    MagicMirror no longer launches
    38 Posts 4 Posters 11.2k Views 3 Watching
      sdetweil @mumblebaj
      @RIKKO14 because MagicMirror now uses a pm2 library inside, we have a version conflict…(I think)
      do
      sudo npm install pm2 -g
      then reboot
        RIKKO14 @sdetweil
        @sdetweil So, I do :
        then I reboot my Pi but the problem stile the same, I Have this screen :
          sdetweil @RIKKO14
          @RIKKO14 your second screen is only the top.
          open a terminal window and
          do
          pm2 stop all
          pm2 flush
          pm2 status
          should show MagicMirror as the pgm to run
          then do
          pm2 start MagicMirror
          wait
          does it appear on screen?
          if not do
          pm2 stop all
          pm2 logs --lines=50 >somefile.txt
           ctrl-c to stop log output
          show content of somefile.txt here
          BR CAREFUL some log info will expose your calendar url…
          edit somefile.txt and xxx out the private part.of url
            RIKKO14 @sdetweil
            pi@raspberrypi:~ $ pm2 stop all
            pm2 flush
            pm2 status
            >>>> In-memory PM2 is out-of-date, do:
            >>>> $ pm2 update
            In memory PM2 version: 5.2.2
            Local PM2 version: 5.3.1
            [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
            [PM2] [MagicMirror](0) ✓
            │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
            │ 0  │ MagicMirror        │ fork     │ 567… │ stopped   │ 0%       │ 0b       │
            [PM2] Flushing /home/pi/.pm2/pm2.log
            >>>> $ pm2 update
            [PM2] Flushing:
            [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
            [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
            [PM2] Logs flushed
            >>>> $ pm2 update
            pi@raspberrypi:~ $ pm2 start MagicMirror
            >>>> $ pm2 update
            [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
            [PM2] Process successfully started
            │ 0  │ MagicMirror        │ fork     │ 567… │ online    │ 0%       │ 2.7mb    │
            >>>> $ pm2 update
              sdetweil @RIKKO14
              @RIKKO14 ok, do the
              pm2 update as it says
              probably have to do
              sudo pm2 update
              as it is installed globally in protected folders
                RIKKO14 @sdetweil
                  sdetweil @RIKKO14
                  @RIKKO14 yes, it’s stupid. run the fixuppm2 script from my scripts page
                    RIKKO14 @sdetweil
                    @sdetweil this script : ?
                    bash -c  "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
                      sdetweil @RIKKO14
                      @RIKKO14 no… from my git repo
                        RIKKO14 @sdetweil
                        @sdetweil so this one :
                        bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                          sdetweil @RIKKO14
                          @RIKKO14 yes
                            RIKKO14 @sdetweil
                              sdetweil @RIKKO14
                              @RIKKO14 and reboot
                                RIKKO14 @sdetweil
                                @sdetweil I reboot my Pi but It stile the same sceen…
                                pm2 doesn’t launch…
                                  sdetweil @RIKKO14
                                  @RIKKO14 ok, show
                                  output of
                                  pm2 status
                                  pm2 logs --lines=50
                                    RIKKO14 @sdetweil
                                    @sdetweil always stile the same problem of “Electron”…
                                      sdetweil @RIKKO14
                                      @RIKKO14 ok, the electron install problem.
                                      can you show results of
                                      uname -a
                                      and do
                                      pm2 stop all
                                      npm install electron@29.1.6
                                       npm start
                                        RIKKO14 @sdetweil
                                         npm start
                                        │ 0  │ MagicMirror        │ fork     │ 8615 │ stopped   │ 0%       │ 0b       │
                                        npm ERR! code ENOTEMPTY
                                        npm ERR! syscall rename
                                        npm ERR! path /home/pi/MagicMirror/node_modules/caniuse-lite
                                        npm ERR! dest /home/pi/MagicMirror/node_modules/.caniuse-lite-6h1pL5No
                                        npm ERR! errno -39
                                        npm ERR! ENOTEMPTY: directory not empty, rename '/home/pi/MagicMirror/node_modules/caniuse-lite' -> '/home/pi/MagicMirror/node_modules/.caniuse-lite-6h1pL5No'
                                        npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_18_54_942Z-debug-0.log
                                        > magicmirror@2.27.0 start
                                        App threw an error during load
                                        Error: Cannot find module 'ansis'
                                        Require stack:
                                        - /home/pi/MagicMirror/js/logger.js
                                            at node:internal/modules/cjs/loader:1084:15
                                            at Function.<anonymous> (node:electron/js2c/browser_init:2:116646)
                                            at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                            at node:internal/modules/cjs/loader:929:27
                                            at Function._load (node:electron/js2c/asar_bundle:2:13327)
                                            at Module.require (node:internal/modules/cjs/loader:1150:19)
                                            at require (node:internal/modules/cjs/helpers:121:18)
                                            at /home/pi/MagicMirror/js/logger.js:5:19
                                            at Object.<anonymous> (/home/pi/MagicMirror/js/logger.js:46:2)
                                            at Module._compile (node:internal/modules/cjs/loader:1271:14)
                                            at Object..js (node:internal/modules/cjs/loader:1326:10)
                                            at Module.load (node:internal/modules/cjs/loader:1126:32)
                                            at node:internal/modules/cjs/loader:967:12
                                        A JavaScript error occurred in the main process
                                        Uncaught Exception:
                                        Require stack:
                                        Warning: vkCreateInstance: Found no drivers!
                                        Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                                            at CheckVkSuccessImpl (../../third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                                            at CreateVkInstance (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                                            at Initialize (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                                            at Create (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                                            at operator() (../../third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                                        Warning: eglChooseConfig returned zero configs
                                            at Create (../../third_party/dawn/src/dawn/native/opengl/ContextEGL.cpp:52)
                                            at Create (../../third_party/dawn/src/dawn/native/opengl/PhysicalDeviceGL.cpp:97)
                                          sdetweil @RIKKO14
                                          @RIKKO14 said in MagicMirror no longer launches:
                                          ‘ansis’
                                          npm install ansis
                                          and try again
                                            RIKKO14 @sdetweil
                                            pi@raspberrypi:~ $ npm install ansis
                                            up to date, audited 2 packages in 1s
                                            found 0 vulnerabilities
                                             npm start
                                            npm ERR! errno -39
                                            npm ERR! A complete log of this run can be found in: /home/pi/.npm/_logs/2024-04-26T16_37_54_575Z-debug-0.log
                                            [2024-04-26 18:38:03.262] [ERROR] App threw an error during load
                                            [2024-04-26 18:38:03.265] [ERROR] Error: Cannot find module 'socket.io'
                                            Require stack:
                                            - /home/pi/MagicMirror/js/server.js
                                                at Object.<anonymous> (/home/pi/MagicMirror/js/server.js:8:18)
                                                at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:9:16)
                                            Uncaught Exception:
                                            Require stack:
