    Everything was going so well
    52 Posts 4 Posters 21.6k Views 3 Watching
    • O Offline
      OldSunGuy @JMac
      @JMac that should be the letter (l) not a number (1) .
      sudo fdisk -l
        JMac @OldSunGuy
        @OldSunGuy well that was a great start :man_facepalming_light_skin_tone:
        if I can get the steps above to work, can I get the original SD card to work again? It’s a samsung evo micro sd and way better than the unbranded one I’ve found to try and recover the original setup.
          JMac
          I get the same issue. Sudo fdisk -i returns
          fdisk: invalid option - - ‘i’
          try 'fdisk - - help fro more information
          any thoughts?
          • mumblebajM Offline
            mumblebaj Module Developer @JMac
            @JMac That is not an i it is an l (small letter L)
              JMac @mumblebaj
              @mumblebaj that’s worked.
              I’m now presented with
              /dev/mmcblk0p1
              /dev/mmcblk0p2
              so follow @sdetweil step above and go with the second option?
                @JMac Yeah, would suggest you follow his recommendations.
                  JMac @mumblebaj
                  @mumblebaj cool. Do you have any idea why the initial SD card would be failing to launch when the pi is turned on?
                  as mentioned above it’s a good quality SD card so am I daft to consider (providing I can recover a copy of my old setup) copying it back onto to the original SD card, am I asking for trouble in the future?
                    JMac @sdetweil
                    @sdetweil so I ran e2fsck -f -v /dev/mmcblk0p2
                    got a warning about SEVERE filesystem damage.
                    went yes and got ]e2fsck : permission denied while trying to open /dev/mmcblk0p2
                    you must have r/w access to the filesystem or be root.
                    How do I get around this?
                      @JMac I am sure Sam is probably still sleeping, but you can try sudo e2fsck -f -v /dev/mmcblk0p2. This should run as root user.
                        JMac @mumblebaj
                        @mumblebaj when I run that in terminal I get,
                        e2fsck 1.46.2 (28-Feb-2021)
                        /dev/mmcblk0p2 is mounted.
                        e2fsck: cannot continue, aborting.
                        Any thoughts, is that image/setup a goner?
                        mumblebajM S 2 Replies Last reply Reply Quote 0
                        • 1 / 6
