    MagicMirror no longer launches
    38 Posts 4 Posters 11.5k Views 3 Watching
      RIKKO14
      my Magic Mirror hasn’t been working for several weeks…
      I updated by :
      git reset --hard && git pull && npm install
      and since then it no longer launches I just have this screen :
      what should I do ?
      Thank you for your help
      • mumblebajM Offline
        mumblebaj Module Developer @RIKKO14
        @RIKKO14 My suggestion would be to use the script from Sam. See his Github for script details. Use his upgrade script .
        Run the upgrade script and then run it with apply
          RIKKO14 @mumblebaj
          @mumblebaj I do, but :
          pi@raspberrypi:~ $ bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
          doing test run = false
          Minimum Node version: v20.8.0
          Installed Node version: v20.8.0
          No Node.js upgrade necessary.
          Minimum npm version: V10.1.0
          Installed npm version: V10.1.0
          No npm upgrade necessary.
          computing size, want /var/swap=3762MByte, restricting to config limit: 2048MBytes, checking existing: deleting wrong size file (104857600), generating swapfile ... of 2048MBytes
          saving custom.css
          local version 2.27.0 already same as master 2.27.0
          restoring custom.css
          pi@raspberrypi:~ $
          The screen stile the same…
          mumblebajM 2 Replies Last reply Reply Quote 0
            @RIKKO14 I know Sam would want to have a look at the upgrade log. Can you check that for any errors? I think it is in the installers directory.
              @RIKKO14 Also, are there any errors where you start MM? If you start it using pm2 then the pm2 logs need to be checked. If NPM then check the terminal where you run npm from.
                RIKKO14 @mumblebaj
                @mumblebaj sorry I don’t anderstand what to do… can you give the scrip to write in my terminal ?
                  @RIKKO14 How do you start MagicMirror?
                    RIKKO14 @mumblebaj
                    @mumblebaj with pm2
                      @RIKKO14 You should then be able to run pm2 logs --lines 50 and that should return the details from the pm2 log. Hopefully it has any error details.
                        sdetweil @mumblebaj
                        @RIKKO14 because MagicMirror now uses a pm2 library inside, we have a version conflict…(I think)
                        do
                        sudo npm install pm2 -g
                        then reboot
                          RIKKO14 @sdetweil
                          @sdetweil So, I do :
                          then I reboot my Pi but the problem stile the same, I Have this screen :
                            sdetweil @RIKKO14
                            @RIKKO14 your second screen is only the top.
                            open a terminal window and
                            do
                            pm2 stop all
                            pm2 flush
                            pm2 status
                            should show MagicMirror as the pgm to run
                            then do
                            pm2 start MagicMirror
                            wait
                            does it appear on screen?
                            if not do
                            pm2 stop all
                            pm2 logs --lines=50 >somefile.txt
                             ctrl-c to stop log output
                            show content of somefile.txt here
                            BR CAREFUL some log info will expose your calendar url…
                            edit somefile.txt and xxx out the private part.of url
                              RIKKO14 @sdetweil
                              pi@raspberrypi:~ $ pm2 stop all
                              pm2 flush
                              pm2 status
                              >>>> In-memory PM2 is out-of-date, do:
                              >>>> $ pm2 update
                              In memory PM2 version: 5.2.2
                              Local PM2 version: 5.3.1
                              [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                              [PM2] [MagicMirror](0) ✓
                              │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                              │ 0  │ MagicMirror        │ fork     │ 567… │ stopped   │ 0%       │ 0b       │
                              [PM2] Flushing /home/pi/.pm2/pm2.log
                              >>>> $ pm2 update
                              [PM2] Flushing:
                              [PM2] /home/pi/.pm2/logs/MagicMirror-out.log
                              [PM2] /home/pi/.pm2/logs/MagicMirror-error.log
                              [PM2] Logs flushed
                              >>>> $ pm2 update
                              pi@raspberrypi:~ $ pm2 start MagicMirror
                              >>>> $ pm2 update
                              [PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
                              [PM2] Process successfully started
                              │ 0  │ MagicMirror        │ fork     │ 567… │ online    │ 0%       │ 2.7mb    │
                              >>>> $ pm2 update
                                sdetweil @RIKKO14
                                @RIKKO14 ok, do the
                                pm2 update as it says
                                probably have to do
                                sudo pm2 update
                                as it is installed globally in protected folders
                                  RIKKO14 @sdetweil
                                    sdetweil @RIKKO14
                                    @RIKKO14 yes, it’s stupid. run the fixuppm2 script from my scripts page
                                      RIKKO14 @sdetweil
                                      @sdetweil this script : ?
                                      bash -c  "$(curl -sL  https://www.dropbox.com/s/cy2z7lbkpifcbrk/fixuppm2.sh?dl=0)"
                                        sdetweil @RIKKO14
                                        @RIKKO14 no… from my git repo
                                          RIKKO14 @sdetweil
                                          @sdetweil so this one :
                                          bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
                                            sdetweil @RIKKO14
                                            @RIKKO14 yes
