    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil Yes but it’s thanks to people like you that there is still communication without banking intermediary to build projects… I would therefore stay with my version 2.5 which is free while waiting for a developer to find a solution:- ) what bothers me is that the weather forecast with pretty icons etc. there are some on smartphones, cars, television, internet etc. and all this is free, as soon as you want to do something different you have to PAY :-(
        sdetweil @Manu85
        @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
        the problem is that the provider (openweathermap), is only providing v3 api keys now for the OneCall api used by the module.
        SO… there is nothing the developer can do to get around that.
        openweathermap is no longer issuing 2.5 api keys
          manu85340 @sdetweil
          @sdetweil I found a post from March 2023 where we talk about you on the same subject 😉
            sdetweil @manu85340
            @manu85340 yes, this module is already using all that
                apiVersion: "3.0",
             `https://api.openweathermap.org/data/${config.apiVersion}/onecall` +
              Manu85 @sdetweil
              @sdetweil I subscribed to onecall and I just tested this morning and I still have the same “loading” thing, in my config.js I put the following things:
              module: "MMM-OneCallWeather",
                   position: "top_right", // This can be any of the regions.
                   // Best results in bottom_bar region due to horizontal default layout and icon sizes.
                     latitude: "46.561180", // Longitude from https://www.latlong.net/
                     longitude: "-1.782440", // Longitude from https://www.latlong.net/ - is West + is East of London
                     apikey: "MY NEW API KEY V3.0" // openweathermap.org API key.
              in MMM-OneCallWeather.js I have this:
              letdata;
              Module.register("MMM-OneCallWeather", {
                 // Default module config.
                 defaults: {
                   latitude: true,
                   longitude: true,
                   apikey: "",
                   apiVersion: "3.0",
                   units: config.units,
                   layout: "vertical", // default
                   showRainAmount: false,
                   showWind: true,
                   showWindDirection: true,
                   showFeelsLike: true,
                   tempUnits: "c",
                   windunits: "mph",
                   useBeaufortInCurrent: false,
                   initialLoadDelay: 2500, // 2.5 seconds delay. This delay is used to keep the OpenWeather API happy.
                   updateInterval: 10 * 60 * 1000, // every 10 minutes
                   animationSpeed: 1000,
                   updateFadeSpeed: 500,
                   lang:config.language,
                   language: config.language,
                   requestDelay: 0,
              I haven’t touched anything else, can you help me please?
                sdetweil @Manu85
                @Manu85 show me the output of npm start
                if you use pm2 to launch, then
                pm2 logs --lines=50
                  Manu85 @sdetweil
                  @sdetweil Is that what we need to do? I ran the npm start command in putty
                  pi@MagicMirror:~ $ npm start
                  npm ERR! code ENOENT
                  npm ERR! syscall open
                  npm ERR! errno -2
                  npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                  npm ERR! enoent This is related to npm not being able to find a file.
                  npm ERR! enoent
                  npm ERR!     /home/pi/.npm/_logs/2024-01-24T12_40_06_083Z-debug.log
                    sdetweil @Manu85
                    @Manu85 need to be in the MagicMirror folder
                      Manu85 @sdetweil
                      @sdetweil I did that, I hope it’s ok, however the cursor remains stuck at the bottom left and does not return to: ```
                      pi@MagicMirror:~/MagicMirror $
                      pi@MagicMirror:~/MagicMirror $ npm start
                      > magicmirror@2.23.0 start /home/pi/MagicMirror
                      [24.01.2024 14:15.19.980] [LOG]   Starting MagicMirror: v2.23.0
                      [24.01.2024 14:15.19.999] [LOG]   Loading config ...
                      [24.01.2024 14:15.20.009] [DEBUG] config template file not exists, no envsubst
                      [24.01.2024 14:15.20.024] [LOG]   Loading module helpers ...
                      [24.01.2024 14:15.20.031] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Logging/MMM-Logging.js found for module: MMM-Logging.
                      [24.01.2024 14:15.20.034] [LOG]   No helper found for module: MMM-Logging.
                      [24.01.2024 14:15.20.036] [LOG]   No helper found for module: clock.
                      [24.01.2024 14:15.20.075] [LOG]   Initializing new module helper ...
                      [24.01.2024 14:15.20.079] [LOG]   Module helper loaded: MMM-PiTemp
                      [24.01.2024 14:15.20.153] [LOG]   Initializing new module helper ...
                      [24.01.2024 14:15.20.155] [LOG]   Module helper loaded: MMM-OneCallWeather
                      [24.01.2024 14:15.20.161] [LOG]   Initializing new module helper ...
                      [24.01.2024 14:15.20.163] [LOG]   Module helper loaded: MMM-DHT
                      [24.01.2024 14:15.20.681] [LOG]   Initializing new module helper ...
                      [24.01.2024 14:15.20.682] [LOG]   Module helper loaded: calendar
                      [24.01.2024 14:15.20.683] [LOG]   No helper found for module: MMM-SmartWebDisplay.
                      [24.01.2024 14:15.20.685] [LOG]   No helper found for module: MMM-ISS-Live.
                      [24.01.2024 14:15.20.746] [LOG]   Initializing new module helper ...
                      [24.01.2024 14:15.20.747] [LOG]   Module helper loaded: newsfeed
                      [24.01.2024 14:15.20.748] [LOG]   All module helpers loaded.
                      [24.01.2024 14:15.20.777] [LOG]   Starting server on port 8080 ...
                      [24.01.2024 14:15.20.791] [WARN]  You're using a full whitelist configuration to allow for all IPs
                      [24.01.2024 14:15.20.818] [ERROR] Whoops! There was an uncaught exception...
                      [24.01.2024 14:15.20.834] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                          at Server.setupListenHandle [as _listen2] (node:net:1432:16)
                          at listenInCluster (node:net:1480:12)
                          at doListen (node:net:1629:7)
                          at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
                        code: 'EADDRINUSE',
                        errno: -98,
                        syscall: 'listen',
                        address: '0.0.0.0',
                        port: 8080
                      [24.01.2024 14:15.20.834] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [24.01.2024 14:15.20.835] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                      [24.01.2024 14:15.21.545] [LOG]   Launching application.
                      [1330:0124/141522.949654:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                      [1353:0124/141523.177443:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                      code_text
                        sdetweil @Manu85
                        @Manu85 well it’s running…so no return to command line, ctrl-c to stop
                        but, the message here says you didn’t stop the one running by pm2, do
                        pm2 stop all
                          Manu85 @sdetweil
                          @sdetweil now I have this
                          pi@MagicMirror:~ $ cd  ~/MagicMirror/
                          pi@MagicMirror:~/MagicMirror $ pm2 stop all
                          [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                          [PM2] [mm](0) ✓
                          │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                          │ 0  │ mm                 │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                            sdetweil @Manu85
                            @Manu85 yes, now
                            npm start
                              Manu85 @sdetweil
                              @sdetweil ok it’s done but I have the impression that the page adds new lines every 20 seconds, I’ll give you a screenshot, please tell me what you need or what to do please
                                sdetweil @Manu85
                                @Manu85 I was looking for the error from the calendar module. it would have been right near the top
                                  Manu85 @sdetweil
                                  @sdetweil towards this place?
                                  [24.01.2024 14:30.00.848] [LOG]   Starting MagicMirror: v2.23.0
                                  [24.01.2024 14:30.00.868] [LOG]   Loading config ...
                                  [24.01.2024 14:30.00.876] [DEBUG] config template file not exists, no envsubst
                                  [24.01.2024 14:30.00.889] [LOG]   Loading module helpers ...
                                  [24.01.2024 14:30.00.892] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Logg        ing/MMM-Logging.js found for module: MMM-Logging.
                                  [24.01.2024 14:30.00.894] [LOG]   No helper found for module: MMM-Logging.
