    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @manu85340
      @manu85340 yes, this module is already using all that
          apiVersion: "3.0",
       `https://api.openweathermap.org/data/${config.apiVersion}/onecall` +
        Manu85 @sdetweil
        @sdetweil I subscribed to onecall and I just tested this morning and I still have the same “loading” thing, in my config.js I put the following things:
        module: "MMM-OneCallWeather",
             position: "top_right", // This can be any of the regions.
             // Best results in bottom_bar region due to horizontal default layout and icon sizes.
               latitude: "46.561180", // Longitude from https://www.latlong.net/
               longitude: "-1.782440", // Longitude from https://www.latlong.net/ - is West + is East of London
               apikey: "MY NEW API KEY V3.0" // openweathermap.org API key.
        in MMM-OneCallWeather.js I have this:
        letdata;
        Module.register("MMM-OneCallWeather", {
           // Default module config.
           defaults: {
             latitude: true,
             longitude: true,
             apikey: "",
             apiVersion: "3.0",
             units: config.units,
             layout: "vertical", // default
             showRainAmount: false,
             showWind: true,
             showWindDirection: true,
             showFeelsLike: true,
             tempUnits: "c",
             windunits: "mph",
             useBeaufortInCurrent: false,
             initialLoadDelay: 2500, // 2.5 seconds delay. This delay is used to keep the OpenWeather API happy.
             updateInterval: 10 * 60 * 1000, // every 10 minutes
             animationSpeed: 1000,
             updateFadeSpeed: 500,
             lang:config.language,
             language: config.language,
             requestDelay: 0,
        I haven’t touched anything else, can you help me please?
          sdetweil @Manu85
          @Manu85 show me the output of npm start
          if you use pm2 to launch, then
          pm2 logs --lines=50
            Manu85 @sdetweil
            @sdetweil Is that what we need to do? I ran the npm start command in putty
            pi@MagicMirror:~ $ npm start
            npm ERR! code ENOENT
            npm ERR! syscall open
            npm ERR! errno -2
            npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
            npm ERR! enoent This is related to npm not being able to find a file.
            npm ERR! enoent
            npm ERR!     /home/pi/.npm/_logs/2024-01-24T12_40_06_083Z-debug.log
              sdetweil @Manu85
              @Manu85 need to be in the MagicMirror folder
                Manu85 @sdetweil
                @sdetweil I did that, I hope it’s ok, however the cursor remains stuck at the bottom left and does not return to: ```
                pi@MagicMirror:~/MagicMirror $
                pi@MagicMirror:~/MagicMirror $ npm start
                > magicmirror@2.23.0 start /home/pi/MagicMirror
                [24.01.2024 14:15.19.980] [LOG]   Starting MagicMirror: v2.23.0
                [24.01.2024 14:15.19.999] [LOG]   Loading config ...
                [24.01.2024 14:15.20.009] [DEBUG] config template file not exists, no envsubst
                [24.01.2024 14:15.20.024] [LOG]   Loading module helpers ...
                [24.01.2024 14:15.20.031] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Logging/MMM-Logging.js found for module: MMM-Logging.
                [24.01.2024 14:15.20.034] [LOG]   No helper found for module: MMM-Logging.
                [24.01.2024 14:15.20.036] [LOG]   No helper found for module: clock.
                [24.01.2024 14:15.20.075] [LOG]   Initializing new module helper ...
                [24.01.2024 14:15.20.079] [LOG]   Module helper loaded: MMM-PiTemp
                [24.01.2024 14:15.20.153] [LOG]   Initializing new module helper ...
                [24.01.2024 14:15.20.155] [LOG]   Module helper loaded: MMM-OneCallWeather
                [24.01.2024 14:15.20.161] [LOG]   Initializing new module helper ...
                [24.01.2024 14:15.20.163] [LOG]   Module helper loaded: MMM-DHT
                [24.01.2024 14:15.20.681] [LOG]   Initializing new module helper ...
                [24.01.2024 14:15.20.682] [LOG]   Module helper loaded: calendar
                [24.01.2024 14:15.20.683] [LOG]   No helper found for module: MMM-SmartWebDisplay.
