    Timetable from Untis.at
    12 Posts 4 Posters 4.6k Views 5 Watching
      jurcek
      Re: Timetable from Units.at
      Dear community,
      there was a request already 2 1/2 years ago.
      Now that i started also with my Smart Mirror i would also request the help to develop the Module for Untis.at timetables and events.
      Unfortunately, i am not a programer, i still need to learn some day, but maybe there is somebody, who could be able to help.
      There is also API support from the designers of Untis, which could maybe help.
      If someone could direct me in the right direction - how to make this, i will try to do it by myself, but maybe it’s an easy task for someone with experience.
      thank you into looking at this in advance.
        sdetweil @jurcek
        @jurcek if there is no provided API, then one can only screen scrape the html content and convert that to the data to be used.
        usually there a fun challenges required to accomplish that.
        J 1 Reply Last reply
          jurcek @sdetweil
          @sdetweil API is provided by the company - looks like the link didn’t end up in my message.
          Link to API documentation
          Would this help?
          How difficult would it be to scrape HTML content,…? Sorry…i am really a newbie in this.
            sdetweil @jurcek
            @jurcek I misread your first post as no API…
            that should help someone.
              jurcek @sdetweil
              @sdetweil i hope sincerelly someone will be able to help.
              Otherwise i will start learning about usage of API’s and to see if i can figure it out…
                sdetweil @jurcek
                @jurcek if it’s been 2+ years. and no one has created a module, then I think it’s unlikely.
                there are lots of modules that you can look at for inspiration and code.
                  jurcek @sdetweil
                  @sdetweil clear.
                  i will try then to find a was how to make it.
                    rabbit83ka
                    Hi, there’s a module available, works fine for me.
                      jurcek @rabbit83ka
                      @rabbit83ka Thank you so much!! I was searching, but i couldn’t find it.
                      Let’s see if it will work :)
                      Have a nice day!
                      • I
                        ichel
                        It seems that there are no more updates for this module. It doesn’t work for me, can anyone confirm this?
                        R 1 Reply Last reply
                          rabbit83ka @ichel
                          @ichel For me it also stopped working, but I’m unsure if it’s due to the module or due to a changed configuration on school’s side. Respective issue.
                          I 1 Reply Last reply
                          • I
                            ichel @rabbit83ka
                            @rabbit83ka I have just set it up and it has never worked. It looks like the API has been changed by WebUntis. It only gives me https://ajax.webuntis.com as the URL after login and not schoolname.webuntis.com as in the readme.
                            Übersetzt mit DeepL (https://www.deepl.com/app/?utm_source=ios&utm_medium=app&utm_campaign=share-translation)
