    unable to git pull successfully
    7 Posts 3 Posters 8.2k Views 3 Watching
    • 1 Offline
      1a2a3a
      hi
      trying to update my googlephotos and am facing the error.
      error: Your local changes to the following files would be overwritten by merge:
      package-lock.json
      Please commit your changes or stash them before you merge.
      error: The following untracked working tree files would be overwritten by merge:
      .vscode/settings.json
      types/google-photos.d.ts
      types/type.d.ts
      Please move or remove them before you merge.
      so i managed to git checkout package-lock.json.
      but when i tried to git checkout .vscode/settings.json, i got the error error: pathspec ‘.vscode/settings.json’ did not match any file(s) known to git. same goes for the types/google-photos.d.ts and types/type.d.ts
      what should i do next?
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @1a2a3a
        @1a2a3a If you want to reset the module without saving your local changes, you can do this in the module’s directory:
        git fetch origin master
        git reset --hard origin/master
        git pull
        1 S 2 Replies Last reply Reply Quote 0
          sdetweil @1a2a3a
          @1a2a3a said in unable to git pull successfully:
          package-lock.json
          this file is regenerated by npm install, so just erase it
          rm package-lock.json
          but… these make no sense
          types/type.d.ts
          as they are untracked, git doesn’t do anything with them…
          but I see search results for that problem…
          looks like you were developing in the module folder… so
          you SHOULD be able to stash those files (hide them)
          one suggestion (afer erasing the package-lock.json)
          git add *
          git stash
          git pull
          after the pull,
          git stash pop
          1 1 Reply Last reply Reply Quote 0
          • 1 Offline
            1a2a3a @sdetweil
            @sdetweil did as per your mentioned but still stuck with .vscode/setting.json
              git pull
              • 1 Offline
                1a2a3a @KristjanESPERANTO
                @KristjanESPERANTO thanks, that fixed it now!
                  sdetweil @KristjanESPERANTO
                  @KristjanESPERANTO but why does this fix the problem of untracked files blocking pull? if they are untracked, they are not in the repo… I have never seen this happen
                    @sdetweil With git reset ... everything is reset hard, this fixes the problem, but does not help to explain it. I haven’t fully understood myself why git pull didn’t worked after git stash.
