    MagicMirror no longer launches
    38 Posts 4 Posters 12.3k Views 3 Watching
      RIKKO14 @sdetweil
      pi@raspberrypi:~ $ pm2 stop all
      pm2 flush
      pm2 status
      >>>> In-memory PM2 is out-of-date, do:
      >>>> $ pm2 update
      In memory PM2 version: 5.2.2
      Local PM2 version: 5.3.1
      [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
      [PM2] [MagicMirror](0) ✓
      │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
      │ 0  │ MagicMirror        │ fork     │ 567… │ stopped   │ 0%       │ 0b       │
      [PM2] Flushing /home/pi/.pm2/pm2.log
      >>>> $ pm2 update
      [PM2] Flushing:
      [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
      [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
      [PM2] Logs flushed
      >>>> $ pm2 update
      pi@raspberrypi:~ $ pm2 start MagicMirror
      >>>> $ pm2 update
      [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
      [PM2] Process successfully started
      │ 0  │ MagicMirror        │ fork     │ 567… │ online    │ 0%       │ 2.7mb    │
      pm2 logs --lines=50 >somefile.txt
       ctrl-c to stop log output
      >>>> $ pm2 update
        sdetweil @RIKKO14
        @RIKKO14 ok, do the
        pm2 update as it says
        probably have to do
        sudo pm2 update
        as it is installed globally in protected folders
        R 1 Reply Last reply
          RIKKO14 @sdetweil
            sdetweil @RIKKO14
            @RIKKO14 yes, it’s stupid. run the fixuppm2 script from my scripts page
              RIKKO14 @sdetweil
              @sdetweil this script : ?
              bash -c  "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
                sdetweil @RIKKO14
                @RIKKO14 no… from my git repo
                  RIKKO14 @sdetweil
                  @sdetweil so this one :
                  bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                    sdetweil @RIKKO14
                    @RIKKO14 yes
                      RIKKO14 @sdetweil
                        sdetweil @RIKKO14
                        @RIKKO14 and reboot
                          RIKKO14 @sdetweil
                          @sdetweil I reboot my Pi but It stile the same sceen…
                          pm2 doesn’t launch…
                            sdetweil @RIKKO14
                            @RIKKO14 ok, show
                            output of
                            pm2 status
                            pm2 logs --lines=50
                              RIKKO14 @sdetweil
                              @sdetweil always stile the same problem of “Electron”…
                                sdetweil @RIKKO14
                                @RIKKO14 ok, the electron install problem.
                                can you show results of
                                uname -a
                                and do
                                pm2 stop all
                                npm install electron@29.1.6
                                 npm start
                                  RIKKO14 @sdetweil
                                   npm start
                                  │ 0  │ MagicMirror        │ fork     │ 8615 │ stopped   │ 0%       │ 0b       │
                                  npm ERR! code ENOTEMPTY
                                  npm ERR! syscall rename
                                  npm ERR! path /home/pi/MagicMirror/node_modules/caniuse-lite
                                  npm ERR! dest /home/pi/MagicMirror/node_modules/.caniuse-lite-6h1pL5No
                                  npm ERR! errno -39
                                  npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/caniuse-lite' -> '/home/pi/MagicMirror/node_modules/.caniuse-lite-6h1pL5No'
                                  npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_18_54_942Z-debug-0.log
                                  > magicmirror@2.27.0 start
                                  App threw an error during load
                                  Error: Cannot find module 'ansis'
                                  Require stack:
                                  - /home/pi/MagicMirror/js/logger.js
                                      at node:internal/modules/cjs/loader:1084:15
                                      at Function.<anonymous> (node:electron/js2c/browser_init:2:116646)
                                      at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                      at node:internal/modules/cjs/loader:929:27
                                      at Function._load (node:electron/js2c/asar_bundle:2:13327)
                                      at Module.require (node:internal/modules/cjs/loader:1150:19)
                                      at require (node:internal/modules/cjs/helpers:121:18)
                                      at /home/pi/MagicMirror/js/logger.js:5:19
                                      at Object.<anonymous> (/home/pi/MagicMirror/js/logger.js:46:2)
                                      at Module._compile (node:internal/modules/cjs/loader:1271:14)
                                      at Object..js (node:internal/modules/cjs/loader:1326:10)
                                      at Module.load (node:internal/modules/cjs/loader:1126:32)
                                      at node:internal/modules/cjs/loader:967:12
                                  A JavaScript error occurred in the main process
                                  Uncaught Exception:
                                  Require stack:
                                  Warning: vkCreateInstance: Found no drivers!
                                  Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                                      at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                                      at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                                      at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                                      at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                                      at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                                  Warning: eglChooseConfig returned zero configs
                                      at Create (../../third_party/dawn/src/dawn/native/opengl/ContextEGL.cpp:52)
                                      at Create (../../third_party/dawn/src/dawn/native/opengl/PhysicalDeviceGL.cpp:97)
                                    sdetweil @RIKKO14
                                    @RIKKO14 said in MagicMirror no longer launches:
                                    ‘ansis’
                                    npm install ansis
                                    and try again
                                      RIKKO14 @sdetweil
                                      pi@raspberrypi:~ $ npm install ansis
                                      up to date, audited 2 packages in 1s
                                      found 0 vulnerabilities
                                       npm start
                                      npm ERR! errno -39
                                      npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_37_54_575Z-debug-0.log
                                      [2024-04-26 18:38:03.262] [ERROR] App threw an error during load
                                      [2024-04-26 18:38:03.265] [ERROR] Error: Cannot find module 'socket.io'
                                      Require stack:
                                      - /home/pi/MagicMirror/js/server.js
                                          at Object.<anonymous> (/home/pi/MagicMirror/js/server.js:8:18)
                                          at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:9:16)
                                      Uncaught Exception:
                                      Require stack:
                                        sdetweil @RIKKO14
                                        @RIKKO14 sounds like the npm install for MagicMirror failed
                                        do
                                        npm run install-mm
                                          RIKKO14 @sdetweil
                                          pi@raspberrypi:~ $ npm run install-mm
                                          npm ERR! Missing script: "install-mm"
                                          npm ERR!
                                          npm ERR! Did you mean this?
                                          npm ERR!     npm install # Install a package
                                          npm ERR!
                                          npm ERR! To see a list of scripts, run:
                                          npm ERR!   npm run
                                          npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_46_42_166Z-debug-0.log
                                          pi@raspberrypi:~ $
                                          S 2 Replies Last reply
                                            sdetweil @RIKKO14
                                            @RIKKO14 ok, even worse, the git pull failed.
                                            do
                                            git pull
                                            show the output
                                            bugsounetB 1 Reply Last reply
