    Homewizard P1 meter
    11 Posts 5 Posters 4.3k Views 5 Watching
    • V
      vansman
      I like to see some data from the Homewizard P1 meter on my mirror.
      There is an local api which can be turned on in the app.
      In a browser i get the current data with http://IP_P1_meter/api/v1/telegram
      Unfortunately my coding skills are not that great.
      Hope someone like to create it
      • H
        Hoaxr
        Hi, i just received mine, and i was also search for this.
        Yesterday i started to create my first module and it seems to show me data.
        I need to make it more clean and add more from the api. But shouldn’t take to long i think. I will keep you posted and will put it on github when i think it’s releasable :p.
        If you have anything you would like to see let me know so in can see if it’s possible from my end
        • H
          Hoaxr
          Here you go:
          Github MMM-HomeWizard
          For now very simple, but it’s something :)
          V C 2 Replies Last reply
          • V
            vansman @Hoaxr
            @Hoaxr Thanks! It works.
            I added some dataRequest’s in Homewizard.js. (current voltage - total export)
            What i like to see is a daily use of energy. In the API list i see a timestamp but my coding skills are very low.
            I also tried to add the data from the watermeter. This data comes from another local ip adres. When adding the dataRequest.active_liter_lpm the display returns a Null number.
            So tried add an second ip in config.js but then the first ip is ignored, so all electricity and gas return a Null number. (the value of the watermeter then displayed correct.)
            But a nice start that i have some info on my mirror.
            Thanks so far
              CTL073 @Hoaxr
              @Hoaxr Hi, this one stopped working due to various issues. Any possibility to fix this?
              H 1 Reply Last reply
              • H
                Hoaxr @CTL073
                @CTL073 still works fine here. Not sure what errors you get?
                V 1 Reply Last reply
                • V
                  vansman @Hoaxr
                  @Hoaxr Mine is also stopped working. Try to set the url in whitelist but that seems to do nothing with it.
                  When copy the url in the browser i get the information on my screen so the url is right and working at the rasberry.
                  Only see the header on my mirror no data.
                  • V
                    vansman @vansman
                    @vansman it starts working again. After a few days the information is returned at the screen. No idea why.
                    • htilburgsH
                      htilburgs
                      I try to install with
                      git pull https://github.com/Hoaxr/MMM-HomeWizard.git
                      This failes. i got errors
                      remote: Counting objects: 100% (24/24), done.
                      remote: Compressing objects: 100% (22/22), done.
                      remote: Total 24 (delta 6), reused 12 (delta 0), pack-reused 0 (from 0)
                      Unpacking objects: 100% (24/24), 7.95 KiB | 232.00 KiB/s, done.
                      From https://github.com/Hoaxr/MMM-HomeWizard
                       * branch            HEAD       -> FETCH_HEAD
                      hint: You have divergent branches and need to specify how to reconcile them.
                      hint: You can do so by running one of the following commands sometime before
                      hint: your next pull:
                      hint:
                      hint:   git config pull.rebase false  # merge
                      hint:   git config pull.rebase true   # rebase
                      hint:   git config pull.ff only       # fast-forward only
                      hint:
                      hint: You can replace "git config" with "git config --global" to set a default
                      hint: preference for all repositories. You can also pass --rebase, --no-rebase,
                      hint: or --ff-only on the command line to override the configured default per
                      hint: invocation.
                      fatal: Need to specify how to reconcile divergent branches.
                      (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
                      htilburgsH S 2 Replies Last reply
                      • htilburgsH
                        htilburgs @htilburgs
                        @htilburgs
                        Currently I’ve installed it with a work-around.
                          sdetweil @htilburgs
                          @htilburgs that says you changed a file in the module, which you aren’t supposed to do.
                          git status would have shown the changed file(s)
                          git diff would have shown you the exact changes
                          git reset --hard HEAD
                          will force all the changes to be lost and the repo restored to the last commit
                          (and allow you to git pull)
