    magicmirror lagging
    16 Posts 3 Posters 3.7k Views 3 Watching
    • 1 Offline
      1a2a3a @sdetweil
      @sdetweil it was working smoothly previously using the same pi. ill try to enable the gpu but where do i insert that line?
        sdetweil @1a2a3a
        @1a2a3a in the script used to launch MM
        if you are using my installer, and pm2 that is
        ~/MagicMirror/installers/mm.sh
        we changed electron versions too, and well, you never know
        1 1 Reply Last reply Reply Quote 0
        • 1 Offline
          1a2a3a @sdetweil
          @sdetweil hmm not sure if its a placebo effect, but seems to be slightly better but still jerky, not sure. before the update, the marquee effect of ext3 and googlephoto transitioning was smooth. now its like uh… jerky transitioning…
            sdetweil @1a2a3a
            @1a2a3a and u restarted MM after changing the script…
            • 1 Offline
              1a2a3a @sdetweil
              @sdetweil yes i did, definitely…
                sdetweil @1a2a3a
                @1a2a3a can u look and see any new gpu related errors
                pm2 logs --lines=50
                • 1 Offline
                  1a2a3a @sdetweil
                  @sdetweil got this when i enter the command inside mm directory.
                  0|MagicMir |   source: undefined,
                  0|MagicMir |   lineno: undefined,
                  0|MagicMir |   colno: undefined
                  0|MagicMir | }
                  0|MagicMir | [11.01.2024 21:44.04.187] [ERROR] Image loading fails. Check your network.: https://lh3.googleusercontent.com/lr/AAJ1LKd3z4DnSUe5L1BE7e-FC_pskhLh8qgzww-omvYwOFtBiGVsKpqDYmvKZD0mxqWdY3fN1xmlcGXasptkJvlKlFku4fXyNJ_3sBeVfQr1FiqrLUBKfwL24EwZV4rEw69eSU9MapZBunE_Ey5NP8f00QRRpTp3epZkUmknUrFsMZEqtLeXICD_ekNaqEVF_E74TdBaLbdDC4e_jPzNiTKft13TD5YlyWFbcqmRFUCIlgTa4xov-PRt0MExDbZ6kKUMwzsG9RXN2J7h45K5YLKVafTzNkv0fkV-12keW9AZ3eBV7qaGfQOlMGQ-JcKqtwK0DEMizJfRjRfZHXxRLR-OWwXNuJ_otSKRWP5wQcExGkSxxypDt1oQihiRbBznDygTIFVFqYgQtk6rrD_po8MHsSyPYiQvwuvVqBzkpSc_1OJuMC5LYUL23lkQXx468oUDNmnTUQzjrM4KnSOXUV7vWnGpA4HMQIBq0tluQw-9-3nH97a_8X3AwZ4QllXWc9Xo6vaiItASDizjOx5REF7nrQ9sODXqbxgvQwaG4JJN12Mv_hQbMD4epKiLzIALs2wN1N-Z6U9VGNuikHrgJ-dg7dyMdj0uJL_vZthfX7CFwHZ8iNxLIOkeMW3lzDSTKpDJnSmFyXi289wVGnGZj-huCGXY4YbMHbdhLKPP8uSsOk6DYkWYkTn2VS8g9IKncvWkDvVt2ASQMrlZ2-1Eh2IuA-SE0gslF9_2Ck0u0ZtYk1V6Ea_5VvDAZbAn6rEfBFDJ6Q5945ngkG29NvkLm2fIiN_58Lb8DwDtD9lq7iIhkLRDI_eNfqIGN7DKEA3fjS2kxDPmS4-vtWgNe2K_l4iZJLSw2oQeaQNR-271qPLzg5cx39KhS0rDLiFqwNzYVWW2Inxj2T1VUkGAnn6GeY5Bj2DcnyeWcN0ry2qy5FpBKnEFq7DCPbViE2-RqU_zr7YiiUh9zUx2SBgubegJjC0_duDNdJQ2TReTfCMJ5thj6h-Ty-DeBTzOyEOHbhJLcwrPVP19Hru12RLrCIP-rQ4ijpSR8MJC=w1080-h1920
                  0|MagicMir | /home/hsa/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
                  0|MagicMir | [2314:0111/215933.525635:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2314:0111/215933.525875:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2314:0111/215933.525982:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2314:0111/215933.526092:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2314:0111/215933.526216:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2314:0111/215933.526332:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2314:0111/215933.526438:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2314:0111/215933.528604:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2314:0111/215933.528735:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2314:0111/215933.528835:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2314:0111/215933.528930:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2314:0111/215933.529025:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2314:0111/215933.529123:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [2314:0111/215933.529221:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | Warning: vkCreateInstance: Found no drivers!
                  0|MagicMir | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                  0|MagicMir |     at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                  0|MagicMir |     at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                  0|MagicMir |     at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                  0|MagicMir |     at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                  0|MagicMir |     at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                  0|MagicMir |
                  0|MagicMir | [4558:0111/220928.037273:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [4558:0111/220928.037465:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [4558:0111/220928.037555:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [4558:0111/220928.037643:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [4558:0111/220928.037720:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [4558:0111/220928.037801:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [4558:0111/220928.037880:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [4558:0111/220928.039683:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [4558:0111/220928.039825:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [4558:0111/220928.039920:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [4558:0111/220928.040015:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [4558:0111/220928.042133:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [4558:0111/220928.042266:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir | [4558:0111/220928.042352:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                  0|MagicMir |
                    sdetweil @1a2a3a
                    @1a2a3a Oh such joy… not
                    • 1 Offline
                      1a2a3a @sdetweil
                      @sdetweil i remove gpu and it doesnt seems to have error.
                      so i ran npm start again seems to run fine but showing this
                      [6141:0111/221958.106148:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [6141:0111/221958.106492:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [6141:0111/221958.106652:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [6141:0111/221958.106803:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [6141:0111/221958.106975:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [6141:0111/221958.107162:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [6141:0111/221958.107343:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [6141:0111/221958.110017:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      [6141:0111/221958.110444:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: No such file or directory (2)
                      • 1 Offline
                        1a2a3a
                        so i assumed all is in good order ya? the reason for the supposed jerky lag is due to new mm version not playing well with pi 5 wayland?
