    Show calendar based on IP Address accessed
    68 Posts 3 Posters 34.1k Views 3 Watching
      Spinster @sdetweil
      I tried your code, but find that once I include getip module in config.js, I am not seeing any output for calendar. Is this the expected output. Without getip module, I find that client_ip = document.getElementById("getip is returning null.Please advice
      S M 3 Replies Last reply Reply Quote 0
        sdetweil @Spinster
        @Spinstersee later post
          MMRIZE @Spinster
          @Spinster
          By the way, which client are you using? Electron? Or Browser?
            Spinster @MMRIZE
            @MMRIZE Browser as of now.
            I also tried using express ipfilter, but the problem is I don’t know how to use it in module.js, it is throwing error saying ipfilter not known etc
              sdetweil @Spinster
              @Spinster well, here is a working example, in addition to the other code already
              watch out if using address AND MM host system not included. as it won’t show either…
              one could make the ipaddress in cal a list (of ip addresses) similar to what @MMRIZE does…
              I don’t like adding the extra block,
              just add the var to the thing that matters…
              see later post
                MMRIZE @Spinster
                @Spinster
                With getip of @sdetweil and MMM-ModuleMonkeyPatch, I did it. (You don’t have to modify the original source code for future-proof.)
                Example.
                Server is running on 192.168.178.63 and I run 2 clients on 192.168.178.22 and 192.168.178.63.
                Both 2 clients can show different set of calendars.
                	module: "MMM-ModuleMonkeyPatch",
                		patches: [
                				method: "socketNotificationReceived",
                				patch: async function (original, args) {
                					const [ notification, payload ] = args
                					if (notification === "CALENDAR_EVENTS") {
                						const calendarName = this.config.calendars.find((cal) => cal.url === payload?.url)?.name
                						const r = await fetch('http://192.168.178.63:8080/modules/getip')
                						const ip = JSON.parse(await r.text())?.[ 'address' ] ?? null
                						if (!this.config.clientMap?.[ ip ]?.includes(calendarName)) {
                							return original(notification, { ...payload, events: [] })
                					return original(notification, payload)
                	module: "getip",
                	header: "US Holidays",
                		clientMap: {
                			"192.168.178.63": [ "cal1", "cal2", "cal3" ],
                			"192.168.178.22": ["cal3", "cal4", "cal5"]
                				url: "...",
                				url: "...",
                				url: "...",
                				url: "...",
                				url: "...",
                TO Improve
                Whenever notification CALENDAR_EVENTS coming, getip is called. After first execution, to store IP on the localStorage or cookie would be better.
                S S 2 Replies Last reply Reply Quote 0
                  Spinster @sdetweil
                  @sdetweil will express ipfilter be useful? Similar to whitelist, can we try something
                    sdetweil @Spinster
                    @Spinster no… as its in the wrong place… (inside node_helper…) we NEED the ip address to compare with
                    just get it and return . one time
                      sdetweil @MMRIZE
                      @MMRIZE said in Show calendar based on IP Address accessed:
                      BUT you are fetching cal for system not going to use it… SOME cals are 1000’s of entries especially old
                      that have to be processed… this is a bad waste of resources…
                      and this exposes a cal problem, as if u fetch http://xyz on client 1 and client 2 and client 3, we fetch it 3 times. also bad
                      this could also lead to different clients showing different data between fetchIntervals…
                        MMRIZE @sdetweil
                        @sdetweil said in Show calendar based on IP Address accessed:
                        I Can’t understand your point.
                        My code is just small injection that does filtering out calendars by condition on socketNotificationReceived. No additional fetching is needed.
                          MMRIZE @sdetweil
                          Well, if that is the issue, we need a new “calendar” module that can ignore duplicated feed on addCalendar.
                          Regardless of my code, the original calendar module will fetch a same feed multiply on multi clients. It’s MM’s limitation.
                            sdetweil @MMRIZE
                            @MMRIZE yes
                            @Spinster
                            see later post
                              sdetweil @MMRIZE
                              AFTER fetching… so throw away data, which we fetched , knowing we wouldn’t use it…
                                Spinster @MMRIZE
                                @MMRIZE I tried it, but it is still showing the calendar even if there is no calendar defined for the ip. I edited only the config.js file and added your code. Modified the calendars to suite mine. I could see even if there is no calendar defined for a particular ip. Please advice
                                  Spinster @sdetweil
                                  @sdetweil Is this working? Should I try it, please advice
                                    MMRIZE @sdetweil
                                    Still I can’t catch you.
                                    [2024-05-07 15:03:33.741] [LOG]   Use existing calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics
                                    The log shows, duplicated URL would be integrated into existing fetcher, So unlike your words, 3 clients doesn’t make 3 duplicated wasted fetcher.
                                    If clientA needs cal1, cal2, cal3 and clientB needs cal1, cal4, cal5. In this case server should fetch 5 calendars anyway. User may need cal1 ~ cal5 even on 1 screen or 2 screens, ther server’s burden would be the same.
                                    The only aspect that could be considered a waste is the transmission of unusing event data for cal4 and cal5 to clientA, but unless it’s a performance issue with the data parsing algorithm, simply having large data size being transmitted isn’t particularly problematic. Moreover, since the data is dropped in my code as soon as the notification is received, it can’t be deemed a significant memory issue. If the data size itself becomes problematic, it implies there’s already a problem with the original calendar module using cal1, cal2, cal3, cal4, and cal5.
                                    Too skeptic.
                                      MMRIZE @Spinster
                                      @Spinster said in Show calendar based on IP Address accessed:
                                      in the calendar config, I added clientMap.
                                      		clientMap: {
                                      			"192.168.178.22": [ "cal3", "cal4", "cal5" ]
                                      				url: "...",
                                      S 3 Replies Last reply Reply Quote 0
                                        sdetweil @Spinster
                                        @Spinster yes, the two pieces together
                                        ipaddress:“…”
                                        at each cal url block… only does one ipaddress per url
                                          Spinster @MMRIZE
                                          @MMRIZE
                                          Here is my config
                                          		module: "alert",
                                          		module: "updatenotification",
                                          		position: "top_bar"
                                          		module: "clock",
                                          		position: "top_left"
                                          			patches: [
                                          							const r = await fetch('http://10.5.11.1:8080/modules/getip')
                                          							console.log(ip)
                                          		module: "getip",
                                          		header: "Home Cal",
                                          			clientMap: {
                                          				"10.5.11.5": [ "cal1" ],
                                          				"10.5.11.6": ["cal2"]
                                          					fetchInterval: 10 * 60 * 1000,
                                          					symbol: "calendar-check",
                                          					url: "https://homecals/xEzboFt7Kr3Yfiys?export",
                                          This is showing both 10.5.11.5 and 10.5.11.6 the same calendar. Though 10.5.11.6 should not have any calendar since it is not defined. Even I tried without an entry of 10.5.11.6 in calendar map but it still showing the calendar. What am I doing wrong. Please advice
                                            Spinster @MMRIZE
                                            @MMRIZE I even added the calendarmap, I hope you seen my config.js sent earlier
                                            • 2 / 4
