    Homewizard P1 meter
    11 Posts 5 Posters 2.9k Views 5 Watching
      CTL073 @Hoaxr
      @Hoaxr Hi, this one stopped working due to various issues. Any possibility to fix this?
      • H Offline
        Hoaxr @CTL073
        @CTL073 still works fine here. Not sure what errors you get?
        • V Offline
          vansman @Hoaxr
          @Hoaxr Mine is also stopped working. Try to set the url in whitelist but that seems to do nothing with it.
          When copy the url in the browser i get the information on my screen so the url is right and working at the rasberry.
          Only see the header on my mirror no data.
          • V Offline
            vansman @vansman
            @vansman it starts working again. After a few days the information is returned at the screen. No idea why.
            • htilburgsH Offline
              htilburgs
              I try to install with
              git pull https://github.com/Hoaxr/MMM-HomeWizard.git
              This failes. i got errors
              remote: Counting objects: 100% (24/24), done.
              remote: Compressing objects: 100% (22/22), done.
              remote: Total 24 (delta 6), reused 12 (delta 0), pack-reused 0 (from 0)
              Unpacking objects: 100% (24/24), 7.95 KiB | 232.00 KiB/s, done.
              From https://github.com/Hoaxr/MMM-HomeWizard
               * branch            HEAD       -> FETCH_HEAD
              hint: You have divergent branches and need to specify how to reconcile them.
              hint: You can do so by running one of the following commands sometime before
              hint: your next pull:
              hint:
              hint:   git config pull.rebase false  # merge
              hint:   git config pull.rebase true   # rebase
              hint:   git config pull.ff only       # fast-forward only
              hint:
              hint: You can replace "git config" with "git config --global" to set a default
              hint: preference for all repositories. You can also pass --rebase, --no-rebase,
              hint: or --ff-only on the command line to override the configured default per
              hint: invocation.
              fatal: Need to specify how to reconcile divergent branches.
              (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
              htilburgsH S 2 Replies Last reply Reply Quote 0
                htilburgs @htilburgs
                @htilburgs
                Currently I’ve installed it with a work-around.
                  sdetweil @htilburgs
                  @htilburgs that says you changed a file in the module, which you aren’t supposed to do.
                  git status would have shown the changed file(s)
                  git diff would have shown you the exact changes
                  git reset --hard HEAD
                  will force all the changes to be lost and the repo restored to the last commit
                  (and allow you to git pull)
