    vkCreateInstance failed with: Found no drivers
    14 Posts 4 Posters 5.9k Views 4 Watching
      sdetweil @Todt40
      @Todt40 yes, that is a garbage message put out by electron. typically this is because of another error earlier…
      you can try the later electron version
      npm install electron@28.1.1
      T 1 Reply Last reply
      • T
        Todt40 @sdetweil
        @sdetweil so I tried installing the new version of electron, but it still gives the same error.
          sdetweil @Todt40
          @Todt40 can u look higher up in the output, is there any other error?
          T 2 Replies Last reply
          • T
            Todt40 @sdetweil
            @sdetweil there is no other error in the error-log created by pm2.
            /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
            Warning: vkCreateInstance: Found no drivers!
            Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
               at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:101)
               at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:493)
               at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:379)
               at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:301)
               at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:556)
            this is the everything in the error log.
              sdetweil @Todt40
              @Todt40 what about in the non error output
              • T
                Todt40 @sdetweil
                @sdetweil during the installation of the new electron version I also got this error:
                (node:1643) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
                maybe like 10 times or something, I don’t know if this is also a problem?
                • T
                  Todt40 @sdetweil
                  @sdetweil this is the normal output log:
                  > magicmirror@2.26.0 start
                  [17.01.2024 15:45.08.877] [LOG]   Starting MagicMirror: v2.26.0
                  [17.01.2024 15:45.08.885] [LOG]   Loading config ...
                  [17.01.2024 15:45.08.896] [DEBUG] config template file not exists, no envsubst
                  [17.01.2024 15:45.08.907] [LOG]   Loading module helpers ...
                  [17.01.2024 15:45.08.912] [LOG]   No helper found for module: alert.
                  [17.01.2024 15:45.08.962] [LOG]   Initializing new module helper ...
                  [17.01.2024 15:45.08.963] [LOG]   Module helper loaded: updatenotification
                  [17.01.2024 15:45.08.965] [LOG]   No helper found for module: clock.
                  [17.01.2024 15:45.09.687] [LOG]   Initializing new module helper ...
                  [17.01.2024 15:45.09.689] [LOG]   Module helper loaded: calendar
                  [17.01.2024 15:45.09.691] [LOG]   No helper found for module: compliments.
                  [17.01.2024 15:45.09.707] [LOG]   No helper found for module: weather.
                  [17.01.2024 15:45.10.284] [LOG]   Initializing new module helper ...
                  [17.01.2024 15:45.10.284] [LOG]   Module helper loaded: newsfeed
                  [17.01.2024 15:45.10.285] [LOG]   All module helpers loaded.
                  [17.01.2024 15:45.10.363] [LOG]   Starting server on port 8080 ...
                  [17.01.2024 15:45.10.487] [LOG]   Server started ...
                  [17.01.2024 15:45.10.488] [LOG]   Connecting socket for: updatenotification
                  [17.01.2024 15:45.10.489] [LOG]   Starting module helper: updatenotification
                  [17.01.2024 15:45.10.490] [LOG]   Connecting socket for: calendar
                  [17.01.2024 15:45.10.491] [LOG]   Starting node helper for: calendar
                  [17.01.2024 15:45.10.491] [LOG]   Connecting socket for: newsfeed
                  [17.01.2024 15:45.10.492] [LOG]   Starting node helper for: newsfeed
                  [17.01.2024 15:45.10.493] [LOG]   Sockets connected & modules started ...
                  [17.01.2024 15:45.11.596] [LOG]   Launching application.
                  [17.01.2024 15:45.19.121] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/7US_Holidays.ics - Interval: 604800000
                  [17.01.2024 15:45.20.111] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                  [17.01.2024 15:45.20.153] [INFO]  updatenotification: Updater Class Loaded!
                  [17.01.2024 15:45.20.154] [INFO]  updatenotification: Checking PM2 using...
                  [17.01.2024 15:45.20.179] [INFO]  Checking git for module: MagicMirror
                  [17.01.2024 15:45.22.848] [INFO]  Calendar-Fetcher: Broadcasting 11 events from https://ics.calendarlabs.co7/US_Holidays.ics.
                  [17.01.2024 15:45.28.343] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                  [17.01.2024 15:45.30.251] [INFO]  updatenotification: You are using pm2 with MagicMirror
                  [17.01.2024 15:50.28.992] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
                    sdetweil @Todt40
                    @Todt40 ok… its still a noise message… ignore it
                      sdetweil @Todt40
                      @Todt40 yes, its a bug in the npm executable… nothing we can do about it
                      karsten13K 1 Reply Last reply
                      • karsten13K
                        karsten13 @sdetweil
                        I found nothing how to get rid of this messages, I think its electron/chromium related and I’m getting these errors too, not always when starting but a few minutes later.
                          sdetweil @karsten13
                          @karsten13 yes, I think this is another environmental expectation bug in electron… they expect the vulcan display drivers…
                          mumblebajM 1 Reply Last reply
                          • mumblebajM
                            @sdetweil Just out of interest, this is the error I see on Ubuntu running on my Windows machine.
                            This is complaining about a version of vulkan. Different from what I see on my Raspi.
                              sdetweil @mumblebaj
                              @mumblebaj yes it’s a garbage error. they expect the Vulcan drivers but continue on…
