    MMM-WOTD
    Scheduled Pinned Locked Moved Education
    16 Posts 7 Posters 8.1k Views 8 Watching
    • E
      ehjaysea
      @mumblebaj said in MMM-WOTD:
      https://github.com/mumblebaj/MMM-WOTD
      Great work, thank you! FYI, for some strange reason as of right now the URL for english is throwing a 404, easily verified by going to https://www.englishpod101.com/english-phrases/
      mumblebajM 2 Replies Last reply
      • mumblebajM
        mumblebaj Module Developer @ehjaysea
        @ehjaysea Hi. Seems like EnglishPod has now changed. The other languages seem to still be working, for now. Will start looking around for new sources.
        • mumblebajM
          @ehjaysea I have pushed a change and English should now work again. Please do a git pull && npm install in the module folder. Everything should work again.
          E 1 Reply Last reply
          • E
            ehjaysea @mumblebaj
            @mumblebaj Wonderful, thank you! Working again :clapping_hands:
            • NiggichN
              Niggich @mumblebaj
              Hey @mumblebaj,
              looks nice, but I couldn’t get it working. I install all the Dependencies, but it doesn’t work. Is the module not working with more pages and server mode?
              mumblebajM 1 Reply Last reply
              • mumblebajM
                mumblebaj Module Developer @Niggich
                @Niggich said in MMM-WOTD:
                Not sure I understand the above.
                The module works fine, works with MMM-pages and in Container (server only mode) I have tested this.
                Can you check in the logs if you see any errors in the logs and advise?
                NiggichN 1 Reply Last reply
                • NiggichN
                  Niggich @mumblebaj
                  @mumblebaj Ok, this is what I mean. You said it is working with MMM-pages an server only mode. So, I’ve checked the Logs, but there are no errors.
                  I will try the module with my other Mirror Server. Maybe it’s something wrong with this server… Thanks.
                  S mumblebajM 2 Replies Last reply
                    sdetweil @Niggich
                    @Niggich All the UI is done at the client. modules tell MM that there is data to show, MM gets it and shows it
                    all the pages are done at the client. (pages/carousel/…) only cause a modules content to be hidden or shown.
                    the server helps modules collect data and send it to the clients.
                    • NiggichN
                      Niggich @sdetweil
                      @sdetweil Okay, thanks. I learned something new.
                      • mumblebajM
                        @Niggich Have you also check for any errors in the Dev console (shift + ctrl + i)
                        • NiggichN
                          Niggich @mumblebaj
                          @mumblebaj No, I don’t. I tried again and now it is working, but I don’t know why?! I’m not sure I think I made a mistake the first time I installed it.
                          Thank you for your help!
                          • mumblebajM
                            @Niggich Glad it is working for you now.