                                  [24.01.2024 14:30.00.895] [LOG]   No helper found for module: clock.
                                  [24.01.2024 14:30.00.927] [LOG]   Initializing new module helper ...
                                  [24.01.2024 14:30.00.929] [LOG]   Module helper loaded: MMM-PiTemp
                                  [24.01.2024 14:30.00.983] [LOG]   Initializing new module helper ...
                                  [24.01.2024 14:30.00.985] [LOG]   Module helper loaded: MMM-OneCallWeather
                                  [24.01.2024 14:30.00.990] [LOG]   Initializing new module helper ...
                                  [24.01.2024 14:30.00.991] [LOG]   Module helper loaded: MMM-DHT
                                  [24.01.2024 14:30.01.443] [LOG]   Initializing new module helper ...
                                  [24.01.2024 14:30.01.444] [LOG]   Module helper loaded: calendar
                                  [24.01.2024 14:30.01.445] [LOG]   No helper found for module: MMM-SmartWebDispla        y.
                                  [24.01.2024 14:30.01.447] [LOG]   No helper found for module: MMM-ISS-Live.
                                  [24.01.2024 14:30.01.496] [LOG]   Initializing new module helper ...
                                  [24.01.2024 14:30.01.496] [LOG]   Module helper loaded: newsfeed
                                  [24.01.2024 14:30.01.497] [LOG]   All module helpers loaded.
                                  [24.01.2024 14:30.01.520] [LOG]   Starting server on port 8080 ...
                                  [24.01.2024 14:30.01.533] [WARN]  You're using a full whitelist configuration to        allow for all IPs
                                  [24.01.2024 14:30.01.554] [LOG]   Server started ...
                                  [24.01.2024 14:30.01.556] [LOG]   Connecting socket for: MMM-PiTemp
                                  [24.01.2024 14:30.01.558] [LOG]   Starting module helper: MMM-PiTemp
                                  [24.01.2024 14:30.01.559] [LOG]   Connecting socket for: MMM-OneCallWeather
                                  [24.01.2024 14:30.01.561] [LOG]   Connecting socket for: MMM-DHT
                                  [24.01.2024 14:30.01.561] [LOG]   Starting module helper: MMM-DHT
                                  [24.01.2024 14:30.01.562] [LOG]   Connecting socket for: calendar
                                  [24.01.2024 14:30.01.563] [LOG]   Starting node helper for: calendar
                                  [24.01.2024 14:30.01.564] [LOG]   Connecting socket for: newsfeed
                                  [24.01.2024 14:30.01.565] [LOG]   Starting node helper for: newsfeed
                                  [24.01.2024 14:30.01.566] [LOG]   Sockets connected & modules started ...
                                  [24.01.2024 14:30.02.129] [LOG]   Launching application.
                                    Manu85 @sdetweil
                                    @sdetweil then I have lines with “calendar” but there are my https addresses: from the iPhone, maybe I shouldn’t put them on the forum?
                                      sdetweil @Manu85
                                      @Manu85 correct or mass change them in a text editor first…
                                      I don’t know anything more about the module itself. I used a bad apikey and it produced an error in the data you are looking at now
                                      I used a good key, and the module displayed using the sample config. I just used my API key. no other change
                                        Manu85 @sdetweil
                                        and There you go ! if you want I can give you my key in a private message
                                        [24.01.2024 14:30.03.091] [LOG]   Create new calendarfetcher for url: http://p31        -caldav.icloud.com/published/2/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx        xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx - Interval: 300000
                                        [24.01.2024 14:30.03.239] [LOG]   Use existing calendarfetcher for url: http://p        31-caldav.icloud.com/published/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx        xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:30.03.242] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                        [24.01.2024 14:30.03.304] [LOG]   Use existing calendarfetcher for url: http://p        31-caldav.icloud.com/published/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx        xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:30.03.305] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                        [24.01.2024 14:30.03.332] [LOG]   Use existing calendarfetcher for url: http://p        31-caldav.icloud.com/published/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx        xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:30.03.334] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                        [24.01.2024 14:30.03.363] [LOG]   Use existing calendarfetcher for url: http://p        31-caldav.icloud.com/published/2/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx        xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:30.03.364] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                        [24.01.2024 14:30.03.454] [LOG]   <Buffer 33 38 2e 36 0a>
                                        [24.01.2024 14:30.03.487] [LOG]   <Buffer 33 38 2e 36 0a>
                                        [24.01.2024 14:30.03.780] [LOG]   <Buffer 33 39 2e 32 0a>
                                        [24.01.2024 14:30.03.786] [LOG]   <Buffer 33 38 2e 36 0a>
                                        [1910:0124/143004.059795:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to        errors during initialization
                                        [24.01.2024 14:30.04.733] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:30.05.129] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:30.05.511] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [1960:0124/143005.738916:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extens        ion not supported.
