    node_helper.js is not working?
    49 Posts 3 Posters 28.2k Views 3 Watching
      sdetweil @vandy2424
      @vandy2424 well, it’s something…
      • V
        vandy2424 @sdetweil
        @sdetweil This is true, but in the backend log, none of my modules say they were loaded, and never have. Just mentions loading config and loading module helpers.
        The clock & weather still work without showing they were loaded on the backend. (maybe this doesn’t matter since they don’t use a node_helper.js class).
          sdetweil @vandy2424
          @vandy2424 correct , weirdness…
            MMRIZE @vandy2424
            @vandy2424
            Try ‘localhost’ or real IP instead of ‘0.0.0.0’.
            V 1 Reply Last reply
            • V
              vandy2424 @MMRIZE
              @MMRIZE
              I tried both localhost and the IP of my PI (LAN) and neither resolved the issue. Also, whether it matters or not, changing these also did not remove the WebSocket warning shown in the dev console.
              M 1 Reply Last reply
                MMRIZE @vandy2424
                @vandy2424
                Really weird.
                Of course you are probably running MM as Electron standalone(not server/client). Hmmmm… How about your port forwarding on port 8080 on your home router or firewall? Something makes your ws not working.
                Or… there is another process which is using that port as another ws instance.(but seems not possible… hmmmm) or proxy something maybe…
                But I can’t guess any more sorry.
                • V
                  vandy2424 @MMRIZE
                  @MMRIZE
                  Yeah I’m not currently port forwarding at all right now and would have no reason to for 8080 anyways. But I really appreciate all your help! I can tell you that when I did a clean install of the Raspberry Pi OS, I have only installed MM and its dependencies.
                  All my libraries should be up to date. Maybe there is some strange clash going on with my library versions? Maybe I try to go to versions that you guys use (if they’re even different than mine)? Just some thoughts.
                  I’m glad that we are all at least on the same page of the strangeness going on here. Hopefully a lightbulb will pop up at some point and we can resolve the issue. Thanks again! :)
                  S 2 Replies Last reply
                    sdetweil @vandy2424
                    @vandy2424 ok the updatenotification and helloworld modules come from the js/defaults.js
                    I don’t see the path yet that does both.
                      sdetweil @vandy2424
                      @vandy2424 can you do
                      cd  ~/Documents/MagicMirror/config
                      ls -laF
                      • V
                        vandy2424 @sdetweil
                        @sdetweil Yes, here is the output:
                        jackson@raspberrypi:~/Documents/MagicMirror/config $ ls -LaF
                        ./  ../  config.js*  config.js.sample  .config.js.swp
                          sdetweil @vandy2424
                          @vandy2424 lower case L
                          -laF
                          • V
                            vandy2424 @sdetweil
                            @sdetweil Apologies.
                            jackson@raspberrypi:~/Documents/MagicMirror/config $ ls -laF
                            total 20
                            drwxr-xr-x  2 jackson jackson 4096 Feb  9 19:19 ./
                            drwxr-xr-x 18 jackson jackson 4096 Feb  2 10:27 ../
                            -rwxrwxrwx  1 root    root    1998 Feb  9 19:19 config.js*
                            -rw-r--r--  1 jackson jackson 3534 Feb  2 10:27 config.js.sample
                            -rw-r--r--  1 jackson jackson 1024 Feb  2 12:12 .config.js.swp
                              sdetweil @vandy2424
                              @vandy2424
                              change the permissions owner and group
                              exit the editor
                              sudo chown jackson config.js
                              sudo chgrp jackson config.js
                              • V
                                vandy2424 @sdetweil
                                @sdetweil Okay I ran both of those commands.
                                  sdetweil @vandy2424
                                  @vandy2424 and try starting mm again
                                  • V
                                    vandy2424 @sdetweil
                                    @sdetweil The calendar module still says loading… Everything else is the same as it was. Both logs show exactly the same as well.
                                      sdetweil @vandy2424
                                      @vandy2424 can you confirm the permissions change?
                                      ls -laF
                                      I can explain it
                                      access to the file fails at startup time
                                      fs.accessSync() js/app.js, line 117
                                      so defaults is used… thats node helpers
                                      file is loaded in the browser anyhow(index.html), and that controls module loading in browser
                                      S V 2 Replies Last reply
                                        @sdetweil I will test in the morning
                                        • V
                                          vandy2424 @sdetweil
                                          @sdetweil Yeah sure, the output actually looks the same even though I ran those commands:
                                          total 20
                                          -rwxrwxrwx  1 jackson jackson 1998 Feb  9 19:19 config.js*
                                          And wow, its incredible you were able to find that. Thanks so much for the continuous help. Hopefully we are close!
                                            sdetweil @vandy2424
                                            @vandy2424 try this
                                            sudo chmod 644 config.js
                                            • 2 / 3
