    Show calendar based on IP Address accessed
    68 Posts 3 Posters 33.8k Views 3 Watching
      MMRIZE @Spinster
      @Spinster said in Show calendar based on IP Address accessed:
      Modified the calendars to suite mine. I could see even if there is no calendar defined for a particular ip. Please advice
      in the calendar config, I added clientMap.
      	header: "US Holidays",
      		clientMap: {
      			"192.168.178.63": [ "cal1", "cal2", "cal3" ],
      			"192.168.178.22": [ "cal3", "cal4", "cal5" ]
      				url: "...",
      S 3 Replies Last reply Reply Quote 0
        sdetweil @Spinster
        @Spinster yes, the two pieces together
        ipaddress:“…”
        at each cal url block… only does one ipaddress per url
          Spinster @MMRIZE
          @MMRIZE
          Here is my config
          		module: "alert",
          		module: "updatenotification",
          		position: "top_bar"
          		module: "clock",
          		position: "top_left"
          		module: "MMM-ModuleMonkeyPatch",
          			patches: [
          					method: "socketNotificationReceived",
          					patch: async function (original, args) {
          						const [ notification, payload ] = args
          						if (notification === "CALENDAR_EVENTS") {
          							const calendarName = this.config.calendars.find((cal) => cal.url === payload?.url)?.name
          							const r = await fetch('http://10.5.11.1:8080/modules/getip')
          							const ip = JSON.parse(await r.text())?.[ 'address' ] ?? null
          							console.log(ip)
          							if (!this.config.clientMap?.[ ip ]?.includes(calendarName)) {
          								return original(notification, { ...payload, events: [] })
          						return original(notification, payload)
          		module: "getip",
          		header: "Home Cal",
          			clientMap: {
          				"10.5.11.5": [ "cal1" ],
          				"10.5.11.6": ["cal2"]
          					fetchInterval: 10 * 60 * 1000,
          					symbol: "calendar-check",
          					url: "https://homecals/xEzboFt7Kr3Yfiys?export",
          This is showing both 10.5.11.5 and 10.5.11.6 the same calendar. Though 10.5.11.6 should not have any calendar since it is not defined. Even I tried without an entry of 10.5.11.6 in calendar map but it still showing the calendar. What am I doing wrong. Please advice
            Spinster @MMRIZE
            @MMRIZE I even added the calendarmap, I hope you seen my config.js sent earlier
              Spinster @Spinster
              Sorry, i think I have not installed Monkey module, will install and check again
                Spinster @sdetweil
                Should I use your earlier code and this? Please advise
                  sdetweil @Spinster
                  @Spinster yes you need both
                  I am away from my system for another couple hours
                  will collapse to one post then
                    @Spinster ok, here is the final
                    in calendar.js
                    add these variables
                    		updateOnFetch: true,
                    		useIPAddress: false     // add config var
                    	timerHandle:null,                 // add this
                    	ourIPAddress:null,              // add this
                    	requiresVersion: "2.1.0",
                    change this
                    	// Override start method.
