    Timetable from Untis.at
    12 Posts 4 Posters 4.6k Views 5 Watching
      sdetweil @jurcek
      @jurcek if there is no provided API, then one can only screen scrape the html content and convert that to the data to be used.
      usually there a fun challenges required to accomplish that.
        jurcek @sdetweil
        @sdetweil API is provided by the company - looks like the link didn’t end up in my message.
        Link to API documentation
        Would this help?
        How difficult would it be to scrape HTML content,…? Sorry…i am really a newbie in this.
          sdetweil @jurcek
          @jurcek I misread your first post as no API…
          that should help someone.
            jurcek @sdetweil
            @sdetweil i hope sincerelly someone will be able to help.
            Otherwise i will start learning about usage of API’s and to see if i can figure it out…
              sdetweil @jurcek
              @jurcek if it’s been 2+ years. and no one has created a module, then I think it’s unlikely.
              there are lots of modules that you can look at for inspiration and code.
                jurcek @sdetweil
                @sdetweil clear.
                i will try then to find a was how to make it.
                  rabbit83ka
                  Hi, there’s a module available, works fine for me.
                    jurcek @rabbit83ka
                    @rabbit83ka Thank you so much!! I was searching, but i couldn’t find it.
                    Let’s see if it will work :)
                    Have a nice day!
                    • I
                      ichel
                      It seems that there are no more updates for this module. It doesn’t work for me, can anyone confirm this?
                        rabbit83ka @ichel
                        @ichel For me it also stopped working, but I’m unsure if it’s due to the module or due to a changed configuration on school’s side. Respective issue.
                        • I
                          ichel @rabbit83ka
                          @rabbit83ka I have just set it up and it has never worked. It looks like the API has been changed by WebUntis. It only gives me https://ajax.webuntis.com as the URL after login and not schoolname.webuntis.com as in the readme.
                          Übersetzt mit DeepL (https://www.deepl.com/app/?utm_source=ios&utm_medium=app&utm_campaign=share-translation)
