    MagicMirror no longer launches
    38 Posts 4 Posters 12.0k Views 3 Watching
      sdetweil @RIKKO14
      @RIKKO14 yes, it’s stupid. run the fixuppm2 script from my scripts page
        RIKKO14 @sdetweil
        @sdetweil this script : ?
        bash -c  "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
          sdetweil @RIKKO14
          @RIKKO14 no… from my git repo
            RIKKO14 @sdetweil
            @sdetweil so this one :
            bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
              sdetweil @RIKKO14
              @RIKKO14 yes
                RIKKO14 @sdetweil
                  sdetweil @RIKKO14
                  @RIKKO14 and reboot
                    RIKKO14 @sdetweil
                    @sdetweil I reboot my Pi but It stile the same sceen…
                    pm2 doesn’t launch…
                      sdetweil @RIKKO14
                      @RIKKO14 ok, show
                      output of
                      pm2 status
                      pm2 logs --lines=50
                        RIKKO14 @sdetweil
                        @sdetweil always stile the same problem of “Electron”…
                          sdetweil @RIKKO14
                          @RIKKO14 ok, the electron install problem.
                          can you show results of
                          uname -a
                          and do
                          pm2 stop all
                          npm install electron@29.1.6
                           npm start
                            RIKKO14 @sdetweil
                            pi@raspberrypi:~ $ pm2 stop all
                             npm start
                            [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                            [PM2] [MagicMirror](0) ✓
                            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                            │ 0  │ MagicMirror        │ fork     │ 8615 │ stopped   │ 0%       │ 0b       │
                            npm ERR! code ENOTEMPTY
                            npm ERR! syscall rename
                            npm ERR! path /home/pi/MagicMirror/node_modules/caniuse-lite
                            npm ERR! dest /home/pi/MagicMirror/node_modules/.caniuse-lite-6h1pL5No
                            npm ERR! errno -39
                            npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/caniuse-lite' -> '/home/pi/MagicMirror/node_modules/.caniuse-lite-6h1pL5No'
                            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_18_54_942Z-debug-0.log
                            > magicmirror@2.27.0 start
                            App threw an error during load
                            Error: Cannot find module 'ansis'
                            Require stack:
                            - /home/pi/MagicMirror/js/logger.js
                                at node:internal/modules/cjs/loader:1084:15
                                at Function.<anonymous> (node:electron/js2c/browser_init:2:116646)
                                at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                at node:internal/modules/cjs/loader:929:27
                                at Function._load (node:electron/js2c/asar_bundle:2:13327)
                                at Module.require (node:internal/modules/cjs/loader:1150:19)
                                at require (node:internal/modules/cjs/helpers:121:18)
                                at /home/pi/MagicMirror/js/logger.js:5:19
                                at Object.<anonymous> (/home/pi/MagicMirror/js/logger.js:46:2)
                                at Module._compile (node:internal/modules/cjs/loader:1271:14)
                                at Object..js (node:internal/modules/cjs/loader:1326:10)
                                at Module.load (node:internal/modules/cjs/loader:1126:32)
                                at node:internal/modules/cjs/loader:967:12
                            A JavaScript error occurred in the main process
                            Uncaught Exception:
                            Require stack:
                            Warning: vkCreateInstance: Found no drivers!
                            Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                                at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                                at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                                at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                                at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                                at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                            Warning: eglChooseConfig returned zero configs
                                at Create (../../third_party/dawn/src/dawn/native/opengl/ContextEGL.cpp:52)
                                at Create (../../third_party/dawn/src/dawn/native/opengl/PhysicalDeviceGL.cpp:97)
                              sdetweil @RIKKO14
                              @RIKKO14 said in MagicMirror no longer launches:
                              ‘ansis’
                              npm install ansis
                              and try again
                                RIKKO14 @sdetweil
                                pi@raspberrypi:~ $ npm install ansis
                                up to date, audited 2 packages in 1s
                                found 0 vulnerabilities
                                 npm start
                                npm ERR! errno -39
                                npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_37_54_575Z-debug-0.log
                                [2024-04-26 18:38:03.262] [ERROR] App threw an error during load
                                [2024-04-26 18:38:03.265] [ERROR] Error: Cannot find module 'socket.io'
                                Require stack:
                                - /home/pi/MagicMirror/js/server.js
                                    at Object.<anonymous> (/home/pi/MagicMirror/js/server.js:8:18)
                                    at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:9:16)
                                Uncaught Exception:
                                Require stack:
                                  sdetweil @RIKKO14
                                  @RIKKO14 sounds like the npm install for MagicMirror failed
                                  do
                                  npm run install-mm
                                    RIKKO14 @sdetweil
                                    pi@raspberrypi:~ $ npm run install-mm
                                    npm ERR! Missing script: "install-mm"
                                    npm ERR!
                                    npm ERR! Did you mean this?
                                    npm ERR!     npm install # Install a package
                                    npm ERR!
                                    npm ERR! To see a list of scripts, run:
                                    npm ERR!   npm run
                                    npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_46_42_166Z-debug-0.log
                                    pi@raspberrypi:~ $
                                      sdetweil @RIKKO14
                                      @RIKKO14 ok, even worse, the git pull failed.
                                      do
                                      git pull
                                      show the output
                                      bugsounetB 1 Reply Last reply Reply Quote 0
                                      • bugsounetB
                                        bugsounet Banned @sdetweil
                                        @sdetweil (inside MagicMirror Folder)
                                        maybe: (in this case)
                                        rm -rf node_modules
                                        git reset --hard origin
                                        git pull
                                        npm run install-mm
                                        no ?
                                          sdetweil @bugsounet
                                          @bugsounet I want to see what the problem is, not just wipe everything
                                          • bugsounetB
                                            @sdetweil : yes… but inside MM² Folder not outside ;)
