    Show calendar based on IP Address accessed
    68 Posts 3 Posters 35.4k Views 3 Watching
      sdetweil @MMRIZE
      @MMRIZE yes
      @Spinster
      see later post
        sdetweil @MMRIZE
        @MMRIZE said in Show calendar based on IP Address accessed:
        My code is just small injection that does filtering out calendars by condition on socketNotificationReceived. No additional fetching is needed.
        AFTER fetching… so throw away data, which we fetched , knowing we wouldn’t use it…
          Spinster @MMRIZE
          @MMRIZE I tried it, but it is still showing the calendar even if there is no calendar defined for the ip. I edited only the config.js file and added your code. Modified the calendars to suite mine. I could see even if there is no calendar defined for a particular ip. Please advice
            Spinster @sdetweil
            @sdetweil Is this working? Should I try it, please advice
              MMRIZE @sdetweil
              Still I can’t catch you.
              [2024-05-07 15:03:33.741] [LOG]   Use existing calendarfetcher for url: https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics
              The log shows, duplicated URL would be integrated into existing fetcher, So unlike your words, 3 clients doesn’t make 3 duplicated wasted fetcher.
              If clientA needs cal1, cal2, cal3 and clientB needs cal1, cal4, cal5. In this case server should fetch 5 calendars anyway. User may need cal1 ~ cal5 even on 1 screen or 2 screens, ther server’s burden would be the same.
              The only aspect that could be considered a waste is the transmission of unusing event data for cal4 and cal5 to clientA, but unless it’s a performance issue with the data parsing algorithm, simply having large data size being transmitted isn’t particularly problematic. Moreover, since the data is dropped in my code as soon as the notification is received, it can’t be deemed a significant memory issue. If the data size itself becomes problematic, it implies there’s already a problem with the original calendar module using cal1, cal2, cal3, cal4, and cal5.
              Too skeptic.
                MMRIZE @Spinster
                @Spinster said in Show calendar based on IP Address accessed:
                in the calendar config, I added clientMap.
                	header: "US Holidays",
                		clientMap: {
                			"192.168.178.63": [ "cal1", "cal2", "cal3" ],
                			"192.168.178.22": [ "cal3", "cal4", "cal5" ]
                				url: "...",
                S 3 Replies Last reply Reply Quote 0
                  sdetweil @Spinster
                  @Spinster yes, the two pieces together
                  ipaddress:“…”
                  at each cal url block… only does one ipaddress per url
                    Spinster @MMRIZE
                    @MMRIZE
                    Here is my config
                    		module: "alert",
                    		module: "updatenotification",
                    		position: "top_bar"
                    		module: "clock",
                    		position: "top_left"
                    		module: "MMM-ModuleMonkeyPatch",
                    			patches: [
                    					method: "socketNotificationReceived",
                    					patch: async function (original, args) {
                    						const [ notification, payload ] = args
                    						if (notification === "CALENDAR_EVENTS") {
                    							const calendarName = this.config.calendars.find((cal) => cal.url === payload?.url)?.name
                    							const r = await fetch('http://10.5.11.1:8080/modules/getip')
                    							const ip = JSON.parse(await r.text())?.[ 'address' ] ?? null
                    							console.log(ip)
                    							if (!this.config.clientMap?.[ ip ]?.includes(calendarName)) {
                    								return original(notification, { ...payload, events: [] })
                    						return original(notification, payload)
                    		module: "getip",
                    		header: "Home Cal",
                    			clientMap: {
                    				"10.5.11.5": [ "cal1" ],
                    				"10.5.11.6": ["cal2"]
                    					fetchInterval: 10 * 60 * 1000,
                    					symbol: "calendar-check",
                    					url: "https://homecals/xEzboFt7Kr3Yfiys?export",
                    This is showing both 10.5.11.5 and 10.5.11.6 the same calendar. Though 10.5.11.6 should not have any calendar since it is not defined. Even I tried without an entry of 10.5.11.6 in calendar map but it still showing the calendar. What am I doing wrong. Please advice
                      Spinster @MMRIZE
                      @MMRIZE I even added the calendarmap, I hope you seen my config.js sent earlier
                        Spinster @Spinster
                        Sorry, i think I have not installed Monkey module, will install and check again
                          Spinster @sdetweil
                          Should I use your earlier code and this? Please advise
                            sdetweil @Spinster
                            @Spinster yes you need both
                            I am away from my system for another couple hours
                            will collapse to one post then
                              @Spinster ok, here is the final
                              in calendar.js
                              add these variables
                              		updateOnFetch: true,
                              		useIPAddress: false     // add config var
                              	timerHandle:null,                 // add this
                              	ourIPAddress:null,              // add this
                              	requiresVersion: "2.1.0",
                              change this
                              	// Override start method.
