagicMirror $ npm update
              added 495 packages, and changed 6 packages in 3m
              195 packages are looking for funding
              run npm fund for details
              That worked
                @davismorehead i don’t understand
                when we release a new version, we have dependency changes additions, removals
                so to handle all that you do
                npm run install-mm
                install-mm is a script tag in the package.json
                it just turns off as much of the noise as we can…
                my script does the same thing…
                I don’t know what npm update does. we don’t use it
                  davismorehead @sdetweil
                  @sdetweil said in MM doesnt work after update to version 2.26:
                  ad you could try upgrade, with force instead of apply.
                  so based on this post i Tried npm update. Not sure what you meant me to do. So sounds like we solved it but don’t know why.
                      @davismorehead what I meant was to use my upgrade script
                      its a two step process…
                      test
                      do
                      on the ‘do’
                      its the same command as test, but with the parm ‘apply’ on the end
                      I check if you have already upgraded, and won’t let you do it again, accidentally
                      SO, as you HAVE already downloaded the new code, I would just end
                      but if you change apply to force
                      then upgrade will happen again …
                      my objective is to NOT screw up your wonderful mirror system .
                        davismorehead
                        oh. I have to figure that out since I cannot get it to run because of the default.target file not existing on my pi.
                        Again thanks for your help.
                          @davismorehead that check is only on install, not upgrade
                          different scripts
                            davismorehead
                            oh i see. Ran the upgrade script and everything worked. I didn’t apply since nothing changed. I will run it next time i need to update. Thanks again for you help. You can close this now.
                              @davismorehead I updated the installer (raspberry.sh) to use the
                              command instead of looking at the file…
                              thanks for the info
