    MM doesnt work after update to version 2.26
    30 Posts 2 Posters 13.7k Views 2 Watching
      davismorehead
      I did
      npm update.
      i did pm2 start mm
      and it works. Thank you very much
        sdetweil @davismorehead
        @davismorehead what npm update?
          davismorehead
          I will look at your script later.
          So in the future I should run npm update not npm install?
            davismorehead
            cd MagicMirror/
            pi@raspberrypi:~/MagicMirror $ npm update
            added 495 packages, and changed 6 packages in 3m
            195 packages are looking for funding
            run npm fund for details
            That worked
              @davismorehead i don’t understand
              when we release a new version, we have dependency changes additions, removals
              so to handle all that you do
              npm run install-mm
              install-mm is a script tag in the package.json
              it just turns off as much of the noise as we can…
              my script does the same thing…
              I don’t know what npm update does. we don’t use it
                davismorehead @sdetweil
                @sdetweil said in MM doesnt work after update to version 2.26:
                ad you could try upgrade, with force instead of apply.
                so based on this post i Tried npm update. Not sure what you meant me to do. So sounds like we solved it but don’t know why.
                    @davismorehead what I meant was to use my upgrade script
                    its a two step process…
                    test
                    do
                    on the ‘do’
                    its the same command as test, but with the parm ‘apply’ on the end
                    I check if you have already upgraded, and won’t let you do it again, accidentally
                    SO, as you HAVE already downloaded the new code, I would just end
                    but if you change apply to force
                    then upgrade will happen again …
                    my objective is to NOT screw up your wonderful mirror system .
                      davismorehead
                      oh. I have to figure that out since I cannot get it to run because of the default.target file not existing on my pi.
                      Again thanks for your help.
                        @davismorehead that check is only on install, not upgrade
                        different scripts
                          davismorehead
                          oh i see. Ran the upgrade script and everything worked. I didn’t apply since nothing changed. I will run it next time i need to update. Thanks again for you help. You can close this now.
                            @davismorehead I updated the installer (raspberry.sh) to use the
                            systemctl get-default
                            command instead of looking at the file…
                            thanks for the info