                              	start () {
                              to
                              this
                              	startup () {
                              add this code
                              			let ip_match = false;
                              			if(this.config.useIPAddress){
                              			 const client_ip_for_this_calendar = this.getCalendarProperty(calendar.url, "ipaddress", null)
                              			 if(this.ourIPAddress)
                              			 	  ip_match = client_ip_for_this_calendar.includes(this.ourIPAddress)
                              			if(this.config.useIPAddress == false || ip_match==true)
                              			  this.addCalendar(calendar.url, calendar.auth, calendarConfig);   // old original   line
                              and add this routine somewhere
                                notificationReceived(notification,payload){
                                	if(notification === 'ALL_MODULES_STARTED'){
                                		// if we are using ip address checking
                                			// loop thru all the modules
                                			let m = MM.getModules().withClass("getip");
                                			if(m.length){
                                				// if getip is configured and not disabled
                                				if((m[0].disabled== undefined || (m[0].disabled != undefined && m[0].disabled == false)) ){
                                					// start a timer to wait for getip to finish
                                					this.timerHandle = setInterval(()=>{
                                						// get its dom content
                                						let client_ip = document.getElementById("getip_address")
                                						// if we found id
                                						if(client_ip !== null){
                                							// stop the timer
                                							clearInterval(this.timerHandle)
                                							// save our IP address, only need to look it up once
                                							this.ourIPAddress=client_ip.innerText
                                							// call startup
                                							this.startup()
                                					}, 500)
                                			// thru the loop, didn't start a timer, module not found
                              			  if(this.timerHandle === null){
                              					// didn't find getip
                              					// module not found, can't do this later either
                              					this.config.useIPAddress = false;
                              					this.startup()
                                		// use default
                                		else
                                			this.startup()
                                	else if (notification === "FETCH_CALENDAR") {
                              			this.sendSocketNotification(notification, { url: payload.url, id: this.identifier+(this.ourIPAddress?'_'+this.ourIPAddress:'') });
                              and in the socketNotificationReceived routine
                              change this
                              	socketNotificationReceived (notification, payload) {
                              			this.sendSocketNotification(notification, { url: payload.url, id: this.identifier });
                              		if (this.identifier !== payload.id) {
                              			return;
                              to this
                              		if (this.identifier+(this.ourIPAddress?'_'+this.ourIPAddress:'') !== payload.id) {
                              			return;
                              and in the addCalendar routine
                              change this
                              to this
                              to use
                              add the getip module to config.js, anywhere
                              add property to calendar above the calendars list (but still inside the config:{}{ section)
                              useIPAddress:true,
                              in any cal url block you want to be sensitive to IP address add property
                                  ipaddress:"xxx yyy zzz",  // space separated list of client ipaddresses this calendar can be displayed on
                              andhow
                                Spinster @MMRIZE
                                @MMRIZE
                                After installing MonkeyPatch and adding the patch you have mentioned, I get the following error message when I run , npm run config:check
                                [2024-05-07 23:32:55.179] [INFO] Checking file… /home/vjkings/MagicMirror/config/config.js
                                [2024-05-07 23:32:55.222] [ERROR] Your configuration file contains syntax errors :(
                                [2024-05-07 23:32:55.223] [ERROR] Line 56 column 20: Parsing error: Unexpected token function
                                As per config.js, Line 56 is this
                                Whole section of patch as follows
                                if (notification === “CALENDAR_EVENTS”) {
                                const r = await fetch(‘http://192.168.1.4:8080/modules/getip’)
                                const ip = JSON.parse(await r.text())?.[ ‘address’ ] ?? null
                                return original(notification, { …payload, events: [] })
                                If I ignore the error and run the server, I don’t get any calendar and it just says Loading… in the mirror page
                                What is the reason for the error. Please advice
                                  Spinster @sdetweil
                                  Wow, Clear, will try it and provide feedback please.