                                        [24.01.2024 14:30.06.010] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:30.06.422] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [1915:0124/143006.476783:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                                        [24.01.2024 14:30.08.902] [LOG]   Create new calendarfetcher for url: http://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12OfzlWCbJPUrEhN49IHC1yeFEfqRieBnpAKrz592KXN_zwHa5Dxxxxxxxxxxxxxxxxxxxxxx - Interval: 300000
                                        [24.01.2024 14:30.08.913] [LOG]   Create new calendarfetcher for url: http://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12Oezk-6Zk6G2LUSDrRp2bRFAAjCfbogwDyaNVcEuy93NRhkNwxxxxxxxxxxxxxxxxxxxxxx - Interval: 300000
                                        [24.01.2024 14:30.08.932] [LOG]   Create new calendarfetcher for url: http://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12OfgZxxxxxxxxxxxxxxxxxxxxxx - Interval: 300000
                                        [24.01.2024 14:30.08.949] [LOG]   Create new calendarfetcher for url: http://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12OePs9rEDFlPWmcxSIoYt08bLzn0pT5tIY8RoNmxxxxxxxxxxxxxxxxxxxxxxxxxxx - Interval: 300000
                                        [24.01.2024 14:30.08.954] [LOG]   Create new calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx- Interval: 300000
                                        [24.01.2024 14:30.09.043] [LOG]   Create new newsfetcher for url: https://www.lepoint.fr/rss.xml - Interval: 300000
                                        [24.01.2024 14:30.09.060] [LOG]   Create new newsfetcher for url: https://www.sudouest.fr/sport/rugby/top14/rss.xml - Interval: 300000
                                        [24.01.2024 14:30.09.500] [LOG]   <Buffer 34 30 2e 38 0a>
                                        [24.01.2024 14:30.09.528] [LOG]   <Buffer 34 30 2e 38 0a>
                                        [24.01.2024 14:30.09.883] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                        [24.01.2024 14:30.10.539] [INFO]  Calendar-Fetcher: Broadcasting 30 events.
                                        [24.01.2024 14:30.10.692] [INFO]  Calendar-Fetcher: Broadcasting 52 events.
                                        [24.01.2024 14:30.10.853] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:30.11.062] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:30.11.361] [LOG]   node received
                                        [24.01.2024 14:30.11.366] [ERROR] Whoops! There was an uncaught exception...
                                        [24.01.2024 14:30.11.381] [ERROR] ReferenceError: fetch is not defined
                                            at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-OneCallWeather/node_helper.js:55:9)
                                            at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:107:11)
                                            at Socket.emit (node:events:513:28)
                                            at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
                                            at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:703:39
                                            at process.processTicksAndRejections (node:internal/process/task_queues:78:11)
                                        [24.01.2024 14:30.11.385] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        [24.01.2024 14:30.11.387] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        [24.01.2024 14:30.15.968] [INFO]  Calendar-Fetcher: Broadcasting 53 events.
