Unsolved MagicMirror no longer launches
@RIKKO14 ok, the electron install problem.
can you show results of
uname -aand do
pm2 stop all cd ~/MagicMirror npm install electron@29.1.6 npm start
pi@raspberrypi:~ $ pm2 stop all cd ~/MagicMirror npm install electron@29.1.6 npm start [PM2] Applying action stopProcessId on app [all](ids: [ 0 ]) [PM2] [MagicMirror](0) ✓ ┌────┬────────────────────┬──────────┬──────┬───────────┬──────────┬──────────┐ │ id │ name │ mode │ ↺ │ status │ cpu │ memory │ ├────┼────────────────────┼──────────┼──────┼───────────┼──────────┼──────────┤ │ 0 │ MagicMirror │ fork │ 8615 │ stopped │ 0% │ 0b │ └────┴────────────────────┴──────────┴──────┴───────────┴──────────┴──────────┘ npm ERR! code ENOTEMPTY npm ERR! syscall rename npm ERR! path /home/pi/MagicMirror/node_modules/caniuse-lite npm ERR! dest /home/pi/MagicMirror/node_modules/.caniuse-lite-6h1pL5No npm ERR! errno -39 npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/caniuse-lite' -> '/home/pi/MagicMirror/node_modules/.caniuse-lite-6h1pL5No' npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_18_54_942Z-debug-0.log > magicmirror@2.27.0 start > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js App threw an error during load Error: Cannot find module 'ansis' Require stack: - /home/pi/MagicMirror/js/logger.js - /home/pi/MagicMirror/js/app.js - /home/pi/MagicMirror/js/electron.js - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js - at node:internal/modules/cjs/loader:1084:15 at Function.<anonymous> (node:electron/js2c/browser_init:2:116646) at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) at node:internal/modules/cjs/loader:929:27 at Function._load (node:electron/js2c/asar_bundle:2:13327) at Module.require (node:internal/modules/cjs/loader:1150:19) at require (node:internal/modules/cjs/helpers:121:18) at /home/pi/MagicMirror/js/logger.js:5:19 at Object.<anonymous> (/home/pi/MagicMirror/js/logger.js:46:2) at Module._compile (node:internal/modules/cjs/loader:1271:14) at Object..js (node:internal/modules/cjs/loader:1326:10) at Module.load (node:internal/modules/cjs/loader:1126:32) at node:internal/modules/cjs/loader:967:12 at Function._load (node:electron/js2c/asar_bundle:2:13327) at Module.require (node:internal/modules/cjs/loader:1150:19) at require (node:internal/modules/cjs/helpers:121:18) A JavaScript error occurred in the main process Uncaught Exception: Error: Cannot find module 'ansis' Require stack: - /home/pi/MagicMirror/js/logger.js - /home/pi/MagicMirror/js/app.js - /home/pi/MagicMirror/js/electron.js - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js - at node:internal/modules/cjs/loader:1084:15 at Function.<anonymous> (node:electron/js2c/browser_init:2:116646) at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) at node:internal/modules/cjs/loader:929:27 at Function._load (node:electron/js2c/asar_bundle:2:13327) at Module.require (node:internal/modules/cjs/loader:1150:19) at require (node:internal/modules/cjs/helpers:121:18) at /home/pi/MagicMirror/js/logger.js:5:19 at Object.<anonymous> (/home/pi/MagicMirror/js/logger.js:46:2) at Module._compile (node:internal/modules/cjs/loader:1271:14) at Object..js (node:internal/modules/cjs/loader:1326:10) at Module.load (node:internal/modules/cjs/loader:1126:32) at node:internal/modules/cjs/loader:967:12 at Function._load (node:electron/js2c/asar_bundle:2:13327) at Module.require (node:internal/modules/cjs/loader:1150:19) at require (node:internal/modules/cjs/helpers:121:18) Warning: vkCreateInstance: Found no drivers! Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88) at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458) at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344) at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266) at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521) Warning: eglChooseConfig returned zero configs at Create (../../third_party/dawn/src/dawn/native/opengl/ContextEGL.cpp:52) at Create (../../third_party/dawn/src/dawn/native/opengl/PhysicalDeviceGL.cpp:97)
