    Hello everyone, do you know if there is an MM module for rugby
    105 Posts 5 Posters 167.6k Views 6 Watching
    • mumblebajM
      mumblebaj Module Developer @manu85340
      @manu85340 said in Hello everyone, do you know if there is an MM module for rugby:
      Equipe
      Have update this. Time however I am not sure if changing it to hour is correct as it is Hour and Minutes
        manu85340 @mumblebaj
        @mumblebaj in French for a match the eure designates the start of the match, so it’s ok you can put “time”
          manu85340 @manu85340
          @mumblebaj in French for a match the heure designates the start of the match, so it’s ok you can put “heure”
            @mumblebaj Do you think it is possible to have the name of the competition like you did for the world ranking? in my example it is the “six nations”
            • mumblebajM
              @manu85340 What do I put if more than one league is selected?
                @mumblebaj ah, can’t you put a title for each competition? it’s a suggestion, I don’t know if it’s possible and the level of difficulty… it would be great to know what competition is displayed but it’s certainly complex
                • mumblebajM
                  @manu85340 The only option is to add the same column that is added when multiple leagues are selected.
                  Would look like this and was something I had but you did not like the view so I made it to only populate if more than one league is selected. If you have a single league selected you obviously know which league you input. My suggestion based on this is to leave it as is. As you know which single league you have selected we do not need to display it. If multiple leagues are selected then it displays as per below.
                  M 3 Replies Last reply Reply Quote 0
                    Manu85 @mumblebaj
                    @mumblebaj you’re right, it’s just that since I only had one competition it made me feel weird, but you’re completely right
                      Manu85 @mumblebaj
                      @mumblebaj I had in mind the possibility of having a table per competition, for example six nations, then another rugby Europe trophy another rugby Europe international championship etc. but it is certainly very complicated
                        Manu85 @mumblebaj
                        @mumblebaj that would have removed the competition column which takes up a lot of space, but once again these are just suggestions to make your module the most beautiful in MM :-)
                        • mumblebajM
                          mumblebaj Module Developer @Manu85
                          @Manu85 Way too much work. You are welcome to can make a PR.
                            Manu85 @mumblebaj
                            @mumblebaj I understand thank you for all the work you do, what is a “PR”?
                            • mumblebajM
                              @Manu85 PR = Pull Request which means you fork the module and make the relevant changes a push it back to the main repo. :winking_face:
                                Manu85 @mumblebaj
                                @mumblebaj ah ok, but I see that there are more than 2,000 views on this post, maybe someone will be interested in this! :beaming_face_with_smiling_eyes:
                                  Manu85 @mumblebaj
                                  @mumblebaj Hi I saw that @KristjanESPERANTO had made a football module like your Rugby module with the selection of different leagues, do you think that the module is adaptable with yours? it’s just a question :-)
                                  https://github.com/0m4r/MMM-SoccerLiveScore
                                  mumblebajM KristjanESPERANTOK 3 Replies Last reply Reply Quote 0
                                  • mumblebajM
                                    @Manu85 Hi. I do not know. If you want to ask him to create or include the rugby into his module then you are more than welcome to do so.
                                    • mumblebajM
                                      @Manu85 The API they use is football only.
                                        Manu85 @mumblebaj
                                        @mumblebaj I’m going to ask him anyway, he’s already done two or three modules for me
                                        • mumblebajM
                                          @Manu85 I saw your request to him. The module is not built for you and only you. Others are using it right now. You don’t seem to appreciate and understand the complexities around the data and how it the API’s are defined.
                                          This module is being used by a number of people, and unless you raise a feature request and everybody agree to request will I entertain the idea. What you are asking for is not easily achievable with the way the API calls are structured.
                                          For my own personal use the module is fine as is.
                                          I hope you come right but this matter I consider closed now and module will remain as is.
                                          • KristjanESPERANTOK
                                            KristjanESPERANTO Module Developer @Manu85
                                            @Manu85 said in Hello everyone, do you know if there is an MM module for rugby:
                                            MMM-SoccerLiveScore is maintained by @0m4r. I don’t really deal with sports modules :-)
                                            • 5 / 6
