    Developer Wanted To Modify Default Newsfeed Module
    31 Posts 9 Posters 14.0k Views 8 Watching
    • sifuhallS Offline
      sifuhall @MMRIZE
      @MMRIZE Thank you! And of course I would love to pay you for your time.
      I do have a question. This works with the first RSS feed I tried but not the next. I validated the feed using a few online validators and the feed seems ok but it is never picked up.
      The feed is here:
      https://www.ccwky.org/parser/parser.php
      What is the best way to send payment?
        MMRIZE @sifuhall
        @sifuhall
        Yes, that is the issue of Feed.
        Each RSS1.0/RSS2.0/XML/ATOM feed has each standard syntax, but not strictly. So every feed provider (e.g. news site) serves slightly-similar-but-different-syntax-feed.
        Your link has NO IMAGE by definition of the standard syntax, but it has a common CDATA tag to contain an image in the description really. The image doesn’t belong to the article item layer itself, but to its subcomponent description layer. It might be a kind of exception rule.
        I can add some codes to pick up that kind of image from the description of the article. But before that, if I could know which feeds should the module parse, I can make a dedicated-efficient version for your usage. To make an all-bullet-proof version is somehow inefficient. Could you tell me which feed you are considering to show on MagicMirror?
        sifuhallS 2 Replies Last reply Reply Quote 0
        • sifuhallS Offline
          sifuhall @MMRIZE
          @MMRIZE the feed I linked will be the final feed.
          Please tell me how I can pay you
          • sifuhallS Offline
            sifuhall @MMRIZE
            • M MMRIZE referenced this topic on
            • G Offline
              greedyvegan @MMRIZE
              @MMRIZE said
              how’d you add images to the article of the default news feed?
                sdetweil @greedyvegan
                @greedyvegan not default, see
                https://forum.magicmirror.builders/post/102573
                • G Offline
                  greedyvegan @sdetweil
                  I got my hopes up
                    @greedyvegan a different module, he does amazing work
                    G 1 Reply Last reply Reply Quote 1
                    • G Offline
                      I tried to use it but it’s not working for me.
                      it just says “no news at the moment”
                      it’s fine, I’ll just use the default newsfeed
                        MMRIZE @greedyvegan
                        @greedyvegan
                        Give me your target feed. I’ll check
                        • 1 / 4