pi@raspberrypi:~ $ npm install ansis up to date, audited 2 packages in 1s found 0 vulnerabilities pi@raspberrypi:~ $ pm2 stop all cd ~/MagicMirror npm install electron@29.1.6 npm start [PM2] Applying action stopProcessId on app [all](ids: [ 0 ]) [PM2] [MagicMirror](0) ✓ ┌────┬────────────────────┬──────────┬──────┬───────────┬──────────┬──────────┐ │ id │ name │ mode │ ↺ │ status │ cpu │ memory │ ├────┼────────────────────┼──────────┼──────┼───────────┼──────────┼──────────┤ │ 0 │ MagicMirror │ fork │ 8615 │ stopped │ 0% │ 0b │ └────┴────────────────────┴──────────┴──────┴───────────┴──────────┴──────────┘ npm ERR! code ENOTEMPTY npm ERR! syscall rename npm ERR! path /home/pi/MagicMirror/node_modules/caniuse-lite npm ERR! dest /home/pi/MagicMirror/node_modules/.caniuse-lite-6h1pL5No npm ERR! errno -39 npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/caniuse-lite' -> '/home/pi/MagicMirror/node_modules/.caniuse-lite-6h1pL5No' npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_37_54_575Z-debug-0.log > magicmirror@2.27.0 start > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js [2024-04-26 18:38:03.262] [ERROR] App threw an error during load [2024-04-26 18:38:03.265] [ERROR] Error: Cannot find module 'socket.io' Require stack: - /home/pi/MagicMirror/js/server.js - /home/pi/MagicMirror/js/app.js - /home/pi/MagicMirror/js/electron.js - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js - at node:internal/modules/cjs/loader:1084:15 at Function.<anonymous> (node:electron/js2c/browser_init:2:116646) at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) at node:internal/modules/cjs/loader:929:27 at Function._load (node:electron/js2c/asar_bundle:2:13327) at Module.require (node:internal/modules/cjs/loader:1150:19) at require (node:internal/modules/cjs/helpers:121:18) at Object.<anonymous> (/home/pi/MagicMirror/js/server.js:8:18) at Module._compile (node:internal/modules/cjs/loader:1271:14) at Object..js (node:internal/modules/cjs/loader:1326:10) at Module.load (node:internal/modules/cjs/loader:1126:32) at node:internal/modules/cjs/loader:967:12 at Function._load (node:electron/js2c/asar_bundle:2:13327) at Module.require (node:internal/modules/cjs/loader:1150:19) at require (node:internal/modules/cjs/helpers:121:18) at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:9:16) A JavaScript error occurred in the main process Uncaught Exception: Error: Cannot find module 'socket.io' Require stack: - /home/pi/MagicMirror/js/server.js - /home/pi/MagicMirror/js/app.js - /home/pi/MagicMirror/js/electron.js - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js - at node:internal/modules/cjs/loader:1084:15 at Function.<anonymous> (node:electron/js2c/browser_init:2:116646) at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) at node:internal/modules/cjs/loader:929:27 at Function._load (node:electron/js2c/asar_bundle:2:13327) at Module.require (node:internal/modules/cjs/loader:1150:19) at require (node:internal/modules/cjs/helpers:121:18) at Object.<anonymous> (/home/pi/MagicMirror/js/server.js:8:18) at Module._compile (node:internal/modules/cjs/loader:1271:14) at Object..js (node:internal/modules/cjs/loader:1326:10) at Module.load (node:internal/modules/cjs/loader:1126:32) at node:internal/modules/cjs/loader:967:12 at Function._load (node:electron/js2c/asar_bundle:2:13327) at Module.require (node:internal/modules/cjs/loader:1150:19) at require (node:internal/modules/cjs/helpers:121:18) at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:9:16)
pi@raspberrypi:~ $ npm run install-mm npm ERR! Missing script: "install-mm" npm ERR! npm ERR! Did you mean this? npm ERR! npm install # Install a package npm ERR! npm ERR! To see a list of scripts, run: npm ERR! npm run npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_46_42_166Z-debug-0.log pi@raspberrypi:~ $
@sdetweil (inside MagicMirror Folder)
maybe: (in this case)
cd ~/MagicMirror rm -rf node_modules git reset --hard origin git pull npm run install-mm
no ?
@bugsounet I want to see what the problem is, not just wipe everything
@sdetweil : yes… but inside MM² Folder not outside ;)