                [24.01.2024 14:15.20.685] [LOG]   No helper found for module: MMM-ISS-Live.
                [24.01.2024 14:15.20.746] [LOG]   Initializing new module helper ...
                [24.01.2024 14:15.20.747] [LOG]   Module helper loaded: newsfeed
                [24.01.2024 14:15.20.748] [LOG]   All module helpers loaded.
                [24.01.2024 14:15.20.777] [LOG]   Starting server on port 8080 ...
                [24.01.2024 14:15.20.791] [WARN]  You're using a full whitelist configuration to allow for all IPs
                [24.01.2024 14:15.20.818] [ERROR] Whoops! There was an uncaught exception...
                [24.01.2024 14:15.20.834] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                    at Server.setupListenHandle [as _listen2] (node:net:1432:16)
                    at listenInCluster (node:net:1480:12)
                    at doListen (node:net:1629:7)
                    at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
                  code: 'EADDRINUSE',
                  errno: -98,
                  syscall: 'listen',
                  address: '0.0.0.0',
                  port: 8080
                [24.01.2024 14:15.20.834] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                [24.01.2024 14:15.20.835] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                [24.01.2024 14:15.21.545] [LOG]   Launching application.
                [1330:0124/141522.949654:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
                [1353:0124/141523.177443:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
                code_text
                  sdetweil @Manu85
                  @Manu85 well it’s running…so no return to command line, ctrl-c to stop
                  but, the message here says you didn’t stop the one running by pm2, do
                  pm2 stop all
                    Manu85 @sdetweil
                    @sdetweil now I have this
                    pi@MagicMirror:~ $ cd  ~/MagicMirror/
                    pi@MagicMirror:~/MagicMirror $ pm2 stop all
                    [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                    [PM2] [mm](0) ✓
                    │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                    │ 0  │ mm                 │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                      sdetweil @Manu85
                      @Manu85 yes, now
                      npm start
                        Manu85 @sdetweil
                        @sdetweil ok it’s done but I have the impression that the page adds new lines every 20 seconds, I’ll give you a screenshot, please tell me what you need or what to do please
                          sdetweil @Manu85
                          @Manu85 I was looking for the error from the calendar module. it would have been right near the top
                            Manu85 @sdetweil
                            @sdetweil towards this place?
                            [24.01.2024 14:30.00.848] [LOG]   Starting MagicMirror: v2.23.0
                            [24.01.2024 14:30.00.868] [LOG]   Loading config ...
                            [24.01.2024 14:30.00.876] [DEBUG] config template file not exists, no envsubst
                            [24.01.2024 14:30.00.889] [LOG]   Loading module helpers ...
                            [24.01.2024 14:30.00.892] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Logg        ing/MMM-Logging.js found for module: MMM-Logging.
                            [24.01.2024 14:30.00.894] [LOG]   No helper found for module: MMM-Logging.
                            [24.01.2024 14:30.00.895] [LOG]   No helper found for module: clock.
                            [24.01.2024 14:30.00.927] [LOG]   Initializing new module helper ...
                            [24.01.2024 14:30.00.929] [LOG]   Module helper loaded: MMM-PiTemp
                            [24.01.2024 14:30.00.983] [LOG]   Initializing new module helper ...
                            [24.01.2024 14:30.00.985] [LOG]   Module helper loaded: MMM-OneCallWeather
                            [24.01.2024 14:30.00.990] [LOG]   Initializing new module helper ...
                            [24.01.2024 14:30.00.991] [LOG]   Module helper loaded: MMM-DHT
                            [24.01.2024 14:30.01.443] [LOG]   Initializing new module helper ...
                            [24.01.2024 14:30.01.444] [LOG]   Module helper loaded: calendar
                            [24.01.2024 14:30.01.445] [LOG]   No helper found for module: MMM-SmartWebDispla        y.
                            [24.01.2024 14:30.01.447] [LOG]   No helper found for module: MMM-ISS-Live.
                            [24.01.2024 14:30.01.496] [LOG]   Initializing new module helper ...
                            [24.01.2024 14:30.01.496] [LOG]   Module helper loaded: newsfeed
                            [24.01.2024 14:30.01.497] [LOG]   All module helpers loaded.
