    Developer Wanted To Modify Default Newsfeed Module
    31 Posts 9 Posters 13.6k Views 8 Watching
      MMRIZE @sifuhall
      @sifuhall
      Yes, that is the issue of Feed.
      Each RSS1.0/RSS2.0/XML/ATOM feed has each standard syntax, but not strictly. So every feed provider (e.g. news site) serves slightly-similar-but-different-syntax-feed.
      Your link has NO IMAGE by definition of the standard syntax, but it has a common CDATA tag to contain an image in the description really. The image doesn’t belong to the article item layer itself, but to its subcomponent description layer. It might be a kind of exception rule.
      I can add some codes to pick up that kind of image from the description of the article. But before that, if I could know which feeds should the module parse, I can make a dedicated-efficient version for your usage. To make an all-bullet-proof version is somehow inefficient. Could you tell me which feed you are considering to show on MagicMirror?
      sifuhallS 2 Replies Last reply Reply Quote 0
      • sifuhallS Offline
        sifuhall @MMRIZE
        @MMRIZE the feed I linked will be the final feed.
        Please tell me how I can pay you
        • sifuhallS Offline
          sifuhall @MMRIZE
          • M MMRIZE referenced this topic on
          • G Offline
            greedyvegan @MMRIZE
            @MMRIZE said
            how’d you add images to the article of the default news feed?
              sdetweil @greedyvegan
              @greedyvegan not default, see
              https://forum.magicmirror.builders/post/102573
              • G Offline
                greedyvegan @sdetweil
                I got my hopes up
                  @greedyvegan a different module, he does amazing work
                  G 1 Reply Last reply Reply Quote 1
                  • G Offline
                    I tried to use it but it’s not working for me.
                    it just says “no news at the moment”
                    it’s fine, I’ll just use the default newsfeed
                      MMRIZE @greedyvegan
                      @greedyvegan
                      Give me your target feed. I’ll check
                      • G Offline
                        greedyvegan
                        I’m trying two modules out:
                        MMM-anotherNewsFeed
                        MMM-NewsFeedTicker
                        the configs and css are identical (bottom_right and new feed sources
                        config.js
                        module: "MMM-anotherNewsFeed ",
                        header: "ANOTHER News Feed",
                        position: "bottom_right",
                        feeds: [
                        title: "New York Times",
                        url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml",
                        customLogo: "NYT_logo_rss_250x40.png",
                        title: "CBC World",
                        url: "https://www.cbc.ca/webfeed/rss/rss-world",
                        customLogo: "CBC_140x140.png"
                        title: "BBC World News",
                        url: "https://feeds.bbci.co.uk/news/world/rss.xml",
                        customLogo: "bbc_news_120x60.gif",
                        showImage: true,
                        showSourceTitle: true,
                        showPublishDate: true,
                        broadcastNewsFeeds: true,
                        broadcastNewsUpdates: true
                        module: "MMM-NewsFeedTicker",
                        header: "News Feed Ticker",
                        //classes: "day_scheduler",
                        feeds: [
                        title: "CBC World",
                        custom.css
                        .MMM-anotherNewsFeed. {position:relative}
                        .MMM-NewsFeedTicker. {position:relative}
                        • 1 / 4
