Restart Mirror?
5 Posts 3 Posters 25.9k Views 2 Watching
    Achatos
    Hey there! I got the Mirror up and nicely running.
    Now I am playing around with the config file. However I can’t seem to figure how to either update or restart the Mirror App.
    I have it starting on boot. So I don’t want to reboot everytime I make a change in the config.js.
    When I cd to the MagicMirror directory and type
    "npm restart
    I get this:
    npm ERR! Linux 4.4.38-v7+
    npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “restart”
    npm ERR! node v6.9.4
    npm ERR! npm v3.10.10
    npm ERR! code ELIFECYCLE
    npm ERR! magicmirror@2.1.0 start: electron js/electron.js
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the magicmirror@2.1.0 start script ‘electron js/electron.js’.
    npm ERR! If you do, this is most likely a problem with the magicmirror package,
    npm ERR! not with npm itself.
    npm ERR! electron js/electron.js
    npm ERR! npm bugs magicmirror
    npm ERR! Or if that isn’t available, you can get their info via:
    npm ERR! npm owner ls magicmirror
    Any advice?
      broberg Project Sponsor
      if you are working directly on the pi, then ctrl+R reloads the page.
      via ssh somebody else has to chime in, since I don’t use that
        Achatos
        Thanks for the reply. I am indeed using SSH…
        I 1 Reply Last reply Jan 18, 2017, 6:38 PM Reply Quote 0
        • I Offline
          in_a_days @Achatos
          @Achatos
          Are you running pm2? If so,
          pm2 restart mm
          will restart your mirror software. Otherwise use
          DISPLAY=:0 npm start
          from the MagicMirror folder and it will start up.
          EDIT: Just realized this last suggestion is only applicable if you don’t have the MM software already running.
            Achatos
            “pm2 restart mm” works like a charm.
            Much obliged! :)