                            [24.01.2024 14:30.01.520] [LOG]   Starting server on port 8080 ...
                            [24.01.2024 14:30.01.533] [WARN]  You're using a full whitelist configuration to        allow for all IPs
                            [24.01.2024 14:30.01.554] [LOG]   Server started ...
                            [24.01.2024 14:30.01.556] [LOG]   Connecting socket for: MMM-PiTemp
                            [24.01.2024 14:30.01.558] [LOG]   Starting module helper: MMM-PiTemp
                            [24.01.2024 14:30.01.559] [LOG]   Connecting socket for: MMM-OneCallWeather
                            [24.01.2024 14:30.01.561] [LOG]   Connecting socket for: MMM-DHT
                            [24.01.2024 14:30.01.561] [LOG]   Starting module helper: MMM-DHT
                            [24.01.2024 14:30.01.562] [LOG]   Connecting socket for: calendar
                            [24.01.2024 14:30.01.563] [LOG]   Starting node helper for: calendar
                            [24.01.2024 14:30.01.564] [LOG]   Connecting socket for: newsfeed
                            [24.01.2024 14:30.01.565] [LOG]   Starting node helper for: newsfeed
                            [24.01.2024 14:30.01.566] [LOG]   Sockets connected & modules started ...
                            [24.01.2024 14:30.02.129] [LOG]   Launching application.
                              Manu85 @sdetweil
                              @sdetweil then I have lines with “calendar” but there are my https addresses: from the iPhone, maybe I shouldn’t put them on the forum?
                                sdetweil @Manu85
                                @Manu85 correct or mass change them in a text editor first…
                                I don’t know anything more about the module itself. I used a bad apikey and it produced an error in the data you are looking at now
                                I used a good key, and the module displayed using the sample config. I just used my API key. no other change
                                  Manu85 @sdetweil
                                  and There you go ! if you want I can give you my key in a private message
                                  [24.01.2024 14:30.03.091] [LOG]   Create new calendarfetcher for url: http://p31        -caldav.icloud.com/published/2/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx        xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx - Interval: 300000
                                  [24.01.2024 14:30.03.239] [LOG]   Use existing calendarfetcher for url: http://p        31-caldav.icloud.com/published/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx        xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:30.03.242] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                  [24.01.2024 14:30.03.304] [LOG]   Use existing calendarfetcher for url: http://p        31-caldav.icloud.com/published/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx        xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:30.03.305] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                  [24.01.2024 14:30.03.332] [LOG]   Use existing calendarfetcher for url: http://p        31-caldav.icloud.com/published/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx        xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:30.03.334] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                  [24.01.2024 14:30.03.363] [LOG]   Use existing calendarfetcher for url: http://p        31-caldav.icloud.com/published/2/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx        xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:30.03.364] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                  [24.01.2024 14:30.03.454] [LOG]   <Buffer 33 38 2e 36 0a>
                                  [24.01.2024 14:30.03.487] [LOG]   <Buffer 33 38 2e 36 0a>
                                  [24.01.2024 14:30.03.780] [LOG]   <Buffer 33 39 2e 32 0a>
                                  [24.01.2024 14:30.03.786] [LOG]   <Buffer 33 38 2e 36 0a>
                                  [1910:0124/143004.059795:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to        errors during initialization
                                  [24.01.2024 14:30.04.733] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:30.05.129] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:30.05.511] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [1960:0124/143005.738916:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extens        ion not supported.
