    MMM-PIR Install Issue
    4 Posts 3 Posters 771 Views 3 Watching
    • A
      Andrei.Leahu
      Hello all, I have a problem installing MMM-Pir Module. Maybe someone has an idea what I can check/do. Thanks in advance!
      Log:
      123 timing commandinstall Completed in 3987ms
      124 verbose stack Error command failed
      124 verbose stack at ChildProcess.anonymous (usrlibnode_modulesnpmnode_modules@npmclipromise-spawnlibindex.js5327)
      124 verbose stack at ChildProcess.emit (nodeevents51428)
      124 verbose stack at maybeClose (nodeinternalchild_process109116)
      124 verbose stack at ChildProcess._handle.onexit (nodeinternalchild_process3025)
      125 verbose pkgid MMM-Pir@1.5.0
      126 verbose cwd homexenonMagicMirrorv2MagicMirrormodulesMMM-Pir
      127 verbose Linux 6.1.21-v8+
      128 verbose node v18.17.1
      129 verbose npm v9.6.7
      130 error code 255
      131 error path homexenonMagicMirrorv2MagicMirrormodulesMMM-Pir
      132 error command failed
      133 error command sh -c installerpreinstall.sh -d ‘unclutter cec-utils ddcutil python3 python-is-python3 python3-gpiozero’
      134 verbose exit 255
      135 timing npm Completed in 4803ms
      136 verbose code 255
      137 error A complete log of this run can be found in homexenon.npm_logs2024-03-10T19_31_02_029Z-debug-0.log
      S bugsounetB 2 Replies Last reply
        sdetweil @Andrei.Leahu
        @Andrei-Leahu the module author has been updating recently, I would open an issue on the module github page
        • bugsounetB
          bugsounet Banned @Andrei.Leahu
          @Andrei-Leahu
          HI, change MagicMirror folder permission as your own user (xenon) and not root
          A 1 Reply Last reply
          • A
            Andrei.Leahu @bugsounet
            @bugsounet worked !! Thank you - I m still a linux newbie