                                    Spinster @sdetweil
                                    I made all the changes you have mentioned, it is working!!!. Thank you so much for the efforts.
                                    However, following are the observation,
                                    When I add the config.js with useIPAddress: true (calendar.js has the entry of useIPAddress:false in its default), there is no effect, however in calendar.js if I set the useIPAddress: true, it is working, I don’t understand why the configuration settings are not taken.
                                    I clearly added the useIPAddress: true before the calendars declared as part of the module configuration. Please advice how to fix this.
                                    I also have doubt on when we override the start to startup, how the notificationreceived is called. What happens when there is no start in the module.
                                    In fact this is the first time, I have added code without understanding of anything :).
                                    Please help me with configuration settings (config.js) to get it effected than hardcoding it to calendar.js
                                      sdetweil @Spinster
                                      @Spinster can you show the calendar config, you can leave out the calendars:[] list entries
                                      start is optional. but only called once
                                      getip has not placed its content yet.
                                      the notification ALL_MODULES_STARTED is sent be the system when all the
                                      modules start methods have been called
                                      from the module development doc
                                        Spinster @sdetweil
                                        Thank you for the details.
                                        As required, my calendar config as follows
                                        		module: "getip",
                                        		position:"bottom_left"
                                        		useIPAddress: true,
                                        		header: "My Calendars",
                                        					fetchInterval: 5 * 60 * 1000,
                                        					url: "https://mycalendar/xEzboFt7Kr3Yfiys?export",
                                        					ipaddress: "10.5.18.252 127.0.0.1 10.5.14.104",
                                        					//useIPAddress: true,
                                        					url: "https://mycalendar/4aK7xZPQkGKz6nCZ?export",
                                        					ipaddress: "10.5.11.5",
                                        Please let me know if I have done any mistake
                                          sdetweil @Spinster
                                          @Spinster yes, it has to be inside the
                                          config:{} section
                                          everything outside config are MagicMirror properties about a module
                                          see
                                          https://docs.magicmirror.builders/modules/configuration.html#example
                                          config is properties FOR the module and override what is defined in the module defaults:{} object
                                            Spinster @sdetweil
                                            I made the change and it first showed correctly, but when I refresh any one of the client, the other client is getting both the calendars. What is wrong? Here is my updated calendar.js as suggested by you.
                                            /* global CalendarUtils */
                                            Module.register("calendar", {
                                            	// Define module defaults
                                            	defaults: {
                                            		maximumEntries: 10, // Total Maximum Entries
                                            		maximumNumberOfDays: 365,
                                            		limitDays: 0, // Limit the number of days shown, 0 = no limit
                                            		pastDaysCount: 0,
                                            		displaySymbol: true,
                                            		defaultSymbol: "calendar-alt", // Fontawesome Symbol see https://fontawesome.com/cheatsheet?from=io
                                            		defaultSymbolClassName: "fas fa-fw fa-",
                                            		showLocation: false,
                                            		displayRepeatingCountTitle: false,
                                            		defaultRepeatingCountTitle: "",
                                            		maxTitleLength: 25,
                                            		maxLocationTitleLength: 25,
                                            		wrapEvents: false, // Wrap events to multiple lines breaking at maxTitleLength
                                            		wrapLocationEvents: false,
                                            		maxTitleLines: 3,
                                            		maxEventTitleLines: 3,
                                            		fetchInterval: 60 * 60 * 1000, // Update every hour
                                            		animationSpeed: 2000,
                                            		fade: true,
                                            		fadePoint: 0.25, // Start on 1/4th of the list.