                                  [24.01.2024 14:30.06.010] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:30.06.422] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [1915:0124/143006.476783:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                                  [24.01.2024 14:30.08.902] [LOG]   Create new calendarfetcher for url: http://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12OfzlWCbJPUrEhN49IHC1yeFEfqRieBnpAKrz592KXN_zwHa5Dxxxxxxxxxxxxxxxxxxxxxx - Interval: 300000
                                  [24.01.2024 14:30.08.913] [LOG]   Create new calendarfetcher for url: http://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12Oezk-6Zk6G2LUSDrRp2bRFAAjCfbogwDyaNVcEuy93NRhkNwxxxxxxxxxxxxxxxxxxxxxx - Interval: 300000
                                  [24.01.2024 14:30.08.932] [LOG]   Create new calendarfetcher for url: http://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12OfgZxxxxxxxxxxxxxxxxxxxxxx - Interval: 300000
                                  [24.01.2024 14:30.08.949] [LOG]   Create new calendarfetcher for url: http://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12OePs9rEDFlPWmcxSIoYt08bLzn0pT5tIY8RoNmxxxxxxxxxxxxxxxxxxxxxxxxxxx - Interval: 300000
                                  [24.01.2024 14:30.08.954] [LOG]   Create new calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx- Interval: 300000
                                  [24.01.2024 14:30.09.043] [LOG]   Create new newsfetcher for url: https://www.lepoint.fr/rss.xml - Interval: 300000
                                  [24.01.2024 14:30.09.060] [LOG]   Create new newsfetcher for url: https://www.sudouest.fr/sport/rugby/top14/rss.xml - Interval: 300000
                                  [24.01.2024 14:30.09.500] [LOG]   <Buffer 34 30 2e 38 0a>
                                  [24.01.2024 14:30.09.528] [LOG]   <Buffer 34 30 2e 38 0a>
                                  [24.01.2024 14:30.09.883] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                  [24.01.2024 14:30.10.539] [INFO]  Calendar-Fetcher: Broadcasting 30 events.
                                  [24.01.2024 14:30.10.692] [INFO]  Calendar-Fetcher: Broadcasting 52 events.
                                  [24.01.2024 14:30.10.853] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:30.11.062] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:30.11.361] [LOG]   node received
                                  [24.01.2024 14:30.11.366] [ERROR] Whoops! There was an uncaught exception...
                                  [24.01.2024 14:30.11.381] [ERROR] ReferenceError: fetch is not defined
                                      at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-OneCallWeather/node_helper.js:55:9)
                                      at Socket.<anonymous> (/home/pi/MagicMirror/js/node_helper.js:107:11)
                                      at Socket.emit (node:events:513:28)
                                      at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
                                      at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:703:39
                                      at process.processTicksAndRejections (node:internal/process/task_queues:78:11)
                                  [24.01.2024 14:30.11.385] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  [24.01.2024 14:30.11.387] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                  [24.01.2024 14:30.15.968] [INFO]  Calendar-Fetcher: Broadcasting 53 events.
                                  [24.01.2024 14:30.16.101] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                  [24.01.2024 14:31.09.080] [LOG]   <Buffer 34 34 2e 30 0a>
                                  [24.01.2024 14:31.09.817] [LOG]   <Buffer 34 34 2e 30 0a>
                                  [24.01.2024 14:32.09.327] [LOG]   <Buffer 34 35 2e 36 0a>
                                  [24.01.2024 14:32.10.533] [LOG]   <Buffer 34 36 2e 32 0a>
                                  [24.01.2024 14:33.09.083] [LOG]   <Buffer 34 36 2e 37 0a>
                                  [24.01.2024 14:33.10.985] [LOG]   <Buffer 34 37 2e 32 0a>
                                  [24.01.2024 14:33.14.210] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA1xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:33.14.211] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:33.14.235] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:33.14.238] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:33.14.249] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:33.14.251] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:33.14.259] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:33.14.261] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:33.14.269] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6ixxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:33.14.272] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:33.15.372] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:33.15.917] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:33.16.540] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:33.17.077] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:33.17.738] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:34.09.353] [LOG]   <Buffer 34 37 2e 38 0a>
                                  [24.01.2024 14:34.11.524] [LOG]   <Buffer 34 38 2e 33 0a>
                                  [24.01.2024 14:35.08.106] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:35.08.107] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:35.08.116] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:35.08.117] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:35.08.121] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:35.08.122] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:35.08.166] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:35.08.167] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:35.08.173] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:35.08.187] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:35.09.261] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:35.09.457] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:35.09.473] [LOG]   <Buffer 34 38 2e 39 0a>
                                  [24.01.2024 14:35.09.567] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:35.09.722] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:35.09.965] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:35.10.211] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                  [24.01.2024 14:35.11.303] [INFO]  Calendar-Fetcher: Broadcasting 30 events.
