Solved calendar (icloud) not loading after last MM Update
I had a power outage while executing the command, now I get this error message when I try to run it.
Does anyone know what to do?
@sil3ntstorm
docd ~/MagicMirror sudo rm -rf node_modules/node-ical npm install node-ical@0.16.1
the same message
@sil3ntstorm ah,
cd ~/MagicMirror sudo rm -rf node_modules/axios
Unfortunately when I enter that nothing happens -
@sil3ntstorm on Linux most commands when successful set the return code and just exit
do now reinstall node-ical again
I have now restarted the PI and it boots up but only up to where MM2 is supposed to start, then this image with sunset or sunrise remains and the MM software does not start. This is in the log file (see below)
If I deactivate my calendar module everything starts normally.
The things I was supposed to do yesterday I also did this morning, and I get the same message as yesterday evening -
Does it help if I delete the module with the command and then reinstall it?
cd~/MagicMirror rm-rf modules/MMM-MyCalendar
@sil3ntstorm said in calendar (icloud) not loading after last MM Update:
looks like you didn’t do this step
cd ~/MagicMirror npm install node-ical@0.16.1
which MMM-MyCalendar are you using?
one I found doesn’t have a node_helper.jsgit remote -v
in the module folder
