    Show calendar based on IP Address accessed
    68 Posts 3 Posters 33.3k Views 3 Watching
      MMRIZE @Spinster
      @Spinster
      Ah I suddenly remember that getting Internal IP with only JavaScript on client browseris hard.
      Hmmm another approach might be needed.
        sdetweil @MMRIZE
        @MMRIZE that is why you need the express api call…
        I would make a separate module that has ip in div, not shown, but w id
        then call in calendar is document.get…
        compare, your way or on cal entries
        more synchronous…
          MMRIZE @sdetweil
          Yes. I thought a small module with node_helper that could return clients’ ip as a result of REST api call from calendar module.
            sdetweil @MMRIZE
            @MMRIZE and that module calls its own rest call publishes the address in its getDom() result, with id= on div
            and then cal module can use synchronous document.getElementsById()
            to get that value.
              @MMRIZE @Spinster
              so the little module is
              https://github.com/sdetweil/getip
              and it does correctly return the ip address of the client… tested from 4 different systems to the same MM…
              see later post for final solution
                Spinster @sdetweil
                @sdetweil @MMRIZE
                Wow, you are quick, you have given me some homework. Will use your code and get back with the result.
                Thank you so much for your patience and understanding.
                  Spinster @sdetweil
                  I tried your code, but find that once I include getip module in config.js, I am not seeing any output for calendar. Is this the expected output. Without getip module, I find that client_ip = document.getElementById("getip is returning null.Please advice
                  S M 3 Replies Last reply Reply Quote 0
                    sdetweil @Spinster
                    @Spinstersee later post
                      MMRIZE @Spinster
                      @Spinster
                      By the way, which client are you using? Electron? Or Browser?
                        Spinster @MMRIZE
                        @MMRIZE Browser as of now.
                        I also tried using express ipfilter, but the problem is I don’t know how to use it in module.js, it is throwing error saying ipfilter not known etc
                          sdetweil @Spinster
                          @Spinster well, here is a working example, in addition to the other code already
                          watch out if using address AND MM host system not included. as it won’t show either…
                          one could make the ipaddress in cal a list (of ip addresses) similar to what @MMRIZE does…
                          I don’t like adding the extra block,
                          just add the var to the thing that matters…
                          see later post
                            MMRIZE @Spinster
                            @Spinster
                            With getip of @sdetweil and MMM-ModuleMonkeyPatch, I did it. (You don’t have to modify the original source code for future-proof.)
                            Example.
                            Server is running on 192.168.178.63 and I run 2 clients on 192.168.178.22 and 192.168.178.63.
                            Both 2 clients can show different set of calendars.
                            	module: "MMM-ModuleMonkeyPatch",
                            		patches: [
                            				method: "socketNotificationReceived",
                            				patch: async function (original, args) {
                            					const [ notification, payload ] = args
                            					if (notification === "CALENDAR_EVENTS") {
                            						const calendarName = this.config.calendars.find((cal) => cal.url === payload?.url)?.name
                            						const r = await fetch('http://192.168.178.63:8080/modules/getip')
                            						const ip = JSON.parse(await r.text())?.[ 'address' ] ?? null
                            						if (!this.config.clientMap?.[ ip ]?.includes(calendarName)) {
                            							return original(notification, { ...payload, events: [] })
                            					return original(notification, payload)
                            	module: "getip",
                            	header: "US Holidays",
                            		clientMap: {
                            			"192.168.178.63": [ "cal1", "cal2", "cal3" ],
                            			"192.168.178.22": ["cal3", "cal4", "cal5"]
                            				url: "...",
                            				url: "...",
                            				url: "...",
                            				url: "...",
                            				url: "...",
                            TO Improve
                            Whenever notification CALENDAR_EVENTS coming, getip is called. After first execution, to store IP on the localStorage or cookie would be better.
                            S S 2 Replies Last reply Reply Quote 0
                              Spinster @sdetweil
                              @sdetweil will express ipfilter be useful? Similar to whitelist, can we try something
                                sdetweil @Spinster
                                @Spinster no… as its in the wrong place… (inside node_helper…) we NEED the ip address to compare with
                                just get it and return . one time
                                  sdetweil @MMRIZE
                                  @MMRIZE said in Show calendar based on IP Address accessed:
                                  BUT you are fetching cal for system not going to use it… SOME cals are 1000’s of entries especially old
                                  that have to be processed… this is a bad waste of resources…
                                  and this exposes a cal problem, as if u fetch http://xyz on client 1 and client 2 and client 3, we fetch it 3 times. also bad
                                  this could also lead to different clients showing different data between fetchIntervals…
                                    MMRIZE @sdetweil
                                    @sdetweil said in Show calendar based on IP Address accessed:
                                    I Can’t understand your point.
                                    My code is just small injection that does filtering out calendars by condition on socketNotificationReceived. No additional fetching is needed.
                                      MMRIZE @sdetweil
                                      Well, if that is the issue, we need a new “calendar” module that can ignore duplicated feed on addCalendar.
                                      Regardless of my code, the original calendar module will fetch a same feed multiply on multi clients. It’s MM’s limitation.
                                        sdetweil @MMRIZE
                                        @MMRIZE yes
                                        @Spinster
                                        see later post
                                          sdetweil @MMRIZE
                                          AFTER fetching… so throw away data, which we fetched , knowing we wouldn’t use it…
                                            Spinster @MMRIZE
                                            @MMRIZE I tried it, but it is still showing the calendar even if there is no calendar defined for the ip. I edited only the config.js file and added your code. Modified the calendars to suite mine. I could see even if there is no calendar defined for a particular ip. Please advice
                                            • 2 / 4