                    	start () {
                    to
                    this
                    	startup () {
                    add this code
                    			let ip_match = false;
                    			if(this.config.useIPAddress){
                    			 const client_ip_for_this_calendar = this.getCalendarProperty(calendar.url, "ipaddress", null)
                    			 if(this.ourIPAddress)
                    			 	  ip_match = client_ip_for_this_calendar.includes(this.ourIPAddress)
                    			if(this.config.useIPAddress == false || ip_match==true)
                    			  this.addCalendar(calendar.url, calendar.auth, calendarConfig);   // old original   line
                    and add this routine somewhere
                      notificationReceived(notification,payload){
                      	if(notification === 'ALL_MODULES_STARTED'){
                      		// if we are using ip address checking
                      			// loop thru all the modules
                      			let m = MM.getModules().withClass("getip");
                      			if(m.length){
                      				// if getip is configured and not disabled
                      				if((m[0].disabled== undefined || (m[0].disabled != undefined && m[0].disabled == false)) ){
                      					// start a timer to wait for getip to finish
                      					this.timerHandle = setInterval(()=>{
                      						// get its dom content
                      						let client_ip = document.getElementById("getip_address")
                      						// if we found id
                      						if(client_ip !== null){
                      							// stop the timer
                      							clearInterval(this.timerHandle)
                      							// save our IP address, only need to look it up once
                      							this.ourIPAddress=client_ip.innerText
                      							// call startup
                      							this.startup()
                      					}, 500)
                      			// thru the loop, didn't start a timer, module not found
                    			  if(this.timerHandle === null){
                    					// didn't find getip
                    					// module not found, can't do this later either
                    					this.config.useIPAddress = false;
                    					this.startup()
                      		// use default
                      		else
                      			this.startup()
                      	else if (notification === "FETCH_CALENDAR") {
                    			this.sendSocketNotification(notification, { url: payload.url, id: this.identifier+(this.ourIPAddress?'_'+this.ourIPAddress:'') });
                    and in the socketNotificationReceived routine
                    change this
                    	socketNotificationReceived (notification, payload) {
                    			this.sendSocketNotification(notification, { url: payload.url, id: this.identifier });
                    		if (this.identifier !== payload.id) {
                    			return;
                    to this
                    		if (this.identifier+(this.ourIPAddress?'_'+this.ourIPAddress:'') !== payload.id) {
                    			return;
                    and in the addCalendar routine
                    change this
                    to this
                    to use
                    add the getip module to config.js, anywhere
                    add property to calendar above the calendars list (but still inside the config:{}{ section)
                    useIPAddress:true,
                    in any cal url block you want to be sensitive to IP address add property
                        ipaddress:"xxx yyy zzz",  // space separated list of client ipaddresses this calendar can be displayed on
                    andhow
                      Spinster @MMRIZE
                      @MMRIZE
                      After installing MonkeyPatch and adding the patch you have mentioned, I get the following error message when I run , npm run config:check
                      [2024-05-07 23:32:55.179] [INFO] Checking file… /home/vjkings/MagicMirror/config/config.js
                      [2024-05-07 23:32:55.222] [ERROR] Your configuration file contains syntax errors :(
                      [2024-05-07 23:32:55.223] [ERROR] Line 56 column 20: Parsing error: Unexpected token function
                      As per config.js, Line 56 is this
                      Whole section of patch as follows
                      if (notification === “CALENDAR_EVENTS”) {
                      const r = await fetch(‘http://192.168.1.4:8080/modules/getip’)
                      const ip = JSON.parse(await r.text())?.[ ‘address’ ] ?? null
                      return original(notification, { …payload, events: [] })
                      If I ignore the error and run the server, I don’t get any calendar and it just says Loading… in the mirror page
                      What is the reason for the error. Please advice
                        Spinster @sdetweil
                        Wow, Clear, will try it and provide feedback please.
                          Spinster @sdetweil
                          I made all the changes you have mentioned, it is working!!!. Thank you so much for the efforts.
                          However, following are the observation,
                          When I add the config.js with useIPAddress: true (calendar.js has the entry of useIPAddress:false in its default), there is no effect, however in calendar.js if I set the useIPAddress: true, it is working, I don’t understand why the configuration settings are not taken.
                          I clearly added the useIPAddress: true before the calendars declared as part of the module configuration. Please advice how to fix this.
                          I also have doubt on when we override the start to startup, how the notificationreceived is called. What happens when there is no start in the module.
                          In fact this is the first time, I have added code without understanding of anything :).
                          Please help me with configuration settings (config.js) to get it effected than hardcoding it to calendar.js
                            sdetweil @Spinster
                            @Spinster can you show the calendar config, you can leave out the calendars:[] list entries
                            start is optional. but only called once
                            getip has not placed its content yet.
                            the notification ALL_MODULES_STARTED is sent be the system when all the
                            modules start methods have been called
                            from the module development doc
                              Spinster @sdetweil
                              Thank you for the details.
