    node_helper.js is not working?
    49 Posts 3 Posters 28.2k Views 3 Watching
    • V
      vandy2424 @MMRIZE
      @MMRIZE
      I tried both localhost and the IP of my PI (LAN) and neither resolved the issue. Also, whether it matters or not, changing these also did not remove the WebSocket warning shown in the dev console.
      M 1 Reply Last reply
        MMRIZE @vandy2424
        @vandy2424
        Really weird.
        Of course you are probably running MM as Electron standalone(not server/client). Hmmmm… How about your port forwarding on port 8080 on your home router or firewall? Something makes your ws not working.
        Or… there is another process which is using that port as another ws instance.(but seems not possible… hmmmm) or proxy something maybe…
        But I can’t guess any more sorry.
        V 1 Reply Last reply
        • V
          vandy2424 @MMRIZE
          @MMRIZE
          Yeah I’m not currently port forwarding at all right now and would have no reason to for 8080 anyways. But I really appreciate all your help! I can tell you that when I did a clean install of the Raspberry Pi OS, I have only installed MM and its dependencies.
          All my libraries should be up to date. Maybe there is some strange clash going on with my library versions? Maybe I try to go to versions that you guys use (if they’re even different than mine)? Just some thoughts.
          I’m glad that we are all at least on the same page of the strangeness going on here. Hopefully a lightbulb will pop up at some point and we can resolve the issue. Thanks again! :)
          S 2 Replies Last reply
            sdetweil @vandy2424
            @vandy2424 ok the updatenotification and helloworld modules come from the js/defaults.js
            I don’t see the path yet that does both.
              sdetweil @vandy2424
              @vandy2424 can you do
              cd  ~/Documents/MagicMirror/config
              ls -laF
              • V
                vandy2424 @sdetweil
                @sdetweil Yes, here is the output:
                jackson@raspberrypi:~/Documents/MagicMirror/config $ ls -LaF
                ./  ../  config.js*  config.js.sample  .config.js.swp
                  sdetweil @vandy2424
                  @vandy2424 lower case L
                  -laF
                  • V
                    vandy2424 @sdetweil
                    @sdetweil Apologies.
                    jackson@raspberrypi:~/Documents/MagicMirror/config $ ls -laF
                    total 20
                    drwxr-xr-x  2 jackson jackson 4096 Feb  9 19:19 ./
                    drwxr-xr-x 18 jackson jackson 4096 Feb  2 10:27 ../
                    -rwxrwxrwx  1 root    root    1998 Feb  9 19:19 config.js*
                    -rw-r--r--  1 jackson jackson 3534 Feb  2 10:27 config.js.sample
                    -rw-r--r--  1 jackson jackson 1024 Feb  2 12:12 .config.js.swp
                      sdetweil @vandy2424
                      @vandy2424
                      change the permissions owner and group
                      exit the editor
                      sudo chown jackson config.js
                      sudo chgrp jackson config.js
                      • V
                        vandy2424 @sdetweil
                        @sdetweil Okay I ran both of those commands.
                          sdetweil @vandy2424
                          @vandy2424 and try starting mm again
                          • V
                            vandy2424 @sdetweil
                            @sdetweil The calendar module still says loading… Everything else is the same as it was. Both logs show exactly the same as well.
                              sdetweil @vandy2424
                              @vandy2424 can you confirm the permissions change?
                              ls -laF
                              I can explain it
                              access to the file fails at startup time
                              fs.accessSync() js/app.js, line 117
                              so defaults is used… thats node helpers
                              file is loaded in the browser anyhow(index.html), and that controls module loading in browser
                              S V 2 Replies Last reply
                                @sdetweil I will test in the morning
                                • V
                                  vandy2424 @sdetweil
                                  @sdetweil Yeah sure, the output actually looks the same even though I ran those commands:
                                  total 20
                                  -rwxrwxrwx  1 jackson jackson 1998 Feb  9 19:19 config.js*
                                  And wow, its incredible you were able to find that. Thanks so much for the continuous help. Hopefully we are close!
                                    sdetweil @vandy2424
                                    @vandy2424 try this
                                    sudo chmod 644 config.js
                                      sdetweil @vandy2424
                                      @vandy2424 said in node_helper.js is not working?:
                                      I can recreate it if I force the fs api call to fail… but I cannot get it to fail normally
                                      root, full permissions, still works…
                                      i can force it to fail the accessSync()
                                      with permissions 740, and owner/group as root
                                      but, i get an error message in the npm startup messages
                                      [09.02.2024 21:21.19.642] [DEBUG] config template file not exists, no envsubst
                                      [09.02.2024 21:21.19.642] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: Error: EACCES: permission denied, open '/home/pi/Documents/MagicMirror/config/config.js'
                                      • V
                                        vandy2424 @sdetweil
                                        @sdetweil Interesting. So it would seem my issue isn’t based with permissions of the config file but something else causing the config file to not be read/synced properly? It is strange that mine is “failing” normally, even though my permissions are correct.