                                        [24.01.2024 14:30.16.101] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                        [24.01.2024 14:31.09.080] [LOG]   <Buffer 34 34 2e 30 0a>
                                        [24.01.2024 14:31.09.817] [LOG]   <Buffer 34 34 2e 30 0a>
                                        [24.01.2024 14:32.09.327] [LOG]   <Buffer 34 35 2e 36 0a>
                                        [24.01.2024 14:32.10.533] [LOG]   <Buffer 34 36 2e 32 0a>
                                        [24.01.2024 14:33.09.083] [LOG]   <Buffer 34 36 2e 37 0a>
                                        [24.01.2024 14:33.10.985] [LOG]   <Buffer 34 37 2e 32 0a>
                                        [24.01.2024 14:33.14.210] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA1xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:33.14.211] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:33.14.235] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:33.14.238] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:33.14.249] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:33.14.251] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:33.14.259] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:33.14.261] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:33.14.269] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6ixxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:33.14.272] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:33.15.372] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:33.15.917] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:33.16.540] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:33.17.077] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:33.17.738] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:34.09.353] [LOG]   <Buffer 34 37 2e 38 0a>
                                        [24.01.2024 14:34.11.524] [LOG]   <Buffer 34 38 2e 33 0a>
                                        [24.01.2024 14:35.08.106] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:35.08.107] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:35.08.116] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:35.08.117] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:35.08.121] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:35.08.122] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:35.08.166] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:35.08.167] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:35.08.173] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:35.08.187] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:35.09.261] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:35.09.457] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:35.09.473] [LOG]   <Buffer 34 38 2e 39 0a>
                                        [24.01.2024 14:35.09.567] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:35.09.722] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:35.09.965] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:35.10.211] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                        [24.01.2024 14:35.11.303] [INFO]  Calendar-Fetcher: Broadcasting 30 events.
                                        [24.01.2024 14:35.11.793] [INFO]  Calendar-Fetcher: Broadcasting 52 events.
                                        [24.01.2024 14:35.12.334] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:35.12.363] [LOG]   <Buffer 34 39 2e 34 0a>
                                        [24.01.2024 14:35.16.283] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                        [24.01.2024 14:35.20.779] [INFO]  Calendar-Fetcher: Broadcasting 53 events.
                                        [24.01.2024 14:36.09.256] [LOG]   <Buffer 34 38 2e 39 0a>
                                        [24.01.2024 14:36.12.996] [LOG]   <Buffer 34 39 2e 39 0a>
                                        [24.01.2024 14:37.09.270] [LOG]   <Buffer 34 39 2e 34 0a>
                                        [24.01.2024 14:37.13.489] [LOG]   <Buffer 34 39 2e 39 0a>
                                        [24.01.2024 14:38.09.169] [LOG]   <Buffer 35 30 2e 35 0a>
                                        [24.01.2024 14:38.13.988] [LOG]   <Buffer 34 39 2e 39 0a>
                                        [24.01.2024 14:38.14.452] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:38.14.457] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:38.14.470] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:38.14.471] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:38.14.485] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:38.14.489] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:38.14.500] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:38.14.501] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:38.14.516] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:38.14.519] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:38.15.574] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:38.16.265] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:38.16.801] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:38.17.287] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:38.17.803] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:39.09.340] [LOG]   <Buffer 34 39 2e 34 0a>
                                        [24.01.2024 14:39.14.471] [LOG]   <Buffer 34 39 2e 34 0a>
                                        [24.01.2024 14:40.08.101] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:40.08.102] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:40.08.120] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:40.08.125] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:40.08.133] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:40.08.137] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:40.08.143] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:40.08.144] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:40.08.147] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:40.08.151] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:40.08.771] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:40.09.154] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:40.09.337] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:40.09.459] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:40.09.572] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:40.09.592] [LOG]   <Buffer 34 39 2e 34 0a>
                                        [24.01.2024 14:40.10.516] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                        [24.01.2024 14:40.11.785] [INFO]  Calendar-Fetcher: Broadcasting 30 events.
