    Developer Wanted To Modify Default Newsfeed Module
    31 Posts 9 Posters 17.7k Views 8 Watching
    • sifuhallS
      sifuhall
      I would like to discuss prices with a developer to make make a new module based on the default newsfeed module with the following changes.
      Display image(s) included in the RSS feed.
      Add the ability to remove phrases from the description. For example, if the words “Get Ticket” appears in the description remove those words from the description.
      M 1 Reply Last reply
        MMRIZE @sifuhall
        @sifuhall
        So, is this what you want similar?
        If what you want is “censoring some improper articles”, it is already applied in original newsfeed module. (See prohibitedWords option)
        sifuhallS 1 Reply Last reply
        • sifuhallS
          sifuhall @MMRIZE
          @MMRIZE
          Thanks for the reply!
          Yes, with the image, however I want to display in list view (like the newsfeed module can do as well).
          Regarding removing words, I only want to remove words, not remove the article. For example, one of the RSS feeds has a link that says Get Tickets. I would like the feed to not display Get Tickets on the mirror.
            MMRIZE @sifuhall
            @sifuhall
            Maybe like this;
            Some test words are censored and removed already, so you cannot see them in title (and in description). (test words are “FBI”, “in data”, ‘man’, “to”)
            Anyway, it is a tiny modification of the original Mich’s default module. So real monetized reward is not fair (at least, I think)
            You can get it here;
            https://github.com/MMRIZE/MMM-anotherNewsFeed
            But if you want more than the little modification, anyway contact me.
            sifuhallS G 2 Replies Last reply
            Reply Quote 2
            • sifuhallS
              sifuhall @MMRIZE
              @MMRIZE Thank you! And of course I would love to pay you for your time.
              I do have a question. This works with the first RSS feed I tried but not the next. I validated the feed using a few online validators and the feed seems ok but it is never picked up.
              The feed is here:
              https://www.ccwky.org/parser/parser.php
              What is the best way to send payment?
                MMRIZE @sifuhall
                @sifuhall
                Yes, that is the issue of Feed.
                Each RSS1.0/RSS2.0/XML/ATOM feed has each standard syntax, but not strictly. So every feed provider (e.g. news site) serves slightly-similar-but-different-syntax-feed.
                Your link has NO IMAGE by definition of the standard syntax, but it has a common CDATA tag to contain an image in the description really. The image doesn’t belong to the article item layer itself, but to its subcomponent description layer. It might be a kind of exception rule.
                I can add some codes to pick up that kind of image from the description of the article. But before that, if I could know which feeds should the module parse, I can make a dedicated-efficient version for your usage. To make an all-bullet-proof version is somehow inefficient. Could you tell me which feed you are considering to show on MagicMirror?
                sifuhallS 2 Replies Last reply
                • sifuhallS
                  sifuhall @MMRIZE
                  @MMRIZE the feed I linked will be the final feed.
                  Please tell me how I can pay you
                  • sifuhallS
                    sifuhall @MMRIZE
                    • M MMRIZE referenced this topic on
                    • G
                      greedyvegan @MMRIZE
                      @MMRIZE said
                      how’d you add images to the article of the default news feed?
                        sdetweil @greedyvegan
                        @greedyvegan not default, see
                        https://forum.magicmirror.builders/post/102573
                        G 1 Reply Last reply
                        • G
                          greedyvegan @sdetweil
                          I got my hopes up
                            @greedyvegan a different module, he does amazing work
                            • G
                              I tried to use it but it’s not working for me.
                              it just says “no news at the moment”
                              it’s fine, I’ll just use the default newsfeed
                                MMRIZE @greedyvegan
                                @greedyvegan
                                Give me your target feed. I’ll check
                                • G
                                  greedyvegan
                                  I’m trying two modules out:
                                  MMM-anotherNewsFeed
                                  MMM-NewsFeedTicker
                                  the configs and css are identical (bottom_right and new feed sources
                                  config.js
                                  module: "MMM-anotherNewsFeed ",
                                  header: "ANOTHER News Feed",
                                  position: "bottom_right",
                                  feeds: [
                                  title: "New York Times",
                                  url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml",
                                  customLogo: "NYT_logo_rss_250x40.png",
                                  title: "CBC World",
                                  url: "https://www.cbc.ca/webfeed/rss/rss-world",
                                  customLogo: "CBC_140x140.png"
                                  title: "BBC World News",
                                  url: "https://feeds.bbci.co.uk/news/world/rss.xml",
                                  customLogo: "bbc_news_120x60.gif",
                                  showImage: true,
                                  showSourceTitle: true,
                                  showPublishDate: true,
                                  broadcastNewsFeeds: true,
                                  broadcastNewsUpdates: true
                                  module: "MMM-NewsFeedTicker",
                                  header: "News Feed Ticker",
                                  //classes: "day_scheduler",
                                  feeds: [
                                  title: "CBC World",
                                  custom.css
                                  .MMM-anotherNewsFeed. {position:relative}
                                  .MMM-NewsFeedTicker. {position:relative}
                                  S M 2 Replies Last reply
                                    @greedyvegan newsfeedticker designed to be bottom bar , full width . takes a lot of space to display all that and make it readable
                                      MMRIZE @greedyvegan
                                      @greedyvegan
                                      Even though MMM-AnotherNewsFeed was not updated for 2 years, it still works.
                                      	module: "MMM-anotherNewsFeed",
                                      	position: "bottom_bar",
                                      		feeds: [
                                      				title: "CBC World",
                                      		showImage: true,
                                      G KristjanESPERANTOK C 3 Replies Last reply
                                      • G
                                        greedyvegan @MMRIZE
                                        @MMRIZE said
                                        thank you, copied and pasted your code and it’s working.
                                        • KristjanESPERANTOK
                                          KristjanESPERANTO Module Developer @MMRIZE
                                          @MMRIZE Since more than one user is using MMM-AnotherNewsFeed, would it make sense to add it to the list of 3rd party modules? :slightly_smiling_face:
                                          Reply Quote 2
                                          • G
                                            @sdetweil said newsfeedticker designed to be bottom bar ,
                                            I totally understand what you’re saying, but:
                                            • some news articles only have seven words in their event
                                            • every newsfeed does not display an image
                                            is there a way that I can force the module to remain and not animate/blink, so the background is always visible?
                                            And can I force the article to be on the right side of the article image whether it is displayed or not?
                                            forgive me, I’m still learning, is that the display: block/flex/inline or margin:left/right % px?
