    Hello everyone, do you know if there is an MM module for rugby
    105 Posts 5 Posters 167.6k Views 6 Watching
      Manu85 @mumblebaj
      @mumblebaj I had in mind the possibility of having a table per competition, for example six nations, then another rugby Europe trophy another rugby Europe international championship etc. but it is certainly very complicated
        Manu85 @mumblebaj
        @mumblebaj that would have removed the competition column which takes up a lot of space, but once again these are just suggestions to make your module the most beautiful in MM :-)
        • mumblebajM
          mumblebaj Module Developer @Manu85
          @Manu85 Way too much work. You are welcome to can make a PR.
            Manu85 @mumblebaj
            @mumblebaj I understand thank you for all the work you do, what is a “PR”?
            • mumblebajM
              @Manu85 PR = Pull Request which means you fork the module and make the relevant changes a push it back to the main repo. :winking_face:
                Manu85 @mumblebaj
                @mumblebaj ah ok, but I see that there are more than 2,000 views on this post, maybe someone will be interested in this! :beaming_face_with_smiling_eyes:
                  Manu85 @mumblebaj
                  @mumblebaj Hi I saw that @KristjanESPERANTO had made a football module like your Rugby module with the selection of different leagues, do you think that the module is adaptable with yours? it’s just a question :-)
                  https://github.com/0m4r/MMM-SoccerLiveScore
                  mumblebajM KristjanESPERANTOK 3 Replies Last reply Reply Quote 0
                  • mumblebajM
                    @Manu85 Hi. I do not know. If you want to ask him to create or include the rugby into his module then you are more than welcome to do so.
                    • mumblebajM
                      @Manu85 The API they use is football only.
                        Manu85 @mumblebaj
                        @mumblebaj I’m going to ask him anyway, he’s already done two or three modules for me
                        • mumblebajM
                          @Manu85 I saw your request to him. The module is not built for you and only you. Others are using it right now. You don’t seem to appreciate and understand the complexities around the data and how it the API’s are defined.
                          This module is being used by a number of people, and unless you raise a feature request and everybody agree to request will I entertain the idea. What you are asking for is not easily achievable with the way the API calls are structured.
                          For my own personal use the module is fine as is.
                          I hope you come right but this matter I consider closed now and module will remain as is.
                          • KristjanESPERANTOK
                            KristjanESPERANTO Module Developer @Manu85
                            @Manu85 said in Hello everyone, do you know if there is an MM module for rugby:
                            MMM-SoccerLiveScore is maintained by @0m4r. I don’t really deal with sports modules :-)
                              Manu85 @mumblebaj
                              @mumblebaj excuse me, I know that the module is not for me but for the community and that the more users there are the better, I think that I expressed myself badly and that the translator does not make things easier , I’m sorry if my words offended
                              • mumblebajM
                                @Manu85 No problem. As mentioned before, if you would like to personalize the module further you are more than welcome to fork it and make whatever changes you would like.
                                  Manu85 @mumblebaj
                                  @mumblebaj hi, I made an error in the correspondence for the French translation it should be:
                                  “L” = “D” and “D” = “N”
                                  sorry for this error, I ask you a lot of things and I am not capable of making a simple correspondence :-(
                                  I made the settings for the top 14 in the config.js and the following thing happens:
                                  I have the ranking table which is displayed for 20 or 30 seconds and then an empty table “Mens Rugby Unions” and 1 minute after another empty table “Rugby World Ranking” and after that it only remains on these two empty tables which it’s running every minute, I’ll give you my config.js, I don’t see where I made a mistake, thanks again
                                          		module: "MMM-Rugby",  //https://github.com/mumblebaj/MMM-Rugby/tree/main
                                          		disabled: false,
                                                          updateInterval: 1000*60*60*24,
                                  			rotateInterval: 60000,
                                                          rankingLimit: 14,
                                                          matchesLimit: 10,
                                                          matchesOlderThan: 7,
                                                          collectionType: "apiSport", // api-key required
                                                          apiSports: {
                                                              apiSportStandingLeagueId: 16,  //16=top 14
                                                              apiSportKey: "91d1ae3cdbxxxxxxxxxxxxxx",
                                                              apiSportTZ: "Europe/Paris",
                                                              numberofGamesToDisplay: 10,
                                                              apiSportsNumRankings: 14,
                                                              apiSportDaysPast: 7,
                                                              apiSportsDaysFuture: 14
                                  mumblebajM 2 Replies Last reply Reply Quote 0
                                  • mumblebajM
                                    @Manu85 Hi. For me it shows the Top14 using apiSport just fine.
                                    If you make changes to the config.js you have to restart MM in order for the changes to take effect. MM caches the config and a restart is required every time a change is made.
                                    Can you confirm that you have restarted you MM after making the changes to the config.js?
                                    You also seem to have 2x rotateInterval in the config. You only require one.
                                    I would also suggest adding and leaving the autoUpdate to the config as shown in the samples.
                                      Manu85 @mumblebaj
                                      @mumblebaj I restarted MM and also the PI I reset config.js, tell me if I made a mistake please?
                                              		disabled: false,
                                                              updateInterval: 1000*60*60,
                                      			autoUpdate: true,
                                                              rankingLimit: 14,
                                                              matchesLimit: 10,
                                                              apiSports: {
        apiSportKey: "91d1ae3cdbxxxxxxxxxx",
                                      mumblebajM 1 Reply Last reply Reply Quote 1
                                      • mumblebajM
                                        @Manu85 Your config looks fine to me. This is the config I used and it works fine for me.
                                              disabled: false,        config: {
                                                              updateInterval: 1000*60*30,
                                                              autoUpdate: true,        rotateInterval: 30000,
                                                              sport: "mru",
                                                              rankingLimit: 10,
                                                              matchesLimit: 10,
                                                              matchesOlderThan: 20,        collectionType: "apiSport",        competitions: ["Six Nations 2024", "Rugby Europe Conference 2024"],                                                     apiSports: {
        apiSportKey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
        apiSportTZ: "Africa/Johannesburg",
        apiSportsNumRankings: 10,
        // add games requirements league id for games to fetch
                                        • mumblebajM
                                          @Manu85 I have also updated the L and D translations now and pushed it.
                                            manu85340 @mumblebaj
                                            @mumblebaj i see in my config.js y don’t have sport: mru, Maybe that’s the cause! I’ll pass on the update and change this as soon as I get home, thanks.
                                            • 5 / 6
