    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 the page says v3 api, and 1000 calls per day free
      M 1 Reply Last reply
        Manu85 @sdetweil
        @sdetweil Yes I went to this page, but then they ask you for your bank card!!!
          sdetweil @Manu85
          @Manu85 yes, they will charge you IF you go over the 1000/day… nothing is free anymore… you MUST provide a valid card, or the api key is not functional
          M 2 Replies Last reply
            Manu85 @sdetweil
            @sdetweil Thank you for your answer and you are right everything is charged today, fortunately there are still sites and people like you to share for FREE what they know
              sdetweil @Manu85
              @Manu85 yes, but I don’t generate any pretty user interfaces!! no icons or graphs…lol
                Manu85 @sdetweil
                @sdetweil Yes but it’s thanks to people like you that there is still communication without banking intermediary to build projects… I would therefore stay with my version 2.5 which is free while waiting for a developer to find a solution:- ) what bothers me is that the weather forecast with pretty icons etc. there are some on smartphones, cars, television, internet etc. and all this is free, as soon as you want to do something different you have to PAY :-(
                  sdetweil @Manu85
                  @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                  the problem is that the provider (openweathermap), is only providing v3 api keys now for the OneCall api used by the module.
                  SO… there is nothing the developer can do to get around that.
                  openweathermap is no longer issuing 2.5 api keys
                    manu85340 @sdetweil
                    @sdetweil I found a post from March 2023 where we talk about you on the same subject 😉
                      sdetweil @manu85340
                      @manu85340 yes, this module is already using all that
                          apiVersion: "3.0",
                       `https://api.openweathermap.org/data/${config.apiVersion}/onecall` +
                        Manu85 @sdetweil
                        @sdetweil I subscribed to onecall and I just tested this morning and I still have the same “loading” thing, in my config.js I put the following things:
                        module: "MMM-OneCallWeather",
                             position: "top_right", // This can be any of the regions.
                             // Best results in bottom_bar region due to horizontal default layout and icon sizes.
                               latitude: "46.561180", // Longitude from https://www.latlong.net/
                               longitude: "-1.782440", // Longitude from https://www.latlong.net/ - is West + is East of London
                               apikey: "MY NEW API KEY V3.0" // openweathermap.org API key.
                        in MMM-OneCallWeather.js I have this:
                        letdata;
                        Module.register("MMM-OneCallWeather", {
                           // Default module config.
                           defaults: {
                             latitude: true,
                             longitude: true,
                             apikey: "",
                             apiVersion: "3.0",
                             units: config.units,
                             layout: "vertical", // default
                             showRainAmount: false,
                             showWind: true,
                             showWindDirection: true,
                             showFeelsLike: true,
                             tempUnits: "c",
                             windunits: "mph",
                             useBeaufortInCurrent: false,
                             initialLoadDelay: 2500, // 2.5 seconds delay. This delay is used to keep the OpenWeather API happy.
                             updateInterval: 10 * 60 * 1000, // every 10 minutes
                             animationSpeed: 1000,
                             updateFadeSpeed: 500,
                             lang:config.language,
                             language: config.language,
                             requestDelay: 0,
                        I haven’t touched anything else, can you help me please?
                          sdetweil @Manu85
                          @Manu85 show me the output of npm start
                          if you use pm2 to launch, then
                          pm2 logs --lines=50
                            Manu85 @sdetweil
                            @sdetweil Is that what we need to do? I ran the npm start command in putty
                            pi@MagicMirror:~ $ npm start
                            npm ERR! code ENOENT
                            npm ERR! syscall open
                            npm ERR! errno -2
                            npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
                            npm ERR! enoent This is related to npm not being able to find a file.
                            npm ERR! enoent
                            npm ERR!     /home/pi/.npm/_logs/2024-01-24T12_40_06_083Z-debug.log
                              sdetweil @Manu85
                              @Manu85 need to be in the MagicMirror folder
                                Manu85 @sdetweil
                                @sdetweil I did that, I hope it’s ok, however the cursor remains stuck at the bottom left and does not return to: ```
                                pi@MagicMirror:~/MagicMirror $
                                pi@MagicMirror:~/MagicMirror $ npm start
                                > magicmirror@2.23.0 start /home/pi/MagicMirror
                                [24.01.2024 14:15.19.980] [LOG]   Starting MagicMirror: v2.23.0
                                [24.01.2024 14:15.19.999] [LOG]   Loading config ...
                                [24.01.2024 14:15.20.009] [DEBUG] config template file not exists, no envsubst
                                [24.01.2024 14:15.20.024] [LOG]   Loading module helpers ...
                                [24.01.2024 14:15.20.031] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Logging/MMM-Logging.js found for module: MMM-Logging.
                                [24.01.2024 14:15.20.034] [LOG]   No helper found for module: MMM-Logging.
                                [24.01.2024 14:15.20.036] [LOG]   No helper found for module: clock.
                                [24.01.2024 14:15.20.075] [LOG]   Initializing new module helper ...
                                [24.01.2024 14:15.20.079] [LOG]   Module helper loaded: MMM-PiTemp
                                [24.01.2024 14:15.20.153] [LOG]   Initializing new module helper ...
                                [24.01.2024 14:15.20.155] [LOG]   Module helper loaded: MMM-OneCallWeather
                                [24.01.2024 14:15.20.161] [LOG]   Initializing new module helper ...
                                [24.01.2024 14:15.20.163] [LOG]   Module helper loaded: MMM-DHT
                                [24.01.2024 14:15.20.681] [LOG]   Initializing new module helper ...
                                [24.01.2024 14:15.20.682] [LOG]   Module helper loaded: calendar
                                [24.01.2024 14:15.20.683] [LOG]   No helper found for module: MMM-SmartWebDisplay.