                                  [24.01.2024 14:35.11.793] [INFO]  Calendar-Fetcher: Broadcasting 52 events.
                                  [24.01.2024 14:35.12.334] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:35.12.363] [LOG]   <Buffer 34 39 2e 34 0a>
                                  [24.01.2024 14:35.16.283] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                  [24.01.2024 14:35.20.779] [INFO]  Calendar-Fetcher: Broadcasting 53 events.
                                  [24.01.2024 14:36.09.256] [LOG]   <Buffer 34 38 2e 39 0a>
                                  [24.01.2024 14:36.12.996] [LOG]   <Buffer 34 39 2e 39 0a>
                                  [24.01.2024 14:37.09.270] [LOG]   <Buffer 34 39 2e 34 0a>
                                  [24.01.2024 14:37.13.489] [LOG]   <Buffer 34 39 2e 39 0a>
                                  [24.01.2024 14:38.09.169] [LOG]   <Buffer 35 30 2e 35 0a>
                                  [24.01.2024 14:38.13.988] [LOG]   <Buffer 34 39 2e 39 0a>
                                  [24.01.2024 14:38.14.452] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:38.14.457] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:38.14.470] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:38.14.471] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:38.14.485] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:38.14.489] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:38.14.500] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:38.14.501] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:38.14.516] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:38.14.519] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:38.15.574] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:38.16.265] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:38.16.801] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:38.17.287] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:38.17.803] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:39.09.340] [LOG]   <Buffer 34 39 2e 34 0a>
                                  [24.01.2024 14:39.14.471] [LOG]   <Buffer 34 39 2e 34 0a>
                                  [24.01.2024 14:40.08.101] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:40.08.102] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:40.08.120] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:40.08.125] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:40.08.133] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:40.08.137] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:40.08.143] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:40.08.144] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:40.08.147] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:40.08.151] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:40.08.771] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:40.09.154] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:40.09.337] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:40.09.459] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:40.09.572] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:40.09.592] [LOG]   <Buffer 34 39 2e 34 0a>
                                  [24.01.2024 14:40.10.516] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                  [24.01.2024 14:40.11.785] [INFO]  Calendar-Fetcher: Broadcasting 30 events.
                                  [24.01.2024 14:40.12.339] [INFO]  Calendar-Fetcher: Broadcasting 52 events.
                                  [24.01.2024 14:40.12.774] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:40.15.393] [LOG]   <Buffer 34 39 2e 34 0a>
                                  [24.01.2024 14:40.16.443] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                  [24.01.2024 14:40.24.801] [INFO]  Calendar-Fetcher: Broadcasting 53 events.
                                  [24.01.2024 14:41.09.525] [LOG]   <Buffer 34 38 2e 33 0a>
                                  [24.01.2024 14:41.16.031] [LOG]   <Buffer 34 38 2e 33 0a>
                                  [24.01.2024 14:42.09.212] [LOG]   <Buffer 34 38 2e 33 0a>
                                  [24.01.2024 14:42.16.668] [LOG]   <Buffer 34 38 2e 33 0a>
                                  [24.01.2024 14:43.09.112] [LOG]   <Buffer 34 37 2e 32 0a>
                                  [24.01.2024 14:43.14.619] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:43.14.619] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:43.14.624] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:43.14.625] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:43.14.633] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:43.14.634] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:43.14.644] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:43.14.645] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:43.14.656] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6GgL9NpRNOQgp80OvSwCbMOeFv6iEbO0MA15jIKExxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:43.14.658] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:43.15.536] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:43.15.948] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:43.16.746] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:43.17.153] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:43.17.757] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:43.18.370] [LOG]   <Buffer 34 37 2e 38 0a>
                                  [24.01.2024 14:44.09.025] [LOG]   <Buffer 34 36 2e 32 0a>
                                  [24.01.2024 14:44.17.658] [LOG]   <Buffer 34 35 2e 31 0a>
                                  [24.01.2024 14:45.08.100] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:45.08.101] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:45.08.120] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:45.08.121] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:45.08.125] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:45.08.126] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:45.08.172] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:45.08.172] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:45.08.200] [LOG]   Use existing calendarfetcher for url: http://p31-caldav.icloud.com/published/2/MTc3NjQyNjU0MTMxNzc2NCCpXXOtdiDoAXKHLKt4Oj6_ewf91iJc_kxBk1CQkLk01-XUuYBYg3p2pAldo6BZKxxxxxxxxxxxxxxxxxxxxxxxxxx
                                  [24.01.2024 14:45.08.201] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:45.08.804] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:45.08.904] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:45.09.005] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:45.09.210] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:45.09.304] [INFO]  Calendar-Fetcher: Broadcasting 6 events.
