    ALT not doing anything
    44 Posts 6 Posters 26.4k Views 5 Watching
      sdetweil @ankonaskiff17
      @ankonaskiff17 I did this
      git clone -b v2.19.0 https://github.com/MichMich/MagicMirror.git mm2.19
      to get the v2.19.0 tag into the folder called mm2.19
      if you don’t have the name at the end the folder will be MagicMirror
      (and fail if there is one already)
      ankonaskiff17A 1 Reply Last reply
      • ankonaskiff17A
        ankonaskiff17 @sdetweil
        @sdetweil Used your script and worked like a charm. Didnt put in mm2.22 at end since I had no previous install.
        Then did the various appropriate steps from the “official” manual install, like node and everything running as desired.
        S ankonaskiff17A 2 Replies Last reply
          @ankonaskiff17 my script does everything… no extra steps required
          • ankonaskiff17A
            ankonaskiff17 @ankonaskiff17
            @ankonaskiff17 I meant the one where you use the version tag. Not the one that
            alternative Installation methods is in . That pulls in the current version which is causing me problems with the ALT key
            I was unsure if git clone -b v2.19.0 https://github.com/... was going to install node.js, or PM2 so I did those portions of manual installation.
              @ankonaskiff17 ah
              • E
                EricD
                Hello all,
                I just install MagiMirror on a new RPI5 and I get the same problem : Alt key doesn’t give me the menu.
                I have compared electron.js from an old installation that works fine with the one I just install on my RPI5 and I remark the line “electronOptionsDefaults.autoHideMenuBar = true;” is missing in the new version. I add this line in the new version, similar place in the code list, and now the Alt command works like the old version : I get the menu.
                So it is solved for me, until the next update of electron.js file…
                If it can help you…
                EricD
                  sdetweil @EricD
                  @EricD yes electron changed the key behavior again. nothing we can do
                  • ankonaskiff17A
                    I have a SmartiPi Touch 2 and a SmartiPi Touch Pro I want to install MM on with both focusing on weather and maybe an item based on user request.
                    Do you recommend going for the latest greatest Bookworm install or an older Pi OS version to build off of? I’m not averse to a learning experience but don’t want to beat my head on a cinderblock wall either.
                    I had the infamous magic smoke :dashing_away: come out of the Pi 4 on my Ender 3D Printer and thinking about doing a MM or two while new parts come for printer. Nothing like feeding the Pi 4B with 24V instead of 5V.
                    Melted my Logitech Mouse/Keyboard dongle.
                      @ankonaskiff17 those are just cases. just a pi underneath
                      I am running bookworm on my pi4 in the case w 7in touch screen display, and MagicMirror w no issues
                      • F
                        Fifteen15Studios
                        It looks like nobody has posted a solution, but I posted a similar post months ago. Someone in there gave me the answer.
                        In MagicMirror/js/electron.js, change the line
                        electronOptionsDefaults.frame = false;
                        to
                        electronOptionsDefaults.frame = true;
                        Then add
                        If you’re using PM2 to load your mirror, you’ll have to stop and start PM2
                          sdetweil @Fifteen15Studios
                          @Fifteen15Studios if so, you can do this in config.js
                          electronOptions:{ frame: true, autoHideMenuBar:true},
                          note the trailing comma
                          before the modules:[ line
                          no code change required
                          • 3 / 3
