    vkCreateInstance failed with: Found no drivers
    14 Posts 4 Posters 5.4k Views 4 Watching
    • T Offline
      Todt40 @sdetweil
      @sdetweil there is no other error in the error-log created by pm2.
      /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      Warning: vkCreateInstance: Found no drivers!
      Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
         at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:101)
         at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:493)
         at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:379)
         at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:301)
         at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:556)
      this is the everything in the error log.
        sdetweil @Todt40
        @Todt40 what about in the non error output
        • T Offline
          Todt40 @sdetweil
          @sdetweil during the installation of the new electron version I also got this error:
          (node:1643) MaxListenersExceededWarning: Possible EventEmitter memory leak detected. 11 close listeners added to [TLSSocket]. Use emitter.setMaxListeners() to increase limit
          maybe like 10 times or something, I don’t know if this is also a problem?
          • T Offline
            Todt40 @sdetweil
            @sdetweil this is the normal output log:
            > magicmirror@2.26.0 start
            [17.01.2024 15:45.08.877] [LOG]   Starting MagicMirror: v2.26.0
            [17.01.2024 15:45.08.885] [LOG]   Loading config ...
            [17.01.2024 15:45.08.896] [DEBUG] config template file not exists, no envsubst
            [17.01.2024 15:45.08.907] [LOG]   Loading module helpers ...
            [17.01.2024 15:45.08.912] [LOG]   No helper found for module: alert.
            [17.01.2024 15:45.08.962] [LOG]   Initializing new module helper ...
            [17.01.2024 15:45.08.963] [LOG]   Module helper loaded: updatenotification
            [17.01.2024 15:45.08.965] [LOG]   No helper found for module: clock.
            [17.01.2024 15:45.09.687] [LOG]   Initializing new module helper ...
            [17.01.2024 15:45.09.689] [LOG]   Module helper loaded: calendar
            [17.01.2024 15:45.09.691] [LOG]   No helper found for module: compliments.
            [17.01.2024 15:45.09.707] [LOG]   No helper found for module: weather.
            [17.01.2024 15:45.10.284] [LOG]   Initializing new module helper ...
            [17.01.2024 15:45.10.284] [LOG]   Module helper loaded: newsfeed
            [17.01.2024 15:45.10.285] [LOG]   All module helpers loaded.
            [17.01.2024 15:45.10.363] [LOG]   Starting server on port 8080 ...
            [17.01.2024 15:45.10.487] [LOG]   Server started ...
            [17.01.2024 15:45.10.488] [LOG]   Connecting socket for: updatenotification
            [17.01.2024 15:45.10.489] [LOG]   Starting module helper: updatenotification
            [17.01.2024 15:45.10.490] [LOG]   Connecting socket for: calendar
            [17.01.2024 15:45.10.491] [LOG]   Starting node helper for: calendar
            [17.01.2024 15:45.10.491] [LOG]   Connecting socket for: newsfeed
            [17.01.2024 15:45.10.492] [LOG]   Starting node helper for: newsfeed
            [17.01.2024 15:45.10.493] [LOG]   Sockets connected & modules started ...
            [17.01.2024 15:45.11.596] [LOG]   Launching application.
            [17.01.2024 15:45.19.121] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/7US_Holidays.ics - Interval: 604800000
            [17.01.2024 15:45.20.111] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
            [17.01.2024 15:45.20.153] [INFO]  updatenotification: Updater Class Loaded!
            [17.01.2024 15:45.20.154] [INFO]  updatenotification: Checking PM2 using...
            [17.01.2024 15:45.20.179] [INFO]  Checking git for module: MagicMirror
            [17.01.2024 15:45.22.848] [INFO]  Calendar-Fetcher: Broadcasting 11 events from https://ics.calendarlabs.co7/US_Holidays.ics.
            [17.01.2024 15:45.28.343] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
            [17.01.2024 15:45.30.251] [INFO]  updatenotification: You are using pm2 with MagicMirror
            [17.01.2024 15:50.28.992] [INFO]  Newsfeed-Fetcher: Broadcasting 29 items.
              sdetweil @Todt40
              @Todt40 ok… its still a noise message… ignore it
                sdetweil @Todt40
                @Todt40 yes, its a bug in the npm executable… nothing we can do about it
                • karsten13K Offline
                  karsten13 @sdetweil
                  I found nothing how to get rid of this messages, I think its electron/chromium related and I’m getting these errors too, not always when starting but a few minutes later.
                    sdetweil @karsten13
                    @karsten13 yes, I think this is another environmental expectation bug in electron… they expect the vulcan display drivers…
                    • mumblebajM Offline
                      @sdetweil Just out of interest, this is the error I see on Ubuntu running on my Windows machine.
                      This is complaining about a version of vulkan. Different from what I see on my Raspi.
                        sdetweil @mumblebaj
                        @mumblebaj yes it’s a garbage error. they expect the Vulcan drivers but continue on…
