    ISS tracker
    33 Posts 5 Posters 32.2k Views 5 Watching
    • karsten13K Offline
      karsten13 @BerkSmash1984
      @BerkSmash1984 said in ISS tracker:
      @karsten13 Any chance we can get a config option to use imperial units in the next update for the altitude and speed calculations? Also, an option to disable those calculations altogether?
      this is a small thing, will put it on my todo list, as I’m total unfamiliar with imperial units: Which are the ones you want to see, ft and mph?
      karsten13K BerkSmash1984B 2 Replies Last reply Reply Quote 0
        karsten13 @karsten13
        @karsten13 said in ISS tracker:
        used now mi and mph …
        There is a new version with the above option and a new default map.
          Manu85 @karsten13
          @karsten13 Bravo and thank you for your responsiveness, this card is more beautiful, the best would be to have a more colorful card, but you are at the top again, congratulations for your work
          karsten13K 1 Reply Last reply Reply Quote 1
            karsten13 @Manu85
            @Manu85
            AFAIS they combine several layers, they are visible in the source code of the page.
            For the main layer you can try
                    mapUrl: "https://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer/tile/{z}/{y}/{x}",
            M M 2 Replies Last reply Reply Quote 0
              manu85340 @karsten13
              @karsten13 thank you for your answer, I will try
                Manu85 @karsten13
                @karsten13 great, it works however there are no longer the names of the cities, do you think it would be possible to have a mix of the two? you are at the top, well done
                • BerkSmash1984B Offline
                  BerkSmash1984 @karsten13
                  @karsten13 Awesome! I updated the module and my config, and see the imperial units. Thanks!
                    karsten13 @Manu85
                    @Manu85 said in ISS tracker:
                    that was meant with “they combine several layers” but I don’t know how at the moment …
                      @karsten13 ok, thank you for your work
                        @karsten13 I just realized that I was using 2 accounts Manu85 and manu85340!!!
                          karsten13 @manu85340
                          I added options for city and country layers, see https://gitlab.com/khassel/MMM-ISS-Map#add-country-and-city-layers
                          If they are missing in the used map you can add them now in the config.
                          M M 4 Replies Last reply Reply Quote 0
                            @karsten13 great, I’m traveling until Wednesday, I’m going to try this when I get back, have a good day and thank you
                              Manu85 @karsten13
                              @karsten13 great, I just did the update and everything is functional, thank you for your work
                                Manu85 @karsten13
                                @karsten13 I saw in your list that you planned the route of the ISS I hate to see that
                                  Manu85 @karsten13
                                  @karsten13 Do you think it is possible to add the position of the ISS like below?
                                    karsten13 @Manu85
                                    @Manu85
                                    for this we need a free public api which provides these info’s depending on the position (longitude/latitude), so if you find one …
                                    M 3 Replies Last reply Reply Quote 0
                                      Manu85 @karsten13
                                      @karsten13 thank you for your answer, I don’t know where we find these APIs…I will search on the internet if I can find an answer and I will keep you informed but as I am not an expert I hope to find
                                        Manu85 @karsten13
                                        @karsten13 Hello, I’m looking but I can’t find it, although it exists for example on:
                                        https://www.youtube.com/watch?v=xRPjKQtRXR8
                                        Or on
                                        https://www.youtube.com/watch?v=_fdQK4lfjL8
                                        we see this information but I am not able to find it on the internet :grimacing_face:
                                          Manu85 @karsten13
                                          @karsten13 Hello, it’s me again, I’m coming to ask you for help once again… I would like to resize the module but when I modify:
                                          width: "762px", // Double width than default
                                          it modifies the size but I still have a white line above the module which is the width of the screen, I went to console mode and I saw that if I modify the size of the “box” then I can modify the width and the white line, on the other hand I can’t understand how I can modify this in my css.custom, I’ll give you a screenshot, if you could help me please, thank you in advance
