Hello everyone, do you know if there is an MM module for rugby
@mumblebaj that would have removed the competition column which takes up a lot of space, but once again these are just suggestions to make your module the most beautiful in MM :-)
@Manu85 Way too much work. You are welcome to can make a PR.
@mumblebaj I understand thank you for all the work you do, what is a “PR”?
@Manu85 PR = Pull Request which means you fork the module and make the relevant changes a push it back to the main repo. :winking_face:
@mumblebaj ah ok, but I see that there are more than 2,000 views on this post, maybe someone will be interested in this! :beaming_face_with_smiling_eyes:
@mumblebaj Hi I saw that @KristjanESPERANTO had made a football module like your Rugby module with the selection of different leagues, do you think that the module is adaptable with yours? it’s just a question :-)
@Manu85 Hi. I do not know. If you want to ask him to create or include the rugby into his module then you are more than welcome to do so.
@Manu85 The API they use is football only.
@mumblebaj I’m going to ask him anyway, he’s already done two or three modules for me
@Manu85 I saw your request to him. The module is not built for you and only you. Others are using it right now. You don’t seem to appreciate and understand the complexities around the data and how it the API’s are defined.
This module is being used by a number of people, and unless you raise a feature request and everybody agree to request will I entertain the idea. What you are asking for is not easily achievable with the way the API calls are structured.
For my own personal use the module is fine as is.
I hope you come right but this matter I consider closed now and module will remain as is.
