    Black Screen when news doesnt fetch
    8 Posts 5 Posters 1.2k Views 5 Watching
    • U Offline
      uok825
      Hi, as i mentioned i got black screen when the news cant fetch due to wifi(i dont know about that).
      Wifi is connected correctly i can ping and browse.
      • “version”: “2.24.0”,
      • Node v16.20.2
      • Npm 8.19.4
      • Distributor ID: Debian
        Description: Debian GNU/Linux 11 (bullseye)
        Release: 11
        Codename: bullseye
      • RPi 3B
      Here is my logs:
      0|MagicMir | [05.02.2024 06:53.10.754] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://t24.com.tr/rss FetchError: request to https://t24.com.tr/rss failed, reason: getaddrinfo EAI_AGAIN t24.com.tr
      0|MagicMir |     at ClientRequest.<anonymous> (/home/pi/MagicMirror/node_modules/node-fetch/lib/index.js:1501:11)
      0|MagicMir |     at ClientRequest.emit (node:events:513:28)
      0|MagicMir |     at TLSSocket.socketErrorListener (node:_http_client:502:9)
      0|MagicMir |     at TLSSocket.emit (node:events:513:28)
      0|MagicMir |     at emitErrorNT (node:internal/streams/destroy:151:8)
      0|MagicMir |     at emitErrorCloseNT (node:internal/streams/destroy:116:3)
      0|MagicMir |     at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
      0|MagicMir |   type: 'system',
      0|MagicMir |   errno: 'EAI_AGAIN',
      0|MagicMir |   code: 'EAI_AGAIN'
      0|MagicMir | }
      0|MagicMir | [05.02.2024 07:28.12.616] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://t24.com.tr/rss FetchError: request to https://t24.com.tr/rss failed, reason: getaddrinfo EAI_AGAIN t24.com.tr
      0|MagicMir | }
      0|MagicMir | [05.02.2024 07:33.12.648] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://t24.com.tr/rss FetchError: request to https://t24.com.tr/rss failed, reason: getaddrinfo EAI_AGAIN t24.com.tr
      0|MagicMir | }
      0|MagicMir | [05.02.2024 07:43.12.993] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://t24.com.tr/rss FetchError: request to https://t24.com.tr/rss failed, reason: getaddrinfo EAI_AGAIN t24.com.tr
      0|MagicMir | }
      0|MagicMir | [05.02.2024 11:12.12.926] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://www.cumhuriyet.com.tr/rss/son_dakika.xml FetchError: request to https://www.cumhuriyet.com.tr/rss/son_dakika.xml failed, reason: getaddrinfo EAI_AGAIN www.cumhuriyet.com.tr
      0|MagicMir | }
      0|MagicMir | [05.02.2024 14:08.56.884] [ERROR] Newsfeed Error. Could not fetch newsfeed:  https://t24.com.tr/rss FetchError: request to https://t24.com.tr/rss failed, reason: getaddrinfo EAI_AGAIN t24.com.tr
      0|MagicMir | }
      0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      0|MagicMir | /home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT```
      KristjanESPERANTOK S 2 Replies Last reply Reply Quote 0
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @uok825
        @uok825 said in Black Screen when news doesnt fetch:
        Node v16.20.2
        Node 16 has reached End of Life. Please update node to version 20 and MM to 2.26.0 and check if the problem still occurs.
          sdetweil @uok825
          @uok825 EAI_AGAIN is a networking problem, unable to resolve address.
          nothing we can do, other than improve the error recovery.
          U 1 Reply Last reply Reply Quote 0
          • U Offline
            uok825 @sdetweil
            @sdetweil I understand that but why is going black screen? It can show something like network error on the screen.
              sdetweil @uok825
              @uok825 it can, but doesn’t handle the error, and crashes the browser…
              many modules do not have very robust error recovery
              kayakbabeK 1 Reply Last reply Reply Quote 0
              • kayakbabeK Offline
                kayakbabe @sdetweil
                @uok825 Is it the default newsfeed module that is causing this or a different third party newsfeed module?
                • U Offline
                  uok825 @kayakbabe
                  @kayakbabe Default
                  • G Offline
                    Grominet
                    Unfortunatly, only way I make it works : using a watch dog… then it auto restart MM.
                    https://github.com/MichMich/MMM-WatchDog
