    Timetable from Untis.at
    12 Posts 4 Posters 3.7k Views 5 Watching
      jurcek @sdetweil
      @sdetweil API is provided by the company - looks like the link didn’t end up in my message.
      Link to API documentation
      Would this help?
      How difficult would it be to scrape HTML content,…? Sorry…i am really a newbie in this.
        sdetweil @jurcek
        @jurcek I misread your first post as no API…
        that should help someone.
          jurcek @sdetweil
          @sdetweil i hope sincerelly someone will be able to help.
          Otherwise i will start learning about usage of API’s and to see if i can figure it out…
            sdetweil @jurcek
            @jurcek if it’s been 2+ years. and no one has created a module, then I think it’s unlikely.
            there are lots of modules that you can look at for inspiration and code.
              jurcek @sdetweil
              @sdetweil clear.
              i will try then to find a was how to make it.
                rabbit83ka
                Hi, there’s a module available, works fine for me.
                  jurcek @rabbit83ka
                  @rabbit83ka Thank you so much!! I was searching, but i couldn’t find it.
                  Let’s see if it will work :)
                  Have a nice day!
                  • I Offline
                    ichel
                    It seems that there are no more updates for this module. It doesn’t work for me, can anyone confirm this?
                      rabbit83ka @ichel
                      @ichel For me it also stopped working, but I’m unsure if it’s due to the module or due to a changed configuration on school’s side. Respective issue.
                      • I Offline
                        ichel @rabbit83ka
                        @rabbit83ka I have just set it up and it has never worked. It looks like the API has been changed by WebUntis. It only gives me https://ajax.webuntis.com as the URL after login and not schoolname.webuntis.com as in the readme.
                        Übersetzt mit DeepL (https://www.deepl.com/app/?utm_source=ios&utm_medium=app&utm_campaign=share-translation)