                                            		urgency: 7,
                                            		timeFormat: "relative",
                                            		dateFormat: "MMM Do",
                                            		dateEndFormat: "LT",
                                            		fullDayEventDateFormat: "MMM Do",
                                            		showEnd: false,
                                            		getRelative: 6,
                                            		hidePrivate: false,
                                            		hideOngoing: false,
                                            		hideTime: false,
                                            		hideDuplicates: true,
                                            		showTimeToday: false,
                                            		colored: false,
                                            		forceUseCurrentTime: false,
                                            		tableClass: "small",
                                            				symbol: "calendar-alt",
                                            				url: "https://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                                            		customEvents: [
                                            			// Array of {keyword: "", symbol: "", color: "", eventClass: ""} where Keyword is a regexp and symbol/color/eventClass are to be applied for matched
                                            			{ keyword: ".*", transform: { search: "De verjaardag van ", replace: "" } },
                                            			{ keyword: ".*", transform: { search: "'s birthday", replace: "" } }
                                            		locationTitleReplace: {
                                            			"street ": ""
                                            		broadcastEvents: true,
                                            		excludedEvents: [],
                                            		sliceMultiDayEvents: false,
                                            		broadcastPastEvents: false,
                                            		nextDaysRelative: false,
                                            		selfSignedCert: false,
                                            		coloredText: false,
                                            		coloredBorder: false,
                                            		coloredSymbol: false,
                                            		coloredBackground: false,
                                            		limitDaysNeverSkip: false,
                                            		flipDateHeaderTitle: false,
                                            		useIPAddress: false,// add config var
                                            	// Define required scripts.
                                            	getStyles () {
                                            		return ["calendar.css", "font-awesome.css"];
                                            	getScripts () {
                                            		return ["calendarutils.js", "moment.js"];
                                            	// Define required translations.
                                            	getTranslations () {
                                            		// The translations for the default modules are defined in the core translation files.
                                            		// Therefore we can just return false. Otherwise we should have returned a dictionary.
                                            		// If you're trying to build your own module including translations, check out the documentation.
                                            		return false;
                                            	startup () {
                                            		//const ip = settings.detectIp(req)
                                            		Log.info(`Starting module: ${this.name}`);
                                            		Log.info(`Vijay starup Starting module: ${this.name}`);
                                            		if (this.config.colored) {
                                            			Log.warn("Your are using the deprecated config values 'colored'. Please switch to 'coloredSymbol' & 'coloredText'!");
                                            			this.config.coloredText = true;
                                            			this.config.coloredSymbol = true;
                                            		if (this.config.coloredSymbolOnly) {
                                            			Log.warn("Your are using the deprecated config values 'coloredSymbolOnly'. Please switch to 'coloredSymbol' & 'coloredText'!");
                                            			this.config.coloredText = false;
                                            		// Set locale.