                                        I tried sudo chmod 644 config.js and nothing changed.
                                        I wonder if its worth reinstalling MM at this point? Not sure what your take would be on that.
                                          sdetweil @vandy2424
                                          @vandy2424 I would try the normal path
                                          copy the config.js.sample to config.js
                                          mv config.js config.js.save
                                          cp config.js.sample config.js
                                          I also moved my MagicMirror folder under Documents. that had no effect
                                          you can disable modules with
                                          disabled: true,
                                          after the module: line
                                          so you don’t have to delete the content…
                                          • V
                                            vandy2424 @sdetweil
                                            @sdetweil Wow so I’m a bit confused on this but its working. So I ran those commands and just started by running the default config.js from config.js.sample that had been copied over and all the modules worked (including calendar which includes a node_helper.js module).
                                            Whats interesting is when I tried copying the contents of my old config.js over to the new config.js, I actually got the same backend log as before:
                                            [10.02.2024 07:51.49.862] [LOG]   Starting MagicMirror: v2.26.0
                                            [10.02.2024 07:51.49.873] [LOG]   Loading config ...
                                            [10.02.2024 07:51.49.879] [DEBUG] config template file not exists, no envsubst
                                            [10.02.2024 07:51.49.887] [LOG]   Loading module helpers ...
                                            [10.02.2024 07:51.49.944] [LOG]   Initializing new module helper ...
                                            [10.02.2024 07:51.49.947] [LOG]   Module helper loaded: updatenotification
                                            [10.02.2024 07:51.49.949] [LOG]   No helper found for module: helloworld.
                                            [10.02.2024 07:51.49.950] [LOG]   All module helpers loaded.
                                            [10.02.2024 07:51.49.969] [LOG]   Starting server on port 8080 ...
                                            [10.02.2024 07:51.50.435] [LOG]   Server started ...
                                            [10.02.2024 07:51.50.438] [LOG]   Connecting socket for: updatenotification
                                            [10.02.2024 07:51.50.440] [LOG]   Starting module helper: updatenotification
                                            [10.02.2024 07:51.50.441] [LOG]   Sockets connected & modules started ...
                                            [10.02.2024 07:51.50.471] [LOG]   Launching application.
                                            Where as, when only manually editing the config contents copied over from the config.js.sample file, and only enabling the same modules as were being used in my old config (just disabled others), now the output looks like this (which I assume is what were looking for):
                                            [10.02.2024 08:02.54.899] [LOG]   Starting MagicMirror: v2.26.0
                                            [10.02.2024 08:02.54.909] [LOG]   Loading config ...
                                            [10.02.2024 08:02.54.915] [DEBUG] config template file not exists, no envsubst
                                            [10.02.2024 08:02.54.923] [LOG]   Loading module helpers ...
                                            [10.02.2024 08:02.54.925] [LOG]   No helper found for module: clock.
                                            [10.02.2024 08:02.55.227] [LOG]   Initializing new module helper ...
                                            [10.02.2024 08:02.55.228] [LOG]   Module helper loaded: calendar
                                            [10.02.2024 08:02.55.230] [LOG]   No helper found for module: weather.
                                            [10.02.2024 08:02.55.444] [LOG]   Initializing new module helper ...
                                            [10.02.2024 08:02.55.446] [LOG]   Module helper loaded: newsfeed
                                            [10.02.2024 08:02.55.447] [LOG]   All module helpers loaded.
                                            [10.02.2024 08:02.55.463] [LOG]   Starting server on port 8080 ...
                                            [10.02.2024 08:02.55.967] [LOG]   Server started ...
                                            [10.02.2024 08:02.55.970] [LOG]   Connecting socket for: calendar
                                            [10.02.2024 08:02.55.971] [LOG]   Starting node helper for: calendar
                                            [10.02.2024 08:02.55.973] [LOG]   Connecting socket for: newsfeed
                                            [10.02.2024 08:02.55.975] [LOG]   Starting node helper for: newsfeed
                                            [10.02.2024 08:02.55.977] [LOG]   Sockets connected & modules started ...
                                            [10.02.2024 08:02.56.003] [LOG]   Launching application.
                                            [10.02.2024 08:03.02.349] [LOG]   Create new calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics - Interval: 604800000
                                            [10.02.2024 08:03.02.626] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                                            [10.02.2024 08:03.03.472] [INFO]  Calendar-Fetcher: Broadcasting 11 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                                            [10.02.2024 08:03.05.342] [INFO]  Newsfeed-Fetcher: Broadcasting 24 items.
                                            Granted, there is some other lines that came from the sample js that are included that weren’t in my config, but im still confused on the magic that happened here. Maybe I had a really weird formatting error causing something in the code to be out of scope? Id be curious if you had an idea of why this is the case. It was almost like that old config.js may have been corrupted in some way. Either way, this is a huge step in the right direction (in theory its working).
                                            Im going to try and add back non-default modules 1 by 1 to this new config and update in this post here soon.
                                            • 2 / 3
