Emergency service pharmacies in Germany
4 Posts 2 Posters 352 Views 2 Watching
  • K Offline
    KristjanESPERANTO Module Developer
    I would like to have a module that shows the current emergency pharmacies nearby. For Germany, there is for example this page for this. However, I cannot find an API or similar.
    I have already experimented a bit with parsing the website, that would be a possible way to do it. But I don’t think it’s a clean solution and I’m not sure if it would be legally okay.
    What would your approach be to implement this?
    I found notdienst_api, but it only works in bavaria. If there is no better approach, I would possibly try to extend that package.
    M 2 Replies Last reply Mar 23, 2024, 5:21 PM Reply Quote 0
      mumblebaj Module Developer @KristjanESPERANTO
        @KristjanESPERANTO I think if they didn’t want you to get “inside” they would build it better. I.e. if they didn’t want you to scrape the data they would preserve it better.
        The way i see it, you can use one of 2 URL’s to get the data and then scrape it. You require the area / postal code as input though and you can make the radius to search an option as well.
        Pharmacy for postal/area code 80331 within 20km
        https://www.aponet.de/apotheke/apothekensuche/80331/ /20
        Emergency Service 25km radius from postal code 65760
        https://www.aponet.de/apotheke/notdienstsuche/65760/ /5
        Should be easy enough to scrape the data.
        Anyway, they do provide widgets and the code for people to access the data.
        See below link:
        https://apotheken-notdienstdaten.de/aponet-download-service/
        K 1 Reply Last reply Mar 24, 2024, 12:46 AM Reply Quote 0
        • K Offline
          KristjanESPERANTO Module Developer @mumblebaj
          @mumblebaj Many thanks for the tips! :smiley:
          I have meanwhile written to the operators of the website to see if they can offer an API. If not, I will probably follow your suggested approach.