                              As required, my calendar config as follows
                              		module: "getip",
                              		position:"bottom_left"
                              		useIPAddress: true,
                              		header: "My Calendars",
                              					fetchInterval: 5 * 60 * 1000,
                              					url: "https://mycalendar/xEzboFt7Kr3Yfiys?export",
                              					ipaddress: "10.5.18.252 127.0.0.1 10.5.14.104",
                              					//useIPAddress: true,
                              					url: "https://mycalendar/4aK7xZPQkGKz6nCZ?export",
                              					ipaddress: "10.5.11.5",
                              Please let me know if I have done any mistake
                                sdetweil @Spinster
                                @Spinster yes, it has to be inside the
                                config:{} section
                                everything outside config are MagicMirror properties about a module
                                see
                                https://docs.magicmirror.builders/modules/configuration.html#example
                                config is properties FOR the module and override what is defined in the module defaults:{} object
                                  Spinster @sdetweil
                                  I made the change and it first showed correctly, but when I refresh any one of the client, the other client is getting both the calendars. What is wrong? Here is my updated calendar.js as suggested by you.
                                  /* global CalendarUtils */
                                  Module.register("calendar", {
                                  	// Define module defaults
                                  	defaults: {
                                  		maximumEntries: 10, // Total Maximum Entries
                                  		maximumNumberOfDays: 365,
                                  		limitDays: 0, // Limit the number of days shown, 0 = no limit
                                  		pastDaysCount: 0,
                                  		displaySymbol: true,
                                  		defaultSymbol: "calendar-alt", // Fontawesome Symbol see https://fontawesome.com/cheatsheet?from=io
                                  		defaultSymbolClassName: "fas fa-fw fa-",
                                  		showLocation: false,
                                  		displayRepeatingCountTitle: false,
                                  		defaultRepeatingCountTitle: "",
                                  		maxTitleLength: 25,
                                  		maxLocationTitleLength: 25,
                                  		wrapEvents: false, // Wrap events to multiple lines breaking at maxTitleLength
                                  		wrapLocationEvents: false,
                                  		maxTitleLines: 3,
                                  		maxEventTitleLines: 3,
                                  		fetchInterval: 60 * 60 * 1000, // Update every hour
                                  		animationSpeed: 2000,
                                  		fade: true,
                                  		fadePoint: 0.25, // Start on 1/4th of the list.
                                  		urgency: 7,
                                  		timeFormat: "relative",
                                  		dateFormat: "MMM Do",
                                  		dateEndFormat: "LT",
                                  		fullDayEventDateFormat: "MMM Do",
                                  		showEnd: false,
                                  		getRelative: 6,
                                  		hidePrivate: false,
                                  		hideOngoing: false,
                                  		hideTime: false,
                                  		hideDuplicates: true,
                                  		showTimeToday: false,
                                  		colored: false,
                                  		forceUseCurrentTime: false,
                                  		tableClass: "small",
                                  				symbol: "calendar-alt",
                                  				url: "https://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                                  		customEvents: [
                                  			// Array of {keyword: "", symbol: "", color: "", eventClass: ""} where Keyword is a regexp and symbol/color/eventClass are to be applied for matched
                                  			{ keyword: ".*", transform: { search: "De verjaardag van ", replace: "" } },
                                  			{ keyword: ".*", transform: { search: "'s birthday", replace: "" } }
                                  		locationTitleReplace: {
                                  			"street ": ""
                                  		broadcastEvents: true,
                                  		excludedEvents: [],
                                  		sliceMultiDayEvents: false,
                                  		broadcastPastEvents: false,
                                  		nextDaysRelative: false,
                                  		selfSignedCert: false,
                                  		coloredText: false,
                                  		coloredBorder: false,
                                  		coloredSymbol: false,
                                  		coloredBackground: false,
                                  		limitDaysNeverSkip: false,
                                  		flipDateHeaderTitle: false,
                                  		useIPAddress: false,// add config var
                                  	// Define required scripts.