                                  [24.01.2024 14:45.09.310] [LOG]   <Buffer 34 35 2e 31 0a>
                                  [24.01.2024 14:45.10.766] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                  [24.01.2024 14:45.12.577] [INFO]  Calendar-Fetcher: Broadcasting 30 events.
                                  [24.01.2024 14:45.13.104] [INFO]  Calendar-Fetcher: Broadcasting 52 events.
                                  [24.01.2024 14:45.13.296] [INFO]  Calendar-Fetcher: Broadcasting 1 events.
                                  [24.01.2024 14:45.16.606] [INFO]  Newsfeed-Fetcher: Broadcasting 20 items.
                                  [24.01.2024 14:45.18.461] [LOG]   <Buffer 34 35 2e 31 0a>
                                  [24.01.2024 14:45.28.393] [INFO]  Calendar-Fetcher: Broadcasting 53 events.
                                  [24.01.2024 14:46.09.312] [LOG]   <Buffer 34 35 2e 31 0a>
                                  [24.01.2024 14:46.19.414] [LOG]   <Buffer 34 35 2e 36 0a>
                                  [24.01.2024 14:47.09.181] [LOG]   <Buffer 34 37 2e 32 0a>
                                  [24.01.2024 14:47.20.033] [LOG]   <Buffer 34 37 2e 32 0a>
                                  [24.01.2024 14:48.09.102] [LOG]   <Buffer 34 37 2e 32 0a>
                                  [24.01.2024 14:48.15.000] [LOG]   Use existing calendarfetcher for url: http://p31-
                                    sdetweil @Manu85
                                    @Manu85 yep…
                                    yes the module has been updated since v 2.25,
                                    (it should have had a version check!, rather than fail like this)
                                    to use the internal fetch function instead of an external library.
                                    and u are on 2.23
                                    use my upgrade script to get to latest 2.26
                                      Manu85 @sdetweil
                                      @sdetweil sorry for not responding to you more quickly, but I had an appointment with the doctor, is it the weather module that doesn’t have the right version? you ask me to use your script but I don’t know what it is, sorry for my ignorance
                                        sdetweil @Manu85
                                        @Manu85 no problem… I don’t expect any timeline in responses… life goes on
                                        i provide scripts to handle the install and upgrade of the MM base
                                        (these are listed in the MM install doc, alternative approaches)
                                        upgrade is a 2 part process, cause I don’t want to destroy you MagicMirror installation
                                        so the first pass is a test… no changes are made… it will tell you anything about the install that might be of concern… (people change files, and do things I don’t know, so check and report… )
                                        then you run again, with a parameter to DO the upgrade…
                                        both are logged, so we can tell what happened.
                                        and I also provide scripts to take and restore backups of the MM installation
                                        which can also be versioned(with git) and saved/restored from github
                                        https://github.com/sdetweil/MagicMirror-backup-restore
                                          sdetweil @Manu85
                                          @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                                          modules can check the version of MM and fail if its not at least this minimum
                                          https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties
                                          (from another module on my system currently)
                                          requiresVersion: "2.1.0",
                                          so this one should have had
                                          requiresVersion: "2.26.0",
                                            Manu85 @sdetweil
                                            @sdetweil ok, I’ll try to see with the link you sent me “https://github.com/sdetweil/MagicMirror_scripts” I hope I won’t break everything
                                            • 10
                                            • 11
                                            • 15
                                            • 16
                                            • 9 / 16