                                        [24.01.2024 14:40.12.339] [INFO]  Calendar-Fetcher: Broadcasting 52 events.
                                        [24.01.2024 14:40.12.774] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:40.15.393] [LOG]   <Buffer 34 39 2e 34 0a>
                                        [24.01.2024 14:40.16.443] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                        [24.01.2024 14:40.24.801] [INFO]  Calendar-Fetcher: Broadcasting 53 events.
                                        [24.01.2024 14:41.09.525] [LOG]   <Buffer 34 38 2e 33 0a>
                                        [24.01.2024 14:41.16.031] [LOG]   <Buffer 34 38 2e 33 0a>
                                        [24.01.2024 14:42.09.212] [LOG]   <Buffer 34 38 2e 33 0a>
                                        [24.01.2024 14:42.16.668] [LOG]   <Buffer 34 38 2e 33 0a>
                                        [24.01.2024 14:43.09.112] [LOG]   <Buffer 34 37 2e 32 0a>
                                        [24.01.2024 14:43.14.619] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:43.14.619] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:43.14.624] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:43.14.625] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:43.14.633] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:43.14.634] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:43.14.644] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:43.14.645] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:43.14.656] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:43.14.658] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:43.15.536] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:43.15.948] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:43.16.746] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:43.17.153] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:43.17.757] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:43.18.370] [LOG]   <Buffer 34 37 2e 38 0a>
                                        [24.01.2024 14:44.09.025] [LOG]   <Buffer 34 36 2e 32 0a>
                                        [24.01.2024 14:44.17.658] [LOG]   <Buffer 34 35 2e 31 0a>
                                        [24.01.2024 14:45.08.100] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:45.08.101] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:45.08.120] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:45.08.121] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:45.08.125] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:45.08.126] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:45.08.172] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:45.08.172] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:45.08.200] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxxx
                                        [24.01.2024 14:45.08.201] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:45.08.804] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:45.08.904] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:45.09.005] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:45.09.210] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:45.09.304] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                        [24.01.2024 14:45.09.310] [LOG]   <Buffer 34 35 2e 31 0a>
                                        [24.01.2024 14:45.10.766] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                        [24.01.2024 14:45.12.577] [INFO]  Calendar-Fetcher: Broadcasting 30 events.
                                        [24.01.2024 14:45.13.104] [INFO]  Calendar-Fetcher: Broadcasting 52 events.
                                        [24.01.2024 14:45.13.296] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                        [24.01.2024 14:45.16.606] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                        [24.01.2024 14:45.18.461] [LOG]   <Buffer 34 35 2e 31 0a>
                                        [24.01.2024 14:45.28.393] [INFO]  Calendar-Fetcher: Broadcasting 53 events.
                                        [24.01.2024 14:46.09.312] [LOG]   <Buffer 34 35 2e 31 0a>
                                        [24.01.2024 14:46.19.414] [LOG]   <Buffer 34 35 2e 36 0a>
                                        [24.01.2024 14:47.09.181] [LOG]   <Buffer 34 37 2e 32 0a>
                                        [24.01.2024 14:47.20.033] [LOG]   <Buffer 34 37 2e 32 0a>
                                        [24.01.2024 14:48.09.102] [LOG]   <Buffer 34 37 2e 32 0a>
                                        [24.01.2024 14:48.15.000] [LOG]   Use existing calendarfetcher for url: http://p31-
                                          sdetweil @Manu85
                                          @Manu85 yep…
                                          yes the module has been updated since v 2.25,
                                          (it should have had a version check!, rather than fail like this)
                                          to use the internal fetch function instead of an external library.
                                          and u are on 2.23
                                          use my upgrade script to get to latest 2.26
                                            Manu85 @sdetweil
                                            @sdetweil sorry for not responding to you more quickly, but I had an appointment with the doctor, is it the weather module that doesn’t have the right version? you ask me to use your script but I don’t know what it is, sorry for my ignorance
                                            • 10
                                            • 11
                                            • 15
                                            • 16
                                            • 9 / 16
