    MMM-CalendarExt3Agenda no longer working after MM update
    9 Posts 3 Posters 1.6k Views 3 Watching
    • K Offline
      Kelemvor
      I installed the new version of MM and now this module isn’t working properly. I get some data but not much. I do see a notification that there’s an update, but when I run git pull and npm install, it gives me a warning about committing changes for a json file and then says aborted. (not sure if that’s important or not).
      Updating d1d25b3…e0adcbf
      error: Your local changes to the following files would be overwritten by merge:
      package-lock.json
      Please commit your changes or stash them before you merge.
      Aborting
      up to date, audited 1 package in 2s
      When I run MM, the calendar info shows but only a few items and doesn’t grab all the calendars in the list.
      Anyone know why this might not be working and how I update it properly if that’s the issue?
      Thanks!
        sdetweil @Kelemvor
        @Kelemvor do
        git checkout package-lock.json
        git pull
        npm run install-mm
        npm install node-ical@0.16.1
        K 1 Reply Last reply Reply Quote 1
        • K Offline
          Kelemvor @sdetweil
          @sdetweil Thanks!
          I ran that and it seemed to fix the problem. It still tells me there’s an update for Ext3Agenta. Do I now need to run the Upgrade commands from Git again?
          cd ~/MagicMirror/modules/MMM-CalendarExt3Agenda
          git pull
          npm update
          Also, at the end of everything loading I see this. Not sure what it means or if it’s important or not.
          Thoughts?
            sdetweil @Kelemvor
            @Kelemvor generally there is an error further up for the vkCreateInstance problem…
            you can also try a newer version of electron
            npm install electron@28.1.1
            • K Offline
              Kelemvor @sdetweil
              THe vk thing doesn’t seem to be affecting anything so I’ll make a new thread about that if somethign comes up.
              MM is still telling me that there’s an update available for CalendarExt3Agenda.
              I previously ran:
              git pull
              npm update
              But it still tells me there’s an update. Is there some other command I need to run? I ran it before running the commands you pasted in above so maybe I just need to run these commands again?
              Thanks.
                sdetweil @Kelemvor
                @Kelemvor I don’t know on his modules
                  MMRIZE @Kelemvor
                  @Kelemvor
                  Go to directory of CX3A then open the package.json. Could u check the version number?
                  • K Offline
                    Kelemvor @MMRIZE
                    @MMRIZE Hi. The version in Packages.json is 1.4.1.
                    Thanks.
                      MMRIZE @Kelemvor
                      @Kelemvor
                      1.4.2 is the latest version.
