    How to get 2 modules side by side?
    10 Posts 4 Posters 10.5k Views 4 Watching
      BananaBro
      i have two instances of the MMM-PublicTransportBerlin Module.
      			module: 'MMM-PublicTransportBerlin',
      			disabled : false,
      			position: 'bottom_right',
      				stationId: '900000009102',
      				hidden: false,
      				ignoredStations: [],
      				//ignoredLines: ['U5', 'U8', 'S75'],
      				excludedTransportationTypes: 'bus', //suburban,subway
      				travelTimeToStation: 8,
      				interval: 120000,
      				departureMinutes: 15,
      				maxDepartures: 12,
      				marqueeLongDirections: true,
      				showColoredLineSymbols: true,
      				useColorForRealtimeInfo: true,
      				showTableHeaders: true,
      				showTableHeadersAsSymbols: true,
      				maxUnreachableDepartures: 3,
      				maxReachableDepartures: 7,
      				fadeUnreachableDepartures: true,
      				fadeReachableDepartures: true,
      				fadePointForReachableDepartures: 0.25,
      				excludeDelayFromTimeLabel: true
      			disabled : false,
      				stationId: '900000009104',
      				hidden: false,
      				interval: 120000,
      				maxDepartures: 12,
      As you can see I want them both in the bottom_right. For now they align horizontally vertically but I don’t have space for that. Side by side (vertically horizontally) is enough space and it would look much better.
      Unfortunately I don’t have a clue how to do it. Any help appreciated.
      AlvingerA 1 Reply Last reply Reply Quote 0
      • AlvingerA Offline
        Alvinger @BananaBro
        @BananaBro just use the same region name, e.g. “bottom_right”, for both modules and they will be automatically stacked vertically.
          BananaBro
          Sry I mixed up horizontally and vertically :D
          Of course I meant it the other way around!
          My config and the rest of the text should have cleared that out though.
            j.e.f.f Project Sponsor Module Developer @BananaBro
            @BananaBro Try this in your custom CSS:
            .MMM-PublicTransportBerlin {
              display: inline-block;
              width: 49%;
              max-width: 49%;
              min-width: 49%;
            .MMM-PublicTransportBerlin:first-child {
              margin-right: 2%;
            It may need a bit of tweaking to get it to work right… If it doesn’t work as-is, post a screenshot and we’ll take it from there.
              BananaBro @j.e.f.f
              @j.e.f.f thanks thats already looking very promising.
              as you can see both instances of the MMM-PublicTransportBerlin module are side by side. Now it would be nice if there would be a little bit space between them.
              Maybe its just coincidence but my Mirror took ages to load. Does a custom css always slow down the first startup?
                @BananaBro to adjust the space in between, play with the percentages. The 49% value is the width of the modules, and the 2% is the space in between. Adjust them so the total adds up to 100% — in this case, 2 x 49 + 2. So if you wanted more space in between — say you increase the 2% value to 6% then you would decrease the module width from 49% to 47%. Keep adjusting until you are happy.
                As for the start up time, I haven’t noticed custom.css causing abnormally long startup time, and my custom.css file has quite a lot in it. Could be something else going on.
                  BananaBro @j.e.f.f
                  @j.e.f.f thx for the help. i tried to play with the percentages but it breaks the layout of the module. is there a possibility to grant more space in total?
                    @BananaBro try assigning more width to the bottom_right region:
                    .region.bottom.right {
                      width: 800px;
                      min-width: 800px;
                      max-width: 800px;
                    Adjust 800px until you are happy
                      BananaBro @j.e.f.f
                      @j.e.f.f really appreciate your help!
                      this is my result for now!
                        width: 720px;
                        min-width: 720px;
                        max-width: 720px;
                        width: 45%;
                        max-width: 45%;
                        min-width: 45%;
                        margin-left: 5%;
                        margin-right: 5%;
                      And this is my custom css if anyone is interested. I had to split the margin otherwise there was no space between the two instances.
                      • C codac referenced this topic on
                        bertories @BananaBro
                        @BananaBro
                        Re: How to get 2 modules side by side?
                        I am trying to have my Weather modules next to each other. I get close following this post, but I can’t seem to get them next to each other. I have played with the % on width and things and I can’t get the tops even.
                        .weather {
                        width: 47%;
                        max-width: 47%;
                        min-width: 47%;
                        .weather:first-child {
                        margin-right: 6%;
                        .region.top.right {
                        width: 600px;
                        min-width: 600px;
                        max-width: 600px;
                        Link to image:
                        https://www.dropbox.com/scl/fi/377vilalfvri9btnyc195/Screenshot-5.png?rlkey=77qpb4f05qh5zp6iqfa8e28o0&dl=0
                        Thank you,
