    MMM-WOTD
    Scheduled Pinned Locked Moved Education
    16 Posts 7 Posters 4.5k Views 8 Watching
      mdefrancesco
      this is one of my favorite modules. i do have a question.
      i increased the font size of the header but cant figure out how to increase the distance between the header and the divider bar underneath
      am i missing something simple?
        sdetweil @mdefrancesco
        @mdefrancesco see https://www2.lawrence.edu/fast/GREGGJ/CMSC106/lectures/CSS/Boxes.html#:~:text=To create extra space between,extra space around the element.
        also see https://forum.magicmirror.builders/post/90135
        to learn how to use the developers window elements tab to test out your css changes live, without change, restart/reload, repeat…
        • E Offline
          ehjaysea
          @mumblebaj said in MMM-WOTD:
          https://github.com/mumblebaj/MMM-WOTD
          Great work, thank you! FYI, for some strange reason as of right now the URL for english is throwing a 404, easily verified by going to https://www.englishpod101.com/english-phrases/
          mumblebajM 2 Replies Last reply Reply Quote 0
          • mumblebajM Offline
            mumblebaj Module Developer @ehjaysea
            @ehjaysea Hi. Seems like EnglishPod has now changed. The other languages seem to still be working, for now. Will start looking around for new sources.
              @ehjaysea I have pushed a change and English should now work again. Please do a git pull && npm install in the module folder. Everything should work again.
              • E Offline
                ehjaysea @mumblebaj
                @mumblebaj Wonderful, thank you! Working again :clapping_hands:
                • N Offline
                  Niggich @mumblebaj
                  Hey @mumblebaj,
                  looks nice, but I couldn’t get it working. I install all the Dependencies, but it doesn’t work. Is the module not working with more pages and server mode?
                    mumblebaj Module Developer @Niggich
                    @Niggich said in MMM-WOTD:
                    Not sure I understand the above.
                    The module works fine, works with MMM-pages and in Container (server only mode) I have tested this.
                    Can you check in the logs if you see any errors in the logs and advise?
                    • N Offline
                      Niggich @mumblebaj
                      @mumblebaj Ok, this is what I mean. You said it is working with MMM-pages an server only mode. So, I’ve checked the Logs, but there are no errors.
                      I will try the module with my other Mirror Server. Maybe it’s something wrong with this server… Thanks.
                      S mumblebajM 2 Replies Last reply Reply Quote 0
                        sdetweil @Niggich
                        @Niggich All the UI is done at the client. modules tell MM that there is data to show, MM gets it and shows it
                        all the pages are done at the client. (pages/carousel/…) only cause a modules content to be hidden or shown.
                        the server helps modules collect data and send it to the clients.