                                [24.01.2024 14:15.20.685] [LOG]   No helper found for module: MMM-ISS-Live.
                                [24.01.2024 14:15.20.746] [LOG]   Initializing new module helper ...
                                [24.01.2024 14:15.20.747] [LOG]   Module helper loaded: newsfeed
                                [24.01.2024 14:15.20.748] [LOG]   All module helpers loaded.
                                [24.01.2024 14:15.20.777] [LOG]   Starting server on port 8080 ...
                                [24.01.2024 14:15.20.791] [WARN]  You're using a full whitelist configuration to allow for all IPs
                                [24.01.2024 14:15.20.818] [ERROR] Whoops! There was an uncaught exception...
                                [24.01.2024 14:15.20.834] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                    at Server.setupListenHandle [as _listen2] (node:net:1432:16)
                                    at listenInCluster (node:net:1480:12)
                                    at doListen (node:net:1629:7)
                                    at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
                                  code: 'EADDRINUSE',
                                  errno: -98,
                                  syscall: 'listen',
                                  address: '0.0.0.0',
                                  port: 8080
                                [24.01.2024 14:15.20.834] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                [24.01.2024 14:15.20.835] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                [24.01.2024 14:15.21.545] [LOG]   Launching application.
                                [1330:0124/141522.949654:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                                [1353:0124/141523.177443:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                                code_text
                                  sdetweil @Manu85
                                  @Manu85 well it’s running…so no return to command line, ctrl-c to stop
                                  but, the message here says you didn’t stop the one running by pm2, do
                                  pm2 stop all
                                    Manu85 @sdetweil
                                    @sdetweil now I have this
                                    pi@MagicMirror:~ $ cd  ~/MagicMirror/
                                    pi@MagicMirror:~/MagicMirror $ pm2 stop all
                                    [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                                    [PM2] [mm](0) ✓
                                    │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                                    │ 0  │ mm                 │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                                      sdetweil @Manu85
                                      @Manu85 yes, now
                                      npm start
                                        Manu85 @sdetweil
                                        @sdetweil ok it’s done but I have the impression that the page adds new lines every 20 seconds, I’ll give you a screenshot, please tell me what you need or what to do please
                                          sdetweil @Manu85
                                          @Manu85 I was looking for the error from the calendar module. it would have been right near the top
                                            Manu85 @sdetweil
                                            @sdetweil towards this place?
                                            [24.01.2024 14:30.00.848] [LOG]   Starting MagicMirror: v2.23.0
                                            [24.01.2024 14:30.00.868] [LOG]   Loading config ...
                                            [24.01.2024 14:30.00.876] [DEBUG] config template file not exists, no envsubst
                                            [24.01.2024 14:30.00.889] [LOG]   Loading module helpers ...
                                            [24.01.2024 14:30.00.892] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Logg        ing/MMM-Logging.js found for module: MMM-Logging.
                                            [24.01.2024 14:30.00.894] [LOG]   No helper found for module: MMM-Logging.
                                            [24.01.2024 14:30.00.895] [LOG]   No helper found for module: clock.
                                            [24.01.2024 14:30.00.927] [LOG]   Initializing new module helper ...
                                            [24.01.2024 14:30.00.929] [LOG]   Module helper loaded: MMM-PiTemp
                                            [24.01.2024 14:30.00.983] [LOG]   Initializing new module helper ...
                                            [24.01.2024 14:30.00.985] [LOG]   Module helper loaded: MMM-OneCallWeather
                                            [24.01.2024 14:30.00.990] [LOG]   Initializing new module helper ...
                                            [24.01.2024 14:30.00.991] [LOG]   Module helper loaded: MMM-DHT
                                            [24.01.2024 14:30.01.443] [LOG]   Initializing new module helper ...
                                            [24.01.2024 14:30.01.444] [LOG]   Module helper loaded: calendar
                                            [24.01.2024 14:30.01.445] [LOG]   No helper found for module: MMM-SmartWebDispla        y.
                                            [24.01.2024 14:30.01.447] [LOG]   No helper found for module: MMM-ISS-Live.
                                            [24.01.2024 14:30.01.496] [LOG]   Initializing new module helper ...
                                            [24.01.2024 14:30.01.496] [LOG]   Module helper loaded: newsfeed
                                            [24.01.2024 14:30.01.497] [LOG]   All module helpers loaded.
                                            [24.01.2024 14:30.01.520] [LOG]   Starting server on port 8080 ...
                                            [24.01.2024 14:30.01.533] [WARN]  You're using a full whitelist configuration to        allow for all IPs
                                            [24.01.2024 14:30.01.554] [LOG]   Server started ...
                                            [24.01.2024 14:30.01.556] [LOG]   Connecting socket for: MMM-PiTemp
                                            [24.01.2024 14:30.01.558] [LOG]   Starting module helper: MMM-PiTemp
                                            [24.01.2024 14:30.01.559] [LOG]   Connecting socket for: MMM-OneCallWeather
                                            [24.01.2024 14:30.01.561] [LOG]   Connecting socket for: MMM-DHT
                                            [24.01.2024 14:30.01.561] [LOG]   Starting module helper: MMM-DHT
                                            [24.01.2024 14:30.01.562] [LOG]   Connecting socket for: calendar
                                            [24.01.2024 14:30.01.563] [LOG]   Starting node helper for: calendar
                                            [24.01.2024 14:30.01.564] [LOG]   Connecting socket for: newsfeed
                                            [24.01.2024 14:30.01.565] [LOG]   Starting node helper for: newsfeed
                                            [24.01.2024 14:30.01.566] [LOG]   Sockets connected & modules started ...
                                            [24.01.2024 14:30.02.129] [LOG]   Launching application.
                                            • 10
                                            • 15
                                            • 16
                                            • 8 / 16
