    Show calendar based on IP Address accessed
    68 Posts 3 Posters 28.2k Views 3 Watching
      sdetweil @MMRIZE
      @MMRIZE said in Show calendar based on IP Address accessed:
      (You don’t have to modify the original source code for future-proof.)
      BUT you are fetching cal for system not going to use it… SOME cals are 1000’s of entries especially old
      that have to be processed… this is a bad waste of resources…
      and this exposes a cal problem, as if u fetch http://xyz on client 1 and client 2 and client 3, we fetch it 3 times. also bad
      this could also lead to different clients showing different data between fetchIntervals…
        MMRIZE @sdetweil
        @sdetweil said in Show calendar based on IP Address accessed:
        I Can’t understand your point.
        My code is just small injection that does filtering out calendars by condition on socketNotificationReceived. No additional fetching is needed.
          MMRIZE @sdetweil
          Well, if that is the issue, we need a new “calendar” module that can ignore duplicated feed on addCalendar.
          Regardless of my code, the original calendar module will fetch a same feed multiply on multi clients. It’s MM’s limitation.
            sdetweil @MMRIZE
            @MMRIZE yes
            @Spinster
            see later post
              sdetweil @MMRIZE
              AFTER fetching… so throw away data, which we fetched , knowing we wouldn’t use it…
                Spinster @MMRIZE
                @MMRIZE I tried it, but it is still showing the calendar even if there is no calendar defined for the ip. I edited only the config.js file and added your code. Modified the calendars to suite mine. I could see even if there is no calendar defined for a particular ip. Please advice
                  Spinster @sdetweil
                  @sdetweil Is this working? Should I try it, please advice
                    MMRIZE @sdetweil
                    Still I can’t catch you.
                    [2024-05-07 15:03:33.741] [LOG]   Use existing calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics
                    The log shows, duplicated URL would be integrated into existing fetcher, So unlike your words, 3 clients doesn’t make 3 duplicated wasted fetcher.
                    If clientA needs cal1, cal2, cal3 and clientB needs cal1, cal4, cal5. In this case server should fetch 5 calendars anyway. User may need cal1 ~ cal5 even on 1 screen or 2 screens, ther server’s burden would be the same.
                    The only aspect that could be considered a waste is the transmission of unusing event data for cal4 and cal5 to clientA, but unless it’s a performance issue with the data parsing algorithm, simply having large data size being transmitted isn’t particularly problematic. Moreover, since the data is dropped in my code as soon as the notification is received, it can’t be deemed a significant memory issue. If the data size itself becomes problematic, it implies there’s already a problem with the original calendar module using cal1, cal2, cal3, cal4, and cal5.
                    Too skeptic.
                      MMRIZE @Spinster
                      @Spinster said in Show calendar based on IP Address accessed:
                      in the calendar config, I added clientMap.
                      	header: "US Holidays",
                      		clientMap: {
                      			"192.168.178.63": [ "cal1", "cal2", "cal3" ],
                      			"192.168.178.22": [ "cal3", "cal4", "cal5" ]
                      				url: "...",
                      S 3 Replies Last reply Reply Quote 0
                        sdetweil @Spinster
                        @Spinster yes, the two pieces together
                        ipaddress:“…”
                        at each cal url block… only does one ipaddress per url
                        • 3 / 7
