    Google assistant
    2 Posts 2 Posters 773 Views 2 Watching
    • A
      ahmed245275111 Module Developer
      Hello, I have a problem with the Google Assistant Module with the magic mirror on raspberrypi 3 model b. The problem is when I write the auth_and_test.js node command, the file with this name is not found, and you write run token also does not work, although I changed all the previous steps correctly and the credential file was completed in the module.
      IMG-20240406-WA0000.jpg ```
        @ahmed245275111 I recommend opening a topic on the authors own forums. as he prefers support there