                                  	getStyles () {
                                  		return ["calendar.css", "font-awesome.css"];
                                  	getScripts () {
                                  		return ["calendarutils.js", "moment.js"];
                                  	// Define required translations.
                                  	getTranslations () {
                                  		// The translations for the default modules are defined in the core translation files.
                                  		// Therefore we can just return false. Otherwise we should have returned a dictionary.
                                  		// If you're trying to build your own module including translations, check out the documentation.
                                  		return false;
                                  	startup () {
                                  		//const ip = settings.detectIp(req)
                                  		Log.info(`Starting module: ${this.name}`);
                                  		Log.info(`Vijay starup Starting module: ${this.name}`);
                                  		if (this.config.colored) {
                                  			Log.warn("Your are using the deprecated config values 'colored'. Please switch to 'coloredSymbol' & 'coloredText'!");
                                  			this.config.coloredText = true;
                                  			this.config.coloredSymbol = true;
                                  		if (this.config.coloredSymbolOnly) {
                                  			Log.warn("Your are using the deprecated config values 'coloredSymbolOnly'. Please switch to 'coloredSymbol' & 'coloredText'!");
                                  			this.config.coloredText = false;
                                  		// Set locale.
                                  		moment.updateLocale(config.language, CalendarUtils.getLocaleSpecification(config.timeFormat));
                                  		// clear data holder before start
                                  		this.calendarData = {};
                                  		// indicate no data available yet
                                  		this.loaded = false;
                                  		// data holder of calendar url. Avoid fade out/in on updateDom (one for each calendar update)
                                  		this.calendarDisplayer = {};
                                  		this.config.calendars.forEach((calendar) => {
                                  			calendar.url = calendar.url.replace("webcal://", "http://");
                                  			const calendarConfig = {
                                  				maximumEntries: calendar.maximumEntries,
                                  				maximumNumberOfDays: calendar.maximumNumberOfDays,
                                  				pastDaysCount: calendar.pastDaysCount,
                                  				broadcastPastEvents: calendar.broadcastPastEvents,
                                  				selfSignedCert: calendar.selfSignedCert,
                                  				excludedEvents: calendar.excludedEvents,
                                  				fetchInterval: calendar.fetchInterval
                                  			if (typeof calendar.symbolClass === "undefined" || calendar.symbolClass === null) {
                                  				calendarConfig.symbolClass = "";
                                  			if (typeof calendar.titleClass === "undefined" || calendar.titleClass === null) {
                                  				calendarConfig.titleClass = "";
                                  			if (typeof calendar.timeClass === "undefined" || calendar.timeClass === null) {
                                  				calendarConfig.timeClass = "";
                                  			// we check user and password here for backwards compatibility with old configs
                                  			if (calendar.user && calendar.pass) {
                                  				Log.warn("Deprecation warning: Please update your calendar authentication configuration.");
                                  				Log.warn("https://docs.magicmirror.builders/modules/calendar.html#configuration-options");
                                  				calendar.auth = {
                                  					user: calendar.user,
                                  					pass: calendar.pass
                                  			//this.addCalendar(calendar.url, calendar.auth, calendarConfig);
                                  		// for backward compatibility titleReplace
                                  		if (typeof this.config.titleReplace !== "undefined") {
                                  			Log.warn("Deprecation warning: Please consider upgrading your calendar titleReplace configuration to customEvents.");
                                  			for (const [titlesearchstr, titlereplacestr] of Object.entries(this.config.titleReplace)) {
                                  				this.config.customEvents.push({ keyword: ".*", transform: { search: titlesearchstr, replace: titlereplacestr } });
                                  		this.selfUpdate();
                                  	// Override socket notification handler.