                                            		moment.updateLocale(config.language, CalendarUtils.getLocaleSpecification(config.timeFormat));
                                            		// clear data holder before start
                                            		this.calendarData = {};
                                            		// indicate no data available yet
                                            		this.loaded = false;
                                            		// data holder of calendar url. Avoid fade out/in on updateDom (one for each calendar update)
                                            		this.calendarDisplayer = {};
                                            		this.config.calendars.forEach((calendar) => {
                                            			calendar.url = calendar.url.replace("webcal://", "http://");
                                            			const calendarConfig = {
                                            				maximumEntries: calendar.maximumEntries,
                                            				maximumNumberOfDays: calendar.maximumNumberOfDays,
                                            				pastDaysCount: calendar.pastDaysCount,
                                            				broadcastPastEvents: calendar.broadcastPastEvents,
                                            				selfSignedCert: calendar.selfSignedCert,
                                            				excludedEvents: calendar.excludedEvents,
                                            				fetchInterval: calendar.fetchInterval
                                            			if (typeof calendar.symbolClass === "undefined" || calendar.symbolClass === null) {
                                            				calendarConfig.symbolClass = "";
                                            			if (typeof calendar.titleClass === "undefined" || calendar.titleClass === null) {
                                            				calendarConfig.titleClass = "";
                                            			if (typeof calendar.timeClass === "undefined" || calendar.timeClass === null) {
                                            				calendarConfig.timeClass = "";
                                            			// we check user and password here for backwards compatibility with old configs
                                            			if (calendar.user && calendar.pass) {
                                            				Log.warn("Deprecation warning: Please update your calendar authentication configuration.");
                                            				Log.warn("https://docs.magicmirror.builders/modules/calendar.html#configuration-options");
                                            				calendar.auth = {
                                            					user: calendar.user,
                                            					pass: calendar.pass
                                            			//this.addCalendar(calendar.url, calendar.auth, calendarConfig);
                                            		// for backward compatibility titleReplace
                                            		if (typeof this.config.titleReplace !== "undefined") {
                                            			Log.warn("Deprecation warning: Please consider upgrading your calendar titleReplace configuration to customEvents.");
                                            			for (const [titlesearchstr, titlereplacestr] of Object.entries(this.config.titleReplace)) {
                                            				this.config.customEvents.push({ keyword: ".*", transform: { search: titlesearchstr, replace: titlereplacestr } });
                                            		this.selfUpdate();
                                            	// Override socket notification handler.
                                            			return;
                                            			Log.warn("Calendar Events called Vijay");
                                            			if (this.hasCalendarURL(payload.url)) {
                                            				this.calendarData[payload.url] = payload.events;
                                            				this.error = null;
                                            				this.loaded = true;
                                            				if (this.config.broadcastEvents) {
                                            					this.broadcastEvents();
                                            				if (!this.config.updateOnFetch) {
                                            					if (this.calendarDisplayer[payload.url] === undefined) {
                                            						// calendar will never displayed, so display it
                                            						this.updateDom(this.config.animationSpeed);
                                            						// set this calendar as displayed
                                            						this.calendarDisplayer[payload.url] = true;
                                            					} else {
                                            						Log.debug("[Calendar] DOM not updated waiting self update()");
                                            					return;
                                            		} else if (notification === "CALENDAR_ERROR") {
                                            			let error_message = this.translate(payload.error_type);
                                            			this.error = this.translate("MODULE_CONFIG_ERROR", { MODULE_NAME: this.name, ERROR: error_message });
                                            			this.loaded = true;
                                            	eventEndingWithinNextFullTimeUnit (event, ONE_DAY) {
                                            		const now = new Date();
                                            		return event.endDate - now <= ONE_DAY;
                                            		if(notification === 'ALL_MODULES_STARTED') {
                                            			Log.info(`Vijay Calling : ${this.name}`);
                                            			console.log("Vijay : Calendar notificationReceived called");
                                            				console.log("Vijay : Calendar Using IP Address");
                                            				// find our dependent module in config.js, returns an array []
                                            				if(m.length){
                                            					// if getip is not disabled
                                            					if((m[0].disabled == undefined || (m[0].disabled != undefined && m[0].disabled == false)) ){
                                            							// if we found id
                                            								// stop the timer
                                            								// call startup
                                            								this.startup()
                                            						}, 500)
                                            				// didn't start a timer, module not found
                                            						// turn off address checking
                                            						// start fetching calendars
                                            						Log.info(`Vijay No timer, useIP set to false: ${this.name}`);
                                            						this.startup()
                                            			// use old approach
                                            			else{
                                            				Log.info(`Vijay timer available :  ${this.name}`);
                                            				this.startup()
                                            Please let me know if I have to do something about this.
                                            • 2 / 4
