    MMM-GoogleTasks token.json
    8 Posts 2 Posters 2.4k Views 2 Watching
      sdetweil @svenpisa
      @svenpisa never seen that node .
      see the module instructions
        sdetweil @svenpisa
        @svenpisa but more importantly, why are you doing that script instead of following the module instructions?
          svenpisa
          :loudly_crying_face: :loudly_crying_face: :loudly_crying_face:
          Do I understand correctly that I have chosen the wrong or faulty module?
          so it’s best to use https://github.com/jgauth/MMM-GoogleTasks?tab=readme-ov-file then install https://github.com/googleapis/google-api-nodejs-client first and then it should work???
          If only it were always that easy… I’ll give it a try tonight or tomorrow.
          Thanks Sam for your quick feedback :-)
            svenpisa
            I got it right! :grinning_face:
            Now I just have the following question. Can I display more than one list and can I display them side by side?
            I have now created two lists in the Tasks app. But only the first list is displayed.
            I would have simply duplicated the entry in Config.js and entered “top_left” and “top_center” in positions. Additionally used includedLists:. But unfortunately that doesn’t work.
            db7a6458-12fa-4fff-aa6f-f6bdab9c0821-Screenshot_2024-02-14-14-29-13-233-edit_com.google.android.apps.tasks.jpg
            Any ideas?
              sdetweil @svenpisa
              @svenpisa I don’t know. you should ask the author thru an issue to the module repo
              the module does not support multiple instances in config.js, so that type of side by side won’t work.
              because it uses a js library , I don’t know if you can have multiple instances, browser is considered one overall instance.
              the doc seems to imply (to me) one gt list,
              OR one list of events across all lists in gt.
                svenpisa
                @sdetweil Hi Sam,
                I have looked at the module https://github.com/jgauth/MMM-GoogleTasks again and see in the problems exactly the question that I also asked with several lists and a link to https://github.com/usncahill/MMM-GoogleTasks
                but then I come back to the original problem that I need a token.json and from here on I don’t understand it anymore and can’t really get any further.
                  sdetweil @svenpisa
                  @svenpisa i don’t understand… did you do the steps in the module instructions?