                                  			return;
                                  			Log.warn("Calendar Events called Vijay");
                                  			if (this.hasCalendarURL(payload.url)) {
                                  				this.calendarData[payload.url] = payload.events;
                                  				this.error = null;
                                  				this.loaded = true;
                                  				if (this.config.broadcastEvents) {
                                  					this.broadcastEvents();
                                  				if (!this.config.updateOnFetch) {
                                  					if (this.calendarDisplayer[payload.url] === undefined) {
                                  						// calendar will never displayed, so display it
                                  						this.updateDom(this.config.animationSpeed);
                                  						// set this calendar as displayed
                                  						this.calendarDisplayer[payload.url] = true;
                                  					} else {
                                  						Log.debug("[Calendar] DOM not updated waiting self update()");
                                  					return;
                                  		} else if (notification === "CALENDAR_ERROR") {
                                  			let error_message = this.translate(payload.error_type);
                                  			this.error = this.translate("MODULE_CONFIG_ERROR", { MODULE_NAME: this.name, ERROR: error_message });
                                  			this.loaded = true;
                                  	eventEndingWithinNextFullTimeUnit (event, ONE_DAY) {
                                  		const now = new Date();
                                  		return event.endDate - now <= ONE_DAY;
                                  		if(notification === 'ALL_MODULES_STARTED') {
                                  			Log.info(`Vijay Calling : ${this.name}`);
                                  			console.log("Vijay : Calendar notificationReceived called");
                                  				console.log("Vijay : Calendar Using IP Address");
                                  				// find our dependent module in config.js, returns an array []
                                  				if(m.length){
                                  					// if getip is not disabled
                                  					if((m[0].disabled == undefined || (m[0].disabled != undefined && m[0].disabled == false)) ){
                                  							// if we found id
                                  								// stop the timer
                                  								// call startup
                                  								this.startup()
                                  						}, 500)
                                  				// didn't start a timer, module not found
                                  						// turn off address checking
                                  						// start fetching calendars
                                  						Log.info(`Vijay No timer, useIP set to false: ${this.name}`);
                                  						this.startup()
                                  			// use old approach
                                  			else{
                                  				Log.info(`Vijay timer available :  ${this.name}`);
                                  				this.startup()
                                  Please let me know if I have to do something about this.
                                    sdetweil @Spinster
                                    @Spinster sorry, explain
                                    the other client
                                    on refresh, everything is the same in the module.
                                    each module has a unique id assigned, based on its placement in config.js
                                    calendar sends its id down to its helper
                                    and the helper sends the id back on response. as the response mechanism is a broadcast to all connected clients.
                                    the clients then check to see if this response is for their request.
                                    from code posted
                                    also, please start using code block wrapper for all config, code and error postings
                                    paste text into the message editor
                                    empty line above and below
                                    select that pasted text
                                    hit the editor button </>
                                      Spinster @sdetweil
                                      Sorry for not explaining it clearly.
                                      I have two clients, one from a browser using http://ip:8080 and another the native client.
                                      upon using pm2 start MagicMirror, I get the out put in native client and the browser properly showing their respective calendar.
                                      If I hit refresh button on browser, browser is showing only its own calendar however the native client is displaying both the calendars (ie. its own and the one which is supposed to be shown in browser), If I hit Ctr-R on the native client, then browser is showing both the calendars while the native client is showing only its own calendar.
                                      Also I don’t understand the following instructions, please explain what should I do
                                        sdetweil @Spinster
                                        when creating a message here on the forum, if you are inserting code, config, or error text (like you did when u pasted the whole calendar.js, or the part of the module config)
                                        do the instructions I gave
                                          @Spinster I rejected your post (AND a second time) . I already fixed the prior
                                          AND you left your unique info in the module info…
                                          anyhow…
                                          found the issue… the ‘identifier’ is based on placement in config.js SO, it will be the SAME on both browsers… oops…
                                          here are the two lines to fix
                                          1. in the socketNotificationReceived function
                                            change this
                                          			return;
                                          to this
                                          			return;
                                          and 2.
                                          change this
                                          to this
                                            Spinster @sdetweil
                                            You did it! Excellent, I really appreciate your versatility and quick response.
                                            Hope this shall become a feature for the calendar or any other modules if anyone has similar requirement and prefers it.
                                            Sincere Thanks to you and gratitude for your effort and time~
                                            • 3 / 4
